J’ai cette erreur Timeout while fetching data: https://api.awekas.at/current.php?key=rtxlAv2QoW#########arnkP1TVQ%3D%3D&lng=fr"
C’est pour avoir les valeurs de ma station météo.
Cela arrive très souvent parfois ça repart tout seul, parfois il faut redémarrer HA et parfois rien n’y fait.
[center]## System Information
| version |
core-2024.6.3 |
| installation_type |
Home Assistant OS |
| dev |
false |
| hassio |
true |
| docker |
true |
| user |
root |
| virtualenv |
false |
| python_version |
3.12.2 |
| os_name |
Linux |
| os_version |
6.6.29-haos |
| arch |
x86_64 |
| timezone |
Europe/Paris |
| config_dir |
/config |
| GitHub API |
ok |
| GitHub Content |
ok |
| GitHub Web |
ok |
5000 |
| Installed Version |
1.34.0 |
| Stage |
running |
| Available Repositories |
1462 |
| Downloaded Repositories |
15 |
| HACS Data |
ok |
| logged_in |
false |
| can_reach_cert_server |
ok |
| can_reach_cloud_auth |
ok |
| can_reach_cloud |
ok |
| host_os |
Home Assistant OS 12.3 |
| update_channel |
stable |
| supervisor_version |
supervisor-2024.06.0 |
| agent_version |
1.6.0 |
| docker_version |
25.0.5 |
| disk_total |
30.8 GB |
| disk_used |
11.0 GB |
| healthy |
true |
| supported |
true |
| host_connectivity |
true |
| supervisor_connectivity |
true |
| ntp_synchronized |
true |
| virtualization |
kvm |
| board |
ova |
| supervisor_api |
ok |
| version_api |
ok |
| installed_addons |
Advanced SSH & Web Terminal (18.0.0), Grafana (10.0.0), InfluxDB (5.0.0), eWeLink Smart Home (1.4.3), Samba Backup (5.2.0), Mosquitto broker (6.4.1), Duck DNS (1.17.0), Samba NAS (12.2.0-nas2), File editor (5.8.0), Nginx Proxy Manager (1.0.1) |
| dashboards |
12 |
| resources |
6 |
| views |
31 |
| mode |
storage |
| oldest_recorder_run |
8 juin 2024 à 06:19 |
| current_recorder_run |
18 juin 2024 à 19:09 |
| estimated_db_size |
593.73 MiB |
| database_engine |
sqlite |
| database_version |
3.44.2 |
[/center]
Si c’est l’API qui ne répond pas tu ne vas pas pouvoir y faire grand chose.
Essaye de l’appeler à la main (en mettrant l’URL dans un navigateur par exemple) pour voir ce qui se passe.
Tu peux augmenter le timeout, par défaut, il est à 10 secondes : RESTful Sensor - Home Assistant
Merci de vos réponses,
Je n’ai pas de problème quand j’accède à l’API dans un navigateur.
J’ai mis 60 pour le rafraîchissement.
Qu’appelles-tu « rafraîchiseement » ?
Il ne faut pas confondre « scan_interval » et « timeout ».
Rafraîchissement=scan_ interval
Je te conseille d’augmenter « timeout » si tu veux moins d’erreur dans tes logs.
Et « scan_interval » doit être supérieur à « timeout ».
Essaie avec :
timeout: 30
scan_interval: 60
J’ai mis scan_ interval à 90 et timeout à 60 et je n’ai plus d’erreurs, avec 60 et 30 j’avais encore quelques erreurs.
Merci Giga77
