Depuis deux jours, je n’arrive plus à voir le flux de mes caméras sur mon dashboard.
J’ai essayé plusieurs paramètres et reconfiguration de la Frigate ou des Modules et toujours le même résultat, mème avec une restauration du système antérieur.
Tout fonctionait bien auparavant.
Es esperant que vous pouvez maider ce serais aimable de fournir un peut de votre temps.
go2rtc:
webrtc:
listen: ":8555"
streams:
camera1:
- rtsp://admin:admin@192.168.50.144:8554/profile0
camera1_sub:
- rtsp://admin:admin@192.168.50.144:8554/profile1
camera2:
- rtsp://admin:admin@192.168.50.137:8554/profile0
camera3:
- rtsp://admin:admin@192.168.50.194:8554/profile0
camera4:
- rtsp://admin:admin@192.168.50.114/channel=0_stream=0.sdp
log:
level: info
api: trace
exec: debug
ngrok: info
rtsp: warn
streams: error
webrtc: fatal
ngrok:
command: ngrok tcp 8555 --authtoken 2haEJ6Zp45ZNwLzwETkGKEKI3K9_3sDdRDfQtFjZTzEpN6fwq
Frigate:
host: 192.168.50.132
port: 1883
topic_prefix: frigate
client_id: frigate
user: mqttuser
password: mqttuser
stats_interval: 300
detectors:
coral:
type: edgetpu
device: usb
audio:
enabled: true
max_not_heard: 30
min_volume: 500
listen:
- bark
- fire_alarm
- scream
- speech
- yell
filters:
speech:
threshold: 0.8
logger:
default: info
logs:
frigate.event: debug
birdseye:
enabled: true
restream: true
width: 640
height: 320
quality: 8
mode: continuous
inactivity_threshold: 30
layout:
scaling_factor: 2.0
max_cameras: 4
ffmpeg:
global_args: -hide_banner -loglevel warning -threads 2
hwaccel_args: []
input_args: preset-rtsp-generic
output_args:
detect: -threads 2 -f rawvideo -pix_fmt yuv420p
record: preset-record-generic-audio-aac
retry_interval: 10
objects:
track:
- person
- car
- cat
mask: []
filters:
cat:
min_area: 5000
max_area: 100000
min_ratio: 0.5
max_ratio: 2.0
min_score: 0.5
threshold: 0.7
mask: []
car:
min_area: 5000
max_area: 100000
min_ratio: 0.5
max_ratio: 2.0
min_score: 0.5
threshold: 0.6
mask: []
motion:
threshold: 100
lightning_threshold: 0.8
contour_area: 50
frame_alpha: 0.01
frame_height: 100
mask: []
improve_contrast: true
mqtt_off_delay: 100
record:
enabled: true
expire_interval: 60
sync_recordings: true
retain:
days: 5
mode: motion
export:
timelapse_args: -vf setpts=0.04*PTS -r 30
events:
pre_capture: 5
post_capture: 5
objects:
- person
- car
- cat
retain:
default: 10
mode: motion
objects:
person: 10
car: 5
cat: 5
snapshots:
enabled: true
clean_copy: true
timestamp: false
bounding_box: true
crop: false
height: 175
retain:
default: 10
objects:
person: 15
quality: 70
go2rtc:
streams:
camera1: rtsp://admin:admin@192.168.50.144:8554/profile0
camera1_sub:
- ffmpeg:camera1_sub#audio=aac
camera2: rtsp://admin:admin@192.168.50.137:8554/profile0
camera2_sub:
- rtsp://admin:admin@192.168.50.137:8554/profile1
- ffmpeg:camera2_sub#audio=aac
camera3: rtsp://admin:admin@192.168.50.194:8554/profile0
camera3_sub:
- ffmpeg:camera3_sub#audio=aac
camera4: rtsp://admin:admin@192.168.50.114/channel=0_stream=0.sdp
camera4_sub: rtsp://admin:admin@192.168.50.114/channel=1_stream=1.sdp
cameras:
camera1:
enabled: true
ffmpeg:
inputs:
- path: rtsp://admin:admin@192.168.50.144:8554/profile0
roles:
- record
- path: rtsp://admin:admin@192.168.50.144:8554/profile1
roles:
- detect
- audio
detect:
width: 1220
height: 720
fps: 10
enabled: false
min_initialized: 1
max_disappeared: 25
object tracking.
