j’ai installé une clé bluetooth SABRENT BT-UB40 sur mon raspberry pi 4 .
je n’arrive pas a associer l’enceinte avec home assistant (pas d’integration )
sur le raspberry est installé home assistant os et la derniere version de home assistant
Home Assistant 2022.11.5
Supervisor 2022.11.2
Operating System 9.3
Interface utilisateur : 20221108
Renseigner votre problème
version
core-2022.11.5
installation_type
Home Assistant OS
dev
false
hassio
true
docker
true
user
root
virtualenv
false
python_version
3.10.7
os_name
Linux
os_version
5.15.61-v8
arch
aarch64
timezone
Europe/Paris
config_dir
/config
GitHub API
ok
GitHub Content
ok
GitHub Web
ok
GitHub API Calls Remaining
5000
Installed Version
1.28.3
Stage
running
Available Repositories
1155
Downloaded Repositories
2
logged_in
false
can_reach_cert_server
ok
can_reach_cloud_auth
ok
can_reach_cloud
ok
host_os
Home Assistant OS 9.3
update_channel
stable
supervisor_version
supervisor-2022.11.2
agent_version
1.4.1
docker_version
20.10.18
disk_total
109.3 GB
disk_used
11.1 GB
healthy
true
supported
true
board
rpi4-64
supervisor_api
ok
version_api
ok
installed_addons
File editor (5.4.2), Terminal & SSH (9.6.1), Samba share (10.0.0), Zigbee2MQTT (1.28.4-1), Mosquitto broker (6.1.3), Duck DNS (1.15.0), Studio Code Server (5.4.1), Node-RED (13.5.3), Home Assistant Google Drive Backup (0.109.2), InfluxDB (4.5.0), Grafana (8.1.0), AppDaemon (0.10.1)
