Problème de lancement de influxdb
System Health
version 2021.1.5
python_version 3.8.7
os_version 5.4.79-v8
Github API Calls Remaining 4983
Installed Version 1.10.1
Available Repositories 709
Installed Repositories 1
Hass.io
host_os Home Assistant OS 5.10
supervisor_version 2021.01.7
docker_version 19.03.13
disk_total 28.6 GB
disk_used 9.3 GB
board rpi3-64
installed_addons Samba share (9.3.0), File editor (5.2.0), SSH & Web Terminal (7.8.0), Duck DNS (1.12.4), NGINX Home Assistant SSL proxy (3.0.1), Mosquitto broker (5.1), InfluxDB (4.0.1), motionEye (0.11.0)
Lovelace
dashboards 2
views 5
resources 0
Raspberry Pi 3 avec la derniere version en cours de HA
Je n’arrive plus à démarrer mon adodon influxdb car j’ai un message :
failed to starrt addon
404 Client Error for http+docker://localhost/v1.40/containers/create?name=addon_a0d7b954_influxdb: Not Found (« No such image: Package influxdb/aarch64 · GitHub »)
j’ai jetté un oeil à l’esapce disque au ca ou .. et j’ai ca :
Filesystem Size Used Available Use% Mounted on
overlay 28.6G 9.3G 17.8G 34% /
tmpfs 64.0M 0 64.0M 0% /dev
tmpfs 456.3M 0 456.3M 0% /sys/fs/cgroup
shm 64.0M 72.0K 63.9M 0% /dev/shm
/dev/root 98.5M 98.5M 0 100% /sbin/docker-init
/dev/mmcblk0p8 28.6G 9.3G 17.8G 34% /ssl
/dev/mmcblk0p8 28.6G 9.3G 17.8G 34% /backup
/dev/mmcblk0p8 28.6G 9.3G 17.8G 34% /share
/dev/mmcblk0p8 28.6G 9.3G 17.8G 34% /media
/dev/mmcblk0p8 28.6G 9.3G 17.8G 34% /addons
/dev/mmcblk0p8 28.6G 9.3G 17.8G 34% /data
/dev/mmcblk0p8 28.6G 9.3G 17.8G 34% /config
/dev/mmcblk0p8 28.6G 9.3G 17.8G 34% /run/audio
tmpfs 182.5M 1.1M 181.4M 1% /run/dbus
/dev/mmcblk0p8 28.6G 9.3G 17.8G 34% /etc/asound.conf
/dev/mmcblk0p8 28.6G 9.3G 17.8G 34% /etc/hostname
/dev/mmcblk0p8 28.6G 9.3G 17.8G 34% /etc/resolv.conf
/dev/mmcblk0p8 28.6G 9.3G 17.8G 34% /etc/hosts
/dev/mmcblk0p8 28.6G 9.3G 17.8G 34% /etc/pulse/client.conf
tmpfs 456.3M 0 456.3M 0% /proc/asound
tmpfs 64.0M 0 64.0M 0% /proc/keys
tmpfs 64.0M 0 64.0M 0% /proc/latency_stats
tmpfs 64.0M 0 64.0M 0% /proc/timer_list
tmpfs 64.0M 0 64.0M 0% /proc/sched_debug
tmpfs 456.3M 0 456.3M 0% /sys/firmware
J’imagine que c’est pas tres bon mais j’ai pas fait attention comment c’était avant …
J’ai récemment ajouté l’integration " Zigbee Home Automation" mais je ne sais pas si c’est lié .
Quelqu’un ayant un pi3 avec une image de base de ha installé peux me dire ce qu’il a pour un df -h ?
Merci d’avance , je cherche mon pb sur le net sans succes pour l’instant
Essaies peut être de faire une sauvegarde (snapshot) et de refaire une installation et de la restaurer…
En effet c’est ce que j’ai fait finalement .
Merci.
Ca a réglé le soucis ?
Oui tout à fait, de nouveau fonctionnel !