annotation_offset: 0
motion:
threshold: 37
contour_area: 28
improve_contrast: 'true'
zones:
zone1:
coordinates: 0.001,0.007,0,1,1,1,1,0
loitering_time: 0
review:
alerts:
required_zones: zone1
detections:
Camera2:
enabled: true
ffmpeg:
inputs:
- path: rtsp://admin:admin@192.168.50.137:8554/profile0
roles:
- record
- path: rtsp://admin:admin@192.168.50.137:8554/profile1
input_args: preset-rtsp-restream
roles:
- detect
- audio
detect:
width: 640
height: 320
fps: 5
enabled: true
min_initialized: 2
max_disappeared: 25
stationary:
interval: 50
threshold: 50
max_frames:
default: 3000
objects:
cat: 1000
car: 15000
motion:
threshold: 55
contour_area: 36
mask:
0.034,0.329,0.062,0.482,0.165,0.457,0.267,0.436,0.275,0.302,0.385,0.28,0.537,0.267,0.565,0.359,0.712,0.357,0.749,0.439,0.77,0.427,0.785,0.362,0.922,0.243,0.821,0.233,0.701,0.229,0.564,0.244,0.452,0.24,0.347,0.265,0.251,0.277
review:
alerts:
objects:
filters:
car: {}
mask:
0.032,0.479,0.186,0.474,0.377,0.428,0.544,0.389,0.68,0.351,0.838,0.324,0.946,0.258,0.993,0.291,0.997,0.454,0.979,0.513,0.879,0.562,0.725,0.629,0.588,0.685,0.435,0.698,0.251,0.773,0.133,0.766,0.013,0.766
zones:
zone1:
coordinates: 0,1,0,0.275,1,0.212,1,1
loitering_time: 0
Camera3:
enabled: true
ffmpeg:
inputs:
- path: rtsp://admin:admin123456@192.168.50.194:8554/profile0
roles:
- record
- path: rtsp://admin:admin123456@192.168.50.194:8554/profile1
roles:
- detect
- audio
detect:
width: 640
height: 320
fps: 5
enabled: false
min_initialized: 2
max_disappeared: 25
motion:
threshold: 39
contour_area: 24
zones:
zone1:
coordinates: 0,0,0,1,1,1,1,0
loitering_time: 0
Camera4:
enabled: true
ffmpeg:
inputs:
- path: rtsp://admin:admin@192.168.50.114/channel=1_stream=1.sdp
roles:
- record
- path: rtsp://admin:admin@192.168.50.114/channel=0_stream=0.sdp
roles:
- detect
- audio
detect:
width: 640
height: 320
fps: 5
enabled: false
min_initialized: 2
max_disappeared: 25
best_image_timeout: 60
mqtt:
enabled: true
timestamp: true
bounding_box: true
crop: true
height: 270
quality: 70
ui:
order: 0
dashboard: true
birdseye:
order: 0
restream: true
motion:
threshold: 44
contour_area: 38
telemetry:
network_interfaces:
- eth
- enp
- eno
- ens
- wl
- lo
stats:
amd_gpu_stats: true
intel_gpu_stats: true
network_bandwidth: false
version_check: true
version: 0.14
camera_groups:
one:
order: 1
icon: LuWebcam
cameras:
- birdseye
- Camera1
- Camera2
- Camera3
- Camera4
Configuration.yaml:
default_config:
frontend:
script: !include scripts.yaml
scene: !include scenes.yaml
################# DUCK DNS #################
http:
################# NGINX #################
use_x_forwarded_for: true
trusted_proxies:
- 172.30.33.0/24
################# IP BAN #################
ip_ban_enabled: false
login_attempts_threshold: 5
################# stream #################
stream:
camera:
- platform: ffmpeg
input: rtsp://admin:admin@192.168.50.144:8554/profile0
- platform: ffmpeg
input: rtsp://admin:admin@192.168.50.137:8554/profile0
- platform: ffmpeg
