Problème de configuration InfluxDB : pas de sensor
J’ai procédé à l’installation d’InfluxDB en suivant le tutoriel de McFly (✅ Installer InfluxDB dans Home Assistant et booster votre base de donnée)
A priori (journal d’installation), tout c’est bien déroulé mais je n’ai aucun sensor qui apparait sous InfluxDB. J’ai donc du rater quelque chose. Si quelqu’un a une piste, je suis preneur :slight_smile:
Journal :
s6-rc: info: service base-addon-banner: starting
 Add-on: InfluxDB
 Scalable datastore for metrics, events, and real-time analytics
 Add-on version: 4.7.0
 You are running the latest version of this add-on.
 System: Home Assistant OS 10.3  (aarch64 / raspberrypi4-64)
 Home Assistant Core: 2023.7.1
 Home Assistant Supervisor: 2023.07.1
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service base-addon-timezone: starting
s6-rc: info: service base-addon-log-level: starting
[08:04:03] INFO: Configuring timezone (Europe/Paris)...
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service base-addon-timezone successfully started
cont-init: info: running /etc/cont-init.d/create-users.sh
cont-init: info: /etc/cont-init.d/create-users.sh exited 0
cont-init: info: running /etc/cont-init.d/influxdb.sh
cont-init: info: /etc/cont-init.d/influxdb.sh exited 0
cont-init: info: running /etc/cont-init.d/kapacitor.sh
cont-init: info: /etc/cont-init.d/kapacitor.sh exited 0
cont-init: info: running /etc/cont-init.d/nginx.sh
cont-init: info: /etc/cont-init.d/nginx.sh exited 0
services-up: info: copying legacy longrun chronograf (no readiness notification)
services-up: info: copying legacy longrun influxdb (no readiness notification)
services-up: info: copying legacy longrun kapacitor (no readiness notification)
services-up: info: copying legacy longrun nginx (no readiness notification)
[08:04:06] INFO: Kapacitor is waiting until InfluxDB is available...
[08:04:06] INFO: Chronograf is waiting until InfluxDB is available...
[08:04:06] INFO: Starting the InfluxDB...
[08:04:27] INFO: Starting Chronograf...
[08:04:27] INFO: Starting the Kapacitor
2023/07/10 08:04:27 Using configuration at: /etc/kapacitor/kapacitor.conf
time="2023-07-10T08:04:39+02:00" level=info msg="Moving from version 1.8.0"
time="2023-07-10T08:04:39+02:00" level=info msg="Moving to version 1.10.1"
time="2023-07-10T08:04:39+02:00" level=info msg="Successfully created /data/backup/chronograf.db.1.8.0"
time="2023-07-10T08:04:39+02:00" level=info msg="Reporting usage stats" component=usage freq=24h reporting_addr="https://usage.influxdata.com" stats="os,arch,version,cluster_id,uptime"
time="2023-07-10T08:04:39+02:00" level=info msg="Serving chronograf at http://127.0.0.1:8889" component=server
[08:04:39] INFO: Starting NGINX...
time="2023-07-10T08:09:58+02:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:55326" response_time="618.525µs" status=200
time="2023-07-10T08:09:58+02:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:55334" response_time="473.547µs" status=200
time="2023-07-10T08:09:58+02:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:55348" response_time="462.139µs" status=200
time="2023-07-10T08:09:58+02:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:55356" response_time=7.539003ms status=200
time="2023-07-10T08:09:58+02:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:55360" response_time=4.905609ms status=200
time="2023-07-10T08:09:58+02:00" level=info msg="Response: No Content" component=server method=GET remote_addr="127.0.0.1:55364" response_time=1.699097ms status=204
time="2023-07-10T08:09:58+02:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:55374" response_time="412.288µs" status=200
time="2023-07-10T08:09:58+02:00" level=info msg="Response: OK" component=server method=POST remote_addr="127.0.0.1:55390" response_time=3.338861ms status=200
time="2023-07-10T08:09:58+02:00" level=info msg="Response: OK" component=server method=POST remote_addr="127.0.0.1:55392" response_time=2.820539ms status=200
time="2023-07-10T08:10:01+02:00" level=info msg="Response: No Content" component=server method=GET remote_addr="127.0.0.1:55406" response_time=1.420603ms status=204
time="2023-07-10T08:10:01+02:00" level=info msg="Response: OK" component=server method=POST remote_addr="127.0.0.1:55422" response_time=2.06146ms status=200
time="2023-07-10T08:10:01+02:00" level=info msg="Response: OK" component=server method=POST remote_addr="127.0.0.1:55428" response_time=2.072701ms status=200
time="2023-07-10T08:10:01+02:00" level=info msg="Response: OK" component=server method=POST remote_addr="127.0.0.1:55436" response_time=2.728651ms status=200
time="2023-07-10T08:10:01+02:00" level=info msg="Response: OK" component=server method=POST remote_addr="127.0.0.1:55452" response_time=3.359509ms status=200
time="2023-07-10T08:10:08+02:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:48978" response_time="195.607µs" status=200
time="2023-07-10T08:10:18+02:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:33122" response_time="96.647µs" status=200`Texte préformaté`
[center]## System Information
version core-2023.7.1
python_version 3.11.4
os_version 6.1.21-v8
Installed Version 1.32.1
Available Repositories 1342
Downloaded Repositories 8
host_os Home Assistant OS 10.3
supervisor_version supervisor-2023.07.1
agent_version 1.5.1
docker_version 23.0.6
disk_total 457.7 GB
disk_used 7.3 GB
board rpi4-64
installed_addons File editor (5.6.0), Mosquitto broker (6.2.1), Zigbee2MQTT (1.32.1-1), Terminal & SSH (9.7.1), Studio Code Server (5.8.1), Duck DNS (1.15.0), NGINX Home Assistant SSL proxy (3.5.0), Node-RED (14.3.0), InfluxDB (4.7.0)
dashboards 1
resources 4
views 1
oldest_recorder_run 2 juillet 2023 à 00:42
current_recorder_run 10 juillet 2023 à 07:56
estimated_db_size 54.05 MiB
database_version 3.41.2
Personne n’a de voie à m’apporter ?
