QuF
Avril 21, 2025, 7:49
1
je débute avec Zigbee et je voudrais installer le dongle SLZB-07p10 sur ma box HA Green.
J’ai donc installé Mosquitto broker, Zigbee2MQTT. J’ai flashé le dongle avec le dernier firmware.
Mais je n’arrive pas à l’installer…
J’ai bien vérifié que ZHA n’était pas actif.
Ma config Z2M
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: false
mqtt: {}
serial:
port: >-
/dev/serial/by-id/usb-SMLIGHT_SMLIGHT_SLZB-07p10_5c05e51df78aef11bb4d2accef8776e9-if00-port0
adapter: ember
baudrate: 115200
les erreurs dans le journal :
[21:40:48] INFO: Preparing to start...
[21:40:48] INFO: Socat not enabled
[21:40:49] INFO: Starting Zigbee2MQTT...
[2025-04-21 21:40:54] info: z2m: Logging to console, file (filename: log.log)
[2025-04-21 21:40:54] info: z2m: Starting Zigbee2MQTT version 2.2.1 (commit #unknown)
[2025-04-21 21:40:54] info: z2m: Starting zigbee-herdsman (3.4.11)
[2025-04-21 21:40:55] info: zh:ember: Using default stack config.
[2025-04-21 21:40:55] info: zh:ember: ======== Ember Adapter Starting ========
[2025-04-21 21:40:55] info: zh:ember:ezsp: ======== EZSP starting ========
[2025-04-21 21:40:55] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-04-21 21:40:55] info: zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
[2025-04-21 21:40:55] info: zh:ember:uart:ash: Serial port opened
[2025-04-21 21:40:55] info: zh:ember:uart:ash: ======== ASH starting ========
[2025-04-21 21:40:57] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-04-21 21:40:57] info: zh:ember:uart:ash: ======== ASH starting ========
[2025-04-21 21:41:00] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-04-21 21:41:00] info: zh:ember:uart:ash: ======== ASH starting ========
[2025-04-21 21:41:02] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-04-21 21:41:02] info: zh:ember:uart:ash: ======== ASH starting ========
[2025-04-21 21:41:05] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-04-21 21:41:05] info: zh:ember:uart:ash: ======== ASH starting ========
[2025-04-21 21:41:07] error: z2m: Error while starting zigbee-herdsman
[2025-04-21 21:41:07] error: z2m: Failed to start zigbee-herdsman
[2025-04-21 21:41:07] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-04-21 21:41:07] error: z2m: Exiting...
[2025-04-21 21:41:07] error: z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
at EmberAdapter.initEzsp (/app/node_modules/.pnpm/zigbee-herdsman@3.4.11/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:672:19)
at EmberAdapter.start (/app/node_modules/.pnpm/zigbee-herdsman@3.4.11/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1538:24)
at Controller.start (/app/node_modules/.pnpm/zigbee-herdsman@3.4.11/node_modules/zigbee-herdsman/src/controller/controller.ts:136:29)
at Zigbee.start (/app/lib/zigbee.ts:69:27)
at Controller.start (/app/lib/controller.ts:104:13)
at start (/app/index.js:149:5)
Je passe du temps à chercher, mais je n’ai aucune piste.