input: rtsp://admin:admin@192.168.50.194:8554/profile0
- platform: ffmpeg
input: rtsp://admin:admin@192.168.50.114/channel=0_stream=0.sdp
################# Card Frigate #################
lovelace:
resources:
- url: /hacsfiles/frigate-hass-card/frigate-hass-card.js
type: module
################# ALARM #################
alarm_control_panel:
- platform: manual
code: !secret alarmCode
arming_time: 15
delay_time: 20
trigger_time: 4
disarmed:
trigger_time: 0
armed_home:
arming_time: 0
delay_time: 0
################# BOT Telegram #################
telegram_bot:
- platform: polling
api_key: 7454498413:AAECVw1O4c06oWM4lZ0Q-mI_bOV2dUYJRIM
allowed_chat_ids:
- 899677294
################# Notifier Telegram #################
notify:
- platform: telegram
chat_id: 899677294
################# Proxmox Sensor #################
sensors:
proxmox_cpu_temp:
friendly_name: "Procesor"
value_template: '{{ states("input_number.proxmox_input_cpu_temp") | multiply(0.001) | round(1) }}'
unit_of_measurement: °C
sensors:
proxmox_acpi_interface:
friendly_name: "ACPI vmesnik"
value_template: '{{ states("input_number.proxmox_input_acpi_interface") | multiply(0.001) | round(1) }}'
sensors:
proxmox_isa_adapter:
friendly_name: "ISA adapter"
value_template: '{{ states("input_number.proxmox_input_isa_adapter") | multiply(0.001) | round(1) }}'
input_number:
proxmox_input_cpu_temp:
min: 0
max: 200000
proxmox_input_acpi_interface:
min: 0
max: 200000
proxmox_input_isa_adapter:
min: 0
max: 200000
Vous trouverez ci join la configuration de frigate card
type: custom:frigate-card
cameras:
- hide: false
triggers:
motion: false
- image.camera1_person
go2rtc:
modes:
- mse
- webrtc
- mp4
- mjpeg
webrtc_card:
entity: camera.camera1
camera_entity: camera.camera1_profile_000
live_provider: jsmpeg
view:
default: live
camera_select: live
dark_mode: 'on'
update_force: false
update_cycle_camera: false
scan:
enabled: false
show_trigger_status: true
untrigger_reset: true
menu:
buttons:
recordings:
enabled: true
image:
enabled: true
download:
enabled: true
expand:
enabled: true
microphone:
enabled: true
priority: 50
play:
enabled: true
mute:
enabled: true
screenshot:
enabled: true
priority: 49
live:
microphone:
always_connected: true
controls:
timeline:
style: ribbon
layout:
fit: fill
preload: true
auto_unmute: selected
performance:
style:
border_radius: true
box_shadow: true
profile: high
Log Go2rtc
23:51:53.835 TRC [api] GET /api/config 172.30.32.2:42714
23:51:54.779 TRC [api] GET /api/config 172.30.32.2:42714
23:51:54.795 TRC [api] POST /api/config 172.30.32.2:42714
23:51:55.845 TRC [api] POST /api/restart 172.30.32.2:42714
23:51:55.845 DBG [api] restart /usr/local/bin/go2rtc
23:51:55.853 INF go2rtc platform=linux/amd64 revision=a4885c2 version=1.9.4
23:51:55.854 INF config path=/config/go2rtc.yaml
23:51:55.854 TRC [api] register path path=/
23:51:55.854 TRC [api] register path path=/api
23:51:55.854 TRC [api] register path path=/api/config
23:51:55.854 TRC [api] register path path=/api/exit
