zigbee2mqtt ne marche pas
*la fenetre de gauche n’affiche rien *
Ma configuration de la clef
le text
[22:37:56] INFO: Preparing to start…
[22:37:57] INFO: Socat not enabled
[22:37:59] INFO: Starting Zigbee2MQTT…
[2024-06-11 22:38:04] info: z2m: Logging to console, file (filename: log.log)
[2024-06-11 22:38:04] info: z2m: Starting Zigbee2MQTT version 1.38.0 (commit #unknown)
[2024-06-11 22:38:04] info: z2m: Starting zigbee-herdsman (0.49.2)
[2024-06-11 22:38:05] warning: zh:ezsp: Deprecated driver ‹ ezsp › currently in use, ‹ ember › will become the officially supported EmberZNet driver in next release. If using Zigbee2MQTT see Improved Ember (EZSP) driver (experimental) · Koenkk/zigbee2mqtt · Discussion #21462 · GitHub
[2024-06-11 22:38:09] error: zh:ezsp:ezsp: Connection attempt 1 error: Error: getaddrinfo ENOTFOUND core-silabs-multiprotocol
at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:107:26)
[2024-06-11 22:38:17] error: zh:ezsp:ezsp: Connection attempt 2 error: Error: getaddrinfo ENOTFOUND core-silabs-multiprotocol
[2024-06-11 22:38:31] error: zh:ezsp:ezsp: Connection attempt 3 error: Error: getaddrinfo ENOTFOUND core-silabs-multiprotocol
[2024-06-11 22:38:50] error: zh:ezsp:ezsp: Connection attempt 4 error: Error: getaddrinfo ENOTFOUND core-silabs-multiprotocol
[2024-06-11 22:38:50] error: z2m: Error while starting zigbee-herdsman
[2024-06-11 22:38:50] error: z2m: Failed to start zigbee
[2024-06-11 22:38:50] error: z2m: Check Zigbee2MQTT fails to start | Zigbee2MQTT for possible solutions
[2024-06-11 22:38:50] error: z2m: Exiting…
[2024-06-11 22:38:50] error: z2m: Error: Failure to connect
at Ezsp.connect (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:370:19)
at processTicksAndRejections (node:internal/process/task_queues:95:5)
at Driver.startup (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:164:13)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:127:29)
at Zigbee.start (/app/lib/zigbee.ts:62:27)
at Controller.start (/app/lib/controller.ts:109:27)
at start (/app/index.js:107:5)
je ne trouve pas le probleme merci de me tenir informé
merci
bonne journée
[center]## System Information
version | core-2024.6.2 |
dev | false |
hassio | true |
docker | true |
user | root |
virtualenv | false |
python_version | 3.12.2 |
os_name | Linux |
os_version | 6.6.28-haos-raspi |
arch | aarch64 |
timezone | Europe/Zurich |
config_dir | /config |
logged_in | false |
can_reach_cert_server | ok |
can_reach_cloud_auth | ok |
can_reach_cloud | ok |
host_os | Home Assistant OS 12.3 |
update_channel | stable |
supervisor_version | supervisor-2024.06.0 |
agent_version | 1.6.0 |
docker_version | 25.0.5 |
disk_total | 109.3 GB |
disk_used | 7.0 GB |
healthy | true |
supported | true |
host_connectivity | true |
supervisor_connectivity | true |
ntp_synchronized | true |
virtualization | |
board | rpi4-64 |
supervisor_api | ok |
version_api | ok |
installed_addons | Silicon Labs Multiprotocol (2.4.5), OpenThread Border Router (2.6.0), Mosquitto broker (6.4.1), ZeroTier One (0.18.0), tydom2mqtt (3.5.1), go2rtc (1.9.3), Zigbee2MQTT (1.38.0-1) |
dashboards | 2 |
resources | 0 |
views | 1 |
mode | storage |
oldest_recorder_run | 26 mai 2024 à 21:08 |
current_recorder_run | 11 juin 2024 à 21:57 |
estimated_db_size | 24.50 MiB |
database_engine | sqlite |
database_version | 3.44.2 |