[center]## System Information
version
core-2025.4.2
installation_type
Home Assistant OS
dev
false
hassio
true
docker
true
user
root
virtualenv
false
python_version
3.13.2
os_name
Linux
os_version
6.12.23-haos
arch
aarch64
timezone
Europe/Paris
config_dir
/config
GitHub API
ok
GitHub Content
ok
GitHub Web
ok
HACS Data
ok
GitHub API Calls Remaining
5000
Installed Version
2.0.5
Stage
running
Available Repositories
1664
Downloaded Repositories
5
logged_in
false
can_reach_cert_server
ok
can_reach_cloud_auth
ok
can_reach_cloud
ok
host_os
Home Assistant OS 15.2
update_channel
stable
supervisor_version
supervisor-2025.04.0
agent_version
1.7.2
docker_version
28.0.4
disk_total
28.0 GB
disk_used
8.5 GB
healthy
true
supported
true
host_connectivity
true
supervisor_connectivity
true
ntp_synchronized
true
virtualization
board
green
supervisor_api
ok
version_api
ok
installed_addons
Linky (1.5.0), File editor (5.8.0), Get HACS (1.3.1), MariaDB (2.7.2), Nginx Proxy Manager (1.0.1), Matter Server (7.0.0), Terminal & SSH (9.16.0), Zigbee2MQTT (2.2.1-1), Mosquitto broker (6.5.0)
dashboards
6
resources
1
views
11
mode
storage
Network Configuration
adapters
lo (disabled), end0 (enabled, default, auto), hassio (disabled), docker0 (disabled), veth16a1337 (disabled), veth422872a (disabled), vethb8ae4e3 (disabled), veth3d74aeb (disabled), veth5f7c215 (disabled), veth2cd4bd3 (disabled), vethb443348 (disabled), vethf8494e3 (disabled), vethd06e63d (disabled), vethe61ee68 (disabled), vethcb99426 (disabled)
ipv4_addresses
lo (127.0.0.1/8), end0 (10.0.0.2/24), hassio (172.30.32.1/23), docker0 (172.30.232.1/23), veth16a1337 (), veth422872a (), vethb8ae4e3 (), veth3d74aeb (), veth5f7c215 (), veth2cd4bd3 (), vethb443348 (), vethf8494e3 (), vethd06e63d (), vethe61ee68 (), vethcb99426 ()
ipv6_addresses
lo (::1/128), end0 (fe80::bf08:96b8:9bc8:8a1b/64), hassio (fe80::6412:a1ff:fedf:ed6a/64), docker0 (fe80::3064:8cff:fe2c:f2cd/64), veth16a1337 (fe80::6874:fdff:fee1:c68a/64), veth422872a (fe80::f4eb:c4ff:fe29:2c7e/64), vethb8ae4e3 (fe80::2067:efff:fedd:1c8a/64), veth3d74aeb (fe80::e41b:7aff:feb0:851c/64), veth5f7c215 (fe80::4474:7aff:fe98:fbfc/64), veth2cd4bd3 (fe80::68f5:c6ff:feac:ddf8/64), vethb443348 (fe80::309f:b6ff:fe42:a11d/64), vethf8494e3 (fe80::4c90:e5ff:fe45:3002/64), vethd06e63d (fe80::288c:74ff:fe69:5110/64), vethe61ee68 (fe80::e487:7aff:fe08:3e52/64), vethcb99426 (fe80::4ccc:e4ff:fef9:4627/64)
announce_addresses
10.0.0.2, fe80::bf08:96b8:9bc8:8a1b
oldest_recorder_run
3 avril 2025 à 07:39
current_recorder_run
18 avril 2025 à 16:11
estimated_db_size
292.38 MiB
database_engine
sqlite
database_version
3.48.0
Sonoff
version
3.8.2 (c4b6fda)
cloud_online
0 / 1
local_online
0 / 0
[/center]
Tu es sur que zha est bien ignoré ?
C’est l’erreur lorsque le dongle est accaparé par zha
Ne pas oulier de rebooter complètement après avoir ignore zha
Vérifies bien que zha n’est pas dans la liste des intégrations en attente de paramétrage si c’est le cas il faut ignorer puis rebooter
QuF
Avril 21, 2025, 8:09
3
Dans « appareils et services », j’ai l’intégration ZHA qui est bien dans les intégrations ignorées. Tu as une autre manip’ à me conseiller pour vérifier?
Tu as bien connecté ton dongle avec un câble USB pour éviter les perturbation ?
Tente de débrancher a chaud ton dongle puis rebranche le démarre z2m
Par contre ce dongle utilise une puce cc2674 qui n’est pas une puce silicon labs mais une Texas instruments tu devrait choisir un driver zstack et pas ember
QuF
Avril 21, 2025, 8:38
6
merci @ddfdom c’est bien l’adapter qui était mal configuré. J’étais persuadé que c’était un adapter ember.
system
A fermé ce sujet ()
Avril 23, 2025, 8:38
7