23:51:55.854 TRC [api] register path path=/api/restart
23:51:55.854 TRC [api] register path path=/api/log
23:51:55.854 TRC [api] register path path=/api/ws
23:51:55.854 TRC [api] register path path=/api/streams
23:51:55.854 TRC [api] register path path=/api/streams.dot
23:51:55.854 INF [api] listen addr=:1984
23:51:55.854 TRC [api] register path path=/api/webrtc
23:51:55.854 TRC [api] register path path=/api/frame.mp4
23:51:55.854 TRC [api] register path path=/api/stream.mp4
23:51:55.854 TRC [api] register path path=/api/stream.m3u8
23:51:55.854 TRC [api] register path path=/api/hls/playlist.m3u8
23:51:55.854 TRC [api] register path path=/api/hls/segment.ts
23:51:55.854 TRC [api] register path path=/api/hls/init.mp4
23:51:55.854 TRC [api] register path path=/api/hls/segment.m4s
23:51:55.854 TRC [api] register path path=/api/frame.jpeg
23:51:55.854 TRC [api] register path path=/api/stream.mjpeg
23:51:55.854 TRC [api] register path path=/api/stream.ascii
23:51:55.854 TRC [api] register path path=/api/stream.y4m
23:51:55.854 TRC [api] register path path=/static
23:51:55.855 TRC [api] register path path=/streams
23:51:55.855 TRC [api] register path path=/stream/
23:51:55.855 TRC [api] register path path=/api/hass
23:51:55.855 TRC [api] register path path=/onvif/
23:51:55.855 TRC [api] register path path=/api/onvif
23:51:55.855 TRC [api] register path path=/api/webtorrent
23:51:55.855 TRC [api] register path path=/api/stream.flv
23:51:55.855 TRC [api] register path path=/api/ffmpeg
23:51:55.855 TRC [api] register path path=/api/ffmpeg/devices
23:51:55.855 TRC [api] register path path=/api/ffmpeg/hardware
23:51:55.855 TRC [api] register path path=/api/dvrip
23:51:55.855 TRC [api] register path path=/api/stream.ts
23:51:55.855 TRC [api] register path path=/api/stream.aac
23:51:55.855 TRC [api] register path path=/api/roborock
23:51:55.855 TRC [api] register path path=/api/homekit
23:51:55.855 TRC [api] register path path=/api/nest
23:51:55.855 TRC [api] register path path=/api/gopro
23:51:55.856 TRC [api] register path path=/api/stack
23:51:56.702 INF [ngrok] add external candidate for WebRTC addr=3.13.191.225:18852
23:54:11.200 TRC [api] GET /log.html 172.30.32.2:56004
23:54:11.221 TRC [api] GET /main.js 172.30.32.2:56004
23:54:11.236 TRC [api] GET /api/log 172.30.32.2:56004
23:54:16.252 TRC [api] GET /api/log 172.30.32.2:56004
23:54:20.863 TRC [api] GET /api/ws?src=camera1 [::1]:57596
23:54:21.077 TRC [api] ws msg type=webrtc/offer
23:54:21.077 TRC [api] ws msg type=mse
23:54:21.083 TRC [api] ws msg type=webrtc/candidate
23:54:21.085 TRC [api] ws msg type=webrtc/candidate
23:54:21.301 TRC [api] ws msg type=webrtc/candidate
23:54:21.402 TRC [api] ws msg type=webrtc/candidate
23:54:27.164 TRC github.com/AlexxIT/go2rtc/internal/api/ws/ws.go:124 > error="websocket: close 1000 (normal)"
23:54:27.765 TRC [api] GET /api/ws?src=camera1 127.0.0.1:47066
23:54:27.896 TRC [api] ws msg type=webrtc/offer
