Suite au passage de HA 2.4.6 à la version 2.5.2, j’ai une erreur de Scheduler.
Mon installation date un peu mais avait toujours été fonctionnelle:
HACS Interface:
Intégration:
Le message :
Les Logs:
Logger: homeassistant.setup
Source: setup.py:214
First occurred: 14:16:14 (1 occurrences)
Last logged: 14:16:14
Setup failed for custom integration scheduler: Unable to import component: cannot import name 'async_get_registry' from 'homeassistant.helpers.entity_registry' (/usr/src/homeassistant/homeassistant/helpers/entity_registry.py)
Ce n’est plus la période pour chauffer mais j’aimerai bien solutionner le problème, avez-vous rencontré ce souci ?
Merci d’avance
BoB
Configuration:
| version | core-2023.5.2 |
| dev | false |
| hassio | true |
| docker | true |
| user | root |
| virtualenv | false |
| python_version | 3.10.11 |
| os_name | Linux |
| os_version | 6.1.21-v8 |
| arch | aarch64 |
| timezone | Europe/Paris |
| config_dir | /config |
| GitHub API | ok |
| GitHub Content | ok |
| GitHub Web | ok |
| GitHub API Calls Remaining | 4854 |
| Installed Version | 1.32.1 |
| Stage | running |
| Available Repositories | 1287 |
| Downloaded Repositories | 23 |
| logged_in | false |
| can_reach_cloud_auth | ok |
| can_reach_cloud | ok |
| host_os | Home Assistant OS 10.1 |
| update_channel | stable |
| supervisor_version | supervisor-2023.04.1 |
| agent_version | 1.5.1 |
| docker_version | 23.0.3 |
| disk_total | 457.7 GB |
| disk_used | 30.5 GB |
| healthy | true |
| supported | true |
| board | rpi4-64 |
| supervisor_api | ok |
| version_api | ok |
| installed_addons | deCONZ (6.19.0), Let’s Encrypt (4.12.8), File editor (5.6.0), Samba share (10.0.1), Network UPS Tools (0.11.2), Spotify Connect (0.12.3), Terminal & SSH (9.7.0), Portainer (2.0.0), InfluxDB (4.6.0), Grafana (8.2.2), Node-RED (14.1.5), ESPHome (2023.4.4), Studio Code Server (5.5.7) |
| dashboards | 2 |
| resources | 15 |
| views | 13 |
| mode | storage |
| oldest_recorder_run | 2 mai 2023 à 08:05 |
| current_recorder_run | 8 mai 2023 à 14:15 |
| estimated_db_size | 222.38 MiB |
| database_engine | sqlite |
| database_version | 3.40.1 |
Spotify
| api_endpoint_reachable | ok |