As-tu regardé en détails les infos HA et notamment les logs HA (tu as déjà posté ceux de influxdb, et il n’y a rien d’anormal) ?
Accessoirement, regarde bien la fin du tuto, notament la partie include/exclude… Si tu n’as rien indiqué, à HA, normal que rien ne remonte
Effectivement, je n’ai rien indiqué :slight_smile:
Je me suis arrêté ici :
Vérifier le fonctionnement de InfluxDB.
Une fois redémarré, allez sur InfluxDB, puis sur Explore, s’il y a des sensors dans votre Home Assistant, vous devriez voir apparaître plusieurs unités de mesure après avoir cliqué sur votre base de données créée auparavant. Si vous n’avez pas de sensor créés, reportez vous à l’article suivant.
Je vais modifier mon fichier Configuration.yaml en ajoutant un capteur.
Toujours pas de capteur, mais j’ai une erreur 401 dans les logs de HA :
Texte préformaté2023-07-10 15:10:27.702 ERROR (SyncWorker_2) [homeassistant.components.influxdb] InfluxDB database is not accessible due to ‹ 401: {« error »:« authorization failed »} ›. Please check that the database, username and password are correct and that the specified user has the correct permissions set. Retrying in 60 seconds.Texte préformaté
Donc tu as toutes les infos pour corriger
Je pense que ça vient de mon fichier de configuration avec un pointeur vers le nom de la base de données erroné.
Bon, pas mieux pour l’instant, je vais reprendre le tuto depuis le début en essayant d’aller jusqu’au bout
Attention également, la mise à jour dans influxdb se passe UNIQUEMENT quand les entités changent de valeur
J’ai toujours une erreur 401… Ca vient donc de moi et pas du capteur…
Bonsoir,
Même problème que @anon41081891, installation en suivant le tutoriel mais pas de sensor remonté.
Je suis moi aussi preneur d’une piste…
Ma configuration (NAS Synology et VM):
Config
Journal de l’installation et du démarrage:
 Add-on: InfluxDB
 System: Home Assistant OS 10.3  (amd64 / qemux86-64)
 Home Assistant Core: 2023.7.3
[18:04:45] INFO: Configuring timezone (Europe/Lisbon)...
[18:04:47] INFO: Kapacitor is waiting until InfluxDB is available...
[18:04:47] INFO: Chronograf is waiting until InfluxDB is available...
[18:04:47] INFO: Starting the InfluxDB...
[18:05:03] INFO: Starting the Kapacitor
[18:05:03] INFO: Starting Chronograf...
2023/07/31 18:05:03 Using configuration at: /etc/kapacitor/kapacitor.conf
time="2023-07-31T18:05:11+01:00" level=info msg="Reporting usage stats" component=usage freq=24h reporting_addr="https://usage.influxdata.com" stats="os,arch,version,cluster_id,uptime"
time="2023-07-31T18:05:11+01:00" level=info msg="Serving chronograf at http://127.0.0.1:8889" component=server
[18:05:11] INFO: Starting NGINX...
time="2023-07-31T18:05:27+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46212" response_time="311.35µs" status=200
time="2023-07-31T18:05:27+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46214" response_time="142.532µs" status=200
time="2023-07-31T18:05:27+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46222" response_time="284.933µs" status=200
time="2023-07-31T18:05:28+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46234" response_time=4.622796ms status=200
time="2023-07-31T18:05:28+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46246" response_time=2.065161ms status=200
time="2023-07-31T18:05:28+01:00" level=info msg="Response: No Content" component=server method=GET remote_addr="127.0.0.1:46248" response_time="953.987µs" status=204
time="2023-07-31T18:05:28+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:46250" response_time="308.292µs" status=200
time="2023-07-31T18:05:28+01:00" level=info msg="Response: OK" component=server method=POST remote_addr="127.0.0.1:46266" response_time=1.806663ms status=200
time="2023-07-31T18:05:28+01:00" level=info msg="Response: OK" component=server method=POST remote_addr="127.0.0.1:46268" response_time=1.635552ms status=200
time="2023-07-31T18:05:38+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:57360" response_time="79.504µs" status=200
Essayes de mettre l’ip du serveur (host :192.168.1.X) dans la conf influxdb dans configuration.yaml.
Bonsoir @betux
Merci, problème résolu, petite erreur de syntaxe…