23:54:27.896 TRC [api] ws msg type=mse
23:54:27.929 TRC [api] ws msg type=webrtc/candidate
23:54:28.032 TRC [api] ws msg type=webrtc/candidate
23:54:28.033 TRC [api] ws msg type=webrtc/candidate
23:54:28.287 TRC [api] ws msg type=webrtc/candidate
23:54:31.160 TRC github.com/AlexxIT/go2rtc/internal/api/ws/ws.go:124 > error="websocket: close 1000 (normal)"
23:54:31.673 TRC [api] GET /api/ws?src=camera1 [::1]:37542
23:54:31.803 TRC [api] ws msg type=webrtc/offer
23:54:31.807 TRC [api] ws msg type=mse
23:54:32.313 TRC [api] ws msg type=webrtc/candidate
23:54:32.332 TRC [api] ws msg type=webrtc/candidate
23:54:36.759 TRC [api] GET / 172.30.32.2:38720
23:54:36.866 TRC [api] GET /main.js 172.30.32.2:38720
23:54:36.983 TRC [api] GET /api 172.30.32.2:38720
23:54:36.984 TRC [api] GET /api/streams 172.30.32.2:45804
23:54:38.035 TRC [api] GET /api/streams 172.30.32.2:45804
23:54:39.074 TRC [api] GET /api/streams 172.30.32.2:45804
23:54:39.802 TRC [api] GET /log.html 172.30.32.2:45804
23:54:39.910 TRC [api] GET /main.js 172.30.32.2:45804
23:54:40.021 TRC [api] GET /api/log 172.30.32.2:45804
23:54:45.130 TRC [api] GET /api/log 172.30.32.2:45804
23:54:50.133 TRC [api] GET /api/log 172.30.32.2:45804
23:54:55.034 TRC [api] GET /api/log 172.30.32.2:45804
23:55:00.058 TRC [api] GET /api/log 172.30.32.2:45804
23:55:05.073 TRC [api] GET /api/log 172.30.32.2:45804
23:55:10.070 TRC [api] GET /api/log 172.30.32.2:45804
23:55:15.081 TRC [api] GET /api/log 172.30.32.2:45804
23:55:16.436 TRC [api] GET /streams [::1]:41444
23:55:16.437 TRC [api] POST /stream/camera.birdseye/add [::1]:41444
23:55:16.438 TRC [api] POST /stream/camera.birdseye/channel/0/webrtc [::1]:41444
23:55:18.642 TRC [api] GET /api 172.30.32.2:45804
23:55:18.643 TRC [api] GET /api/streams 172.30.32.2:42660
23:55:19.685 TRC [api] GET /api/streams 172.30.32.2:42660
23:55:20.729 TRC [api] GET /api/streams 172.30.32.2:42660
23:55:21.672 TRC [api] GET /api/streams 172.30.32.2:42660
23:55:22.711 TRC [api] GET /api/streams 172.30.32.2:42660
Log Frigate
s6-rc: info: service s6rc-fdholder: starting
s6-rc: info: service s6rc-fdholder successfully started
s6-rc: info: service log-prepare: starting
s6-rc: info: service log-prepare successfully started
s6-rc: info: service nginx-log: starting
s6-rc: info: service go2rtc-log: starting
s6-rc: info: service frigate-log: starting
s6-rc: info: service certsync-log: starting
s6-rc: info: service nginx-log successfully started
s6-rc: info: service go2rtc-log successfully started
s6-rc: info: service go2rtc: starting
s6-rc: info: service frigate-log successfully started
s6-rc: info: service certsync-log successfully started
s6-rc: info: service go2rtc successfully started
s6-rc: info: service go2rtc-healthcheck: starting
s6-rc: info: service frigate: starting
s6-rc: info: service go2rtc-healthcheck successfully started
s6-rc: info: service frigate successfully started
s6-rc: info: service nginx: starting
2024-08-06 04:03:19.487238490 [INFO] Preparing Frigate...
2024-08-06 04:03:19.502240437 [INFO] Starting NGINX...
2024-08-06 04:03:19.515056936 [INFO] No TLS certificate found. Generating a self signed certificate...
2024-08-06 04:03:19.571769042 [INFO] Starting Frigate...
2024-08-06 04:03:19.571893573 [INFO] Preparing new go2rtc config...
2024-08-06 04:03:19.629004029 [INFO] Got IP address from supervisor: 192.168.50.132
2024-08-06 04:03:19.657966237 [INFO] Got WebRTC port from supervisor: 8555
2024-08-06 04:03:20.194732504 [INFO] Starting go2rtc...
2024-08-06 04:03:20.311105932 00:03:20.311 INF go2rtc platform=linux/amd64 revision=b2399f3 version=1.9.2
2024-08-06 04:03:20.311231194 00:03:20.311 INF config path=/dev/shm/go2rtc.yaml
2024-08-06 04:03:20.311528896 00:03:20.311 INF [rtsp] listen addr=:8554
2024-08-06 04:03:20.311671343 00:03:20.311 INF [api] listen addr=:1984
2024-08-06 04:03:20.311739807 00:03:20.311 INF [webrtc] listen addr=:8555/tcp
s6-rc: info: service nginx successfully started
s6-rc: info: service certsync: starting
2024-08-06 04:03:21.028965569 [INFO] Starting certsync...
s6-rc: info: service certsync successfully started
2024-08-06 04:03:21.151783651 127.0.0.1 - - [06/Aug/2024:00:03:21 -0400] "" 400 0 "-" "-" "-"
2024-08-06 04:03:21.759910955 [2024-08-06 00:03:21] frigate.app INFO : Starting Frigate (0.14.0-7c39b17)
2024-08-06 04:03:21.760004227 [2024-08-06 00:03:21] frigate.app INFO : Creating directory: /tmp/cache
2024-08-06 04:03:21.760393539 [2024-08-06 00:03:21] frigate.util.config INFO : Checking if frigate config needs migration...
2024-08-06 04:03:21.828148467 [2024-08-06 00:03:21] frigate.util.config INFO : frigate config does not need migration...
2024-08-06 04:03:21.918659204 [2024-08-06 00:03:21] peewee_migrate.logs INFO : Starting migrations
2024-08-06 04:03:21.919265160 [2024-08-06 00:03:21] peewee_migrate.logs INFO : There is nothing to migrate
2024-08-06 04:03:21.924785528 2024/08/06 00:03:21 [error] 171#171: *2 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.1, server: , request: "GET /api/stats HTTP/1.1", subrequest: "/auth", upstream: "http://127.0.0.1:5001/auth", host: "ccab4aaf-frigate-fa-beta:5000"
2024-08-06 04:03:21.924790222 2024/08/06 00:03:21 [error] 171#171: *2 auth request unexpected status: 502 while sending to client, client: 172.30.32.1, server: , request: "GET /api/stats HTTP/1.1", host: "ccab4aaf-frigate-fa-beta:5000"
2024-08-06 04:03:21.962124086 [2024-08-06 00:03:21] frigate.app INFO : Recording process started: 314
2024-08-06 04:03:21.965760142 [2024-08-06 00:03:21] frigate.app INFO : Recording process started: 316
2024-08-06 04:03:21.967888763 [2024-08-06 00:03:21] frigate.app INFO : go2rtc process pid: 102
2024-08-06 04:03:22.009277576 [2024-08-06 00:03:22] frigate.app INFO : Output process started: 345
2024-08-06 04:03:22.021161069 [2024-08-06 00:03:22] detector.coral INFO : Starting detection process: 343
2024-08-06 04:03:22.021360846 [2024-08-06 00:03:22] frigate.detectors.plugins.edgetpu_tfl INFO : Attempting to load TPU as usb
2024-08-06 04:03:22.420961251 [2024-08-06 00:03:22] frigate.app INFO : Camera processor started for Camera1: 389
2024-08-06 04:03:22.428438400 [2024-08-06 00:03:22] frigate.app INFO : Camera processor started for Camera2: 390
2024-08-06 04:03:22.429356762 [2024-08-06 00:03:22] frigate.app INFO : Camera processor started for Camera3: 391
2024-08-06 04:03:22.437319993 [2024-08-06 00:03:22] frigate.app INFO : Camera processor started for Camera4: 400
2024-08-06 04:03:22.442517003 [2024-08-06 00:03:22] frigate.app INFO : Capture process started for Camera1: 417
2024-08-06 04:03:22.447525400 [2024-08-06 00:03:22] frigate.app INFO : Capture process started for Camera2: 424
2024-08-06 04:03:22.461072134 [2024-08-06 00:03:22] frigate.app INFO : Capture process started for Camera3: 428
2024-08-06 04:03:22.467226491 [2024-08-06 00:03:22] frigate.app INFO : Capture process started for Camera4: 430
2024-08-06 04:03:22.467229925 [2024-08-06 00:03:22] frigate.app INFO : Audio process started: 439
2024-08-06 04:03:23.225882070 [2024-08-06 00:03:23] frigate.record.util INFO : Deleting 26769 recording DB entries with missing files
2024-08-06 04:03:23.230651738 [2024-08-06 00:03:23] frigate.record.util WARNING : Deleting 0.885863% of recordings DB entries, could be due to configuration error. Aborting...
2024-08-06 04:03:29.491952834 [INFO] Starting go2rtc healthcheck service...
2024-08-06 04:03:30.032036556 [2024-08-06 00:03:30] frigate.detectors.plugins.edgetpu_tfl INFO : TPU found
2024-08-06 04:03:44.858596253 127.0.0.1 - - [06/Aug/2024:00:03:44 -0400] "POST /api/events/Camera4/speech/create HTTP/1.1" 200 95 "-" "python-requests/2.32.3" "-"
Log Mosquitto
cont-init: info: running /etc/cont-init.d/mosquitto.sh
[00:01:58] INFO: Certificates found: SSL is available
cont-init: info: /etc/cont-init.d/mosquitto.sh exited 0
cont-init: info: running /etc/cont-init.d/nginx.sh
cont-init: info: /etc/cont-init.d/nginx.sh exited 0
services-up: info: copying legacy longrun mosquitto (no readiness notification)
services-up: info: copying legacy longrun nginx (no readiness notification)
[00:01:58] INFO: Starting NGINX for authentication handling...
[00:01:59] INFO: Starting mosquitto MQTT broker...
2024-08-06 00:01:59: Warning: Mosquitto should not be run as root/administrator.
2024-08-06 00:01:59: mosquitto version 2.0.18 starting
2024-08-06 00:01:59: Config loaded from /etc/mosquitto/mosquitto.conf.
2024-08-06 00:01:59: Loading plugin: /usr/share/mosquitto/go-auth.so
2024-08-06 00:01:59: ├── Username/password checking enabled.
2024-08-06 00:01:59: ├── TLS-PSK checking enabled.
2024-08-06 00:01:59: └── Extended authentication not enabled.
2024-08-06 00:01:59: Opening ipv4 listen socket on port 1883.
2024-08-06 00:01:59: Opening ipv6 listen socket on port 1883.
2024-08-06 00:01:59: Opening websockets listen socket on port 1884.
2024-08-06 00:01:59: Opening ipv4 listen socket on port 8883.
2024-08-06 00:01:59: Opening ipv6 listen socket on port 8883.
2024-08-06 00:01:59: Opening websockets listen socket on port 8884.
2024-08-06 00:01:59: mosquitto version 2.0.18 running
2024-08-06 00:01:59: New connection from ::1:39772 on port 1883.
2024-08-06 00:01:59: Client <unknown> disconnected due to protocol error.
[00:02:00] INFO: Successfully send discovery information to Home Assistant.
[00:02:00] INFO: Successfully send service information to the Supervisor.
2024-08-06 00:02:42: New connection from 192.168.50.132:33715 on port 1883.
2024-08-06 00:02:42: New client connected from 192.168.50.132:33715 as 7scnocmsCalwjicjQiRfdh (p2, c1, k60, u'mqttuser').
2024-08-06 00:02:53: New connection from 172.30.32.1:42502 on port 1883.
2024-08-06 00:02:53: New client connected from 172.30.32.1:42502 as mqttjs_9498c7a5 (p2, c1, k60, u'addons').
2024-08-06 00:03:21: New connection from 172.30.32.1:36484 on port 1883.
2024-08-06 00:03:21: New client connected from 172.30.32.1:36484 as frigate (p2, c1, k60, u'mqttuser').
2024-08-06 00:05:20: New connection from 172.30.32.2:58694 on port 1883.
2024-08-06 00:05:20: Client <unknown> closed its connection.
[center]## System Information
| version |
core-2024.8.0b3 |
| installation_type |
Home Assistant OS |
| dev |
false |
| hassio |
true |
| docker |
true |
| user |
root |
| virtualenv |
false |
| python_version |
3.12.4 |
| os_name |
Linux |
| os_version |
6.6.33-haos |
| arch |
x86_64 |
| timezone |
America/Caracas |
| config_dir |
/config |
| GitHub API |
ok |
| GitHub Content |
ok |
| GitHub Web |
ok |
4994 |
| Installed Version |
1.34.0 |
| Stage |
running |
| Available Repositories |
1459 |
| Downloaded Repositories |
24 |
| HACS Data |
ok |
| logged_in |
false |
| can_reach_cert_server |
ok |
| can_reach_cloud_auth |
ok |
| can_reach_cloud |
ok |
| host_os |
Home Assistant OS 12.4 |
| update_channel |
beta |
| supervisor_version |
supervisor-2024.08.0 |
| agent_version |
1.6.0 |
| docker_version |
26.1.4 |
| disk_total |
30.8 GB |
| disk_used |
26.5 GB |
| healthy |
true |
| supported |
true |
| host_connectivity |
true |
| supervisor_connectivity |
true |
| ntp_synchronized |
true |
| virtualization |
kvm |
| board |
ova |
| supervisor_api |
ok |
| version_api |
ok |
| installed_addons |
Samba share (12.3.2), Advanced SSH & Web Terminal (18.0.0), AirCast (4.2.1), Studio Code Server (5.15.0), go2rtc (1.9.4), Terminal & SSH (9.14.0), eWeLink Smart Home (1.4.3), Node-RED (18.0.4), VLC (0.3.0), ZeroTier One (0.18.0), Assist Microphone (1.2.0), Samba Backup (5.2.0), Duck DNS (1.18.0), Nginx Proxy Manager (1.0.1), NGINX Home Assistant SSL proxy (3.9.0), PS5 MQTT (1.3.3), MariaDB (2.7.1), Google Assistant SDK (2.5.0), phpMyAdmin (0.9.1), Home Assistant Google Drive Backup (0.112.1), Mosquitto broker (6.4.1), Frigate (Full Access) Beta (0.14.0-rc1) |
| dashboards |
5 |
| resources |
16 |
| views |
25 |
| mode |
storage |
| oldest_recorder_run |
26 juillet 2024 à 23:41 |
| current_recorder_run |
5 août 2024 à 23:23 |
| estimated_db_size |
341.98 MiB |
| database_engine |
sqlite |
| database_version |
3.45.3 |
Sonoff
| version |
3.7.3 (e240aaf) |
| cloud_online |
7 / 8 |
| local_online |
7 / 7 |
