Bonjour a tous, J’ai HAOS sur une Vm suite a la mise a jour j’ai mon intégration fusion solar plus qui refuse de ce charger avec ce message d’erreur dans les logs :
‹ « Setup failed for custom integration ‹ fusionsolarplus ›: Requirements for fusionsolarplus not found: [‹ fusion-solar-py ›, ‹ gradio_client ›]. » ›
‹ * Unable to install package fusion-solar-py: error: Request failed after 3 retries in 9.6s Caused by: Failed to fetch: https://wheels.home-assistant.io/musllinux-index/fusion-solar-py/ Caused by: error sending request for url (https://wheels.home-assistant.io/musllinux-index/fusion-solar-py/) Caused by: client error (Connect) Caused by: Connection reset by peer (os error 104) ›
‹ * Unable to install package fusion-solar-py: error: Request failed after 3 retries in 10.6s Caused by: Failed to fetch: https://wheels.home-assistant.io/musllinux-index/fusion-solar-py/ Caused by: error sending request for url (https://wheels.home-assistant.io/musllinux-index/fusion-solar-py/) Caused by: client error (Connect) Caused by: Connection reset by peer (os error 104) ›
‹ * Unable to install package gradio_client: error: Request failed after 3 retries in 11.3s Caused by: Failed to fetch: https://wheels.home-assistant.io/musllinux-index/gradio-client/ Caused by: error sending request for url (https://wheels.home-assistant.io/musllinux-index/gradio-client/) Caused by: client error (Connect) Caused by: Connection reset by peer (os error 104) ›
‹ * Unable to install package gradio_client: error: Request failed after 3 retries in 9.4s Caused by: Failed to fetch: https://wheels.home-assistant.io/musllinux-index/gradio-client/ Caused by: error sending request for url (https://wheels.home-assistant.io/musllinux-index/gradio-client/) Caused by: client error (Connect) Caused by: Connection reset by peer (os error 104) ›
‹ * Unable to install package gradio_client: error: Request failed after 3 retries in 7.4s Caused by: Failed to fetch: https://wheels.home-assistant.io/musllinux-index/gradio-client/ Caused by: error sending request for url (https://wheels.home-assistant.io/musllinux-index/gradio-client/) Caused by: client error (Connect) Caused by: Connection reset by peer (os error 104) ›
Même en essayant d’intaller manuellement la biblio python cela échoue!
Revenir en arriere sur les mise a jour de HA ne résout pas le problème alors que tout était fonctionnel!
Autant dire que c’est au mieux inefficace, au pire ça casse encore plus les choses. L’objectif de HAOS c’est de ne pas bidouiller dans l’administration dudit OS.
L’idée c’est de retrouver l’intégration fusion solar plus que tu utilises (j’ai l’impression qu’il y en a plusieurs) vérifier si c’est maintenu, si c’est à jour, s’il n’y a pas des changements à faire
La version « fusion solar » utilise le mode api elle est beaucoup plus précise mais quand je l’ai installé je me suis retouvé avec tout les installation de mon installateur donc environ 1000 centrales… et impossible de trouver la mienne pour l’isoler correctement.
Le truc vraiment étrange ce que j’ai essayé de l’installé sur une autre maison qui a un Haos sur un rpi4 et pas de soucis tout est fonctionnel!
Je précise que les 2 Haos sont mis a jour avec la même version.
J’en conclue que c’est mon réseau qui est le point bloquant?!
PS: Pour ma culture le lien Home Assistant Wheels c’est toute les bibliothéques python utilisable?
ça contient des WSDL : un format de description des api justement. Sauf que toi (comme moi) n’arrivons pas à récupérer ce qui est indiqué dans la logs. Donc 2 solutions :
souci d’accès
n’existe plus
Le souci d’accès c’est pas possible , ton autre installation n’a pas de souci et pour ma part je n’ai pas non plus cette intégration.
Si ça n’existait plus, ça ne marcherai pas non plus sur ton autre installation.
Donc il n’y a qu’une seule conclusion possible. L’erreur est chez toi uniquement :
soit un mélange de plusieurs fichiers/cache dans ton installation
soit un erreur dans la config
Le fait que tu trouves plein d’autres centrales (en dehors du fait que c’est pas rassurant) tends à confirmer ça aussi.
Essaye de tout désinstaller, redémarrer, et réinstaller.
Personnellement je suis convaincu que c’est pas la mise à jour le souci, c’est juste le révélateur (restart = effacement des caches)
Petite précision:
C’est l’integration que je n’utilise pas qui voit tout plein de centrale et pour ça je pense a une mauvaise config du mode api par mon installateur.
J’ai déja tenté de désinstaller redemarrer réinstaller, sans changement sur le message d’erreur de l’integration.
Ce qui me chagrine lors de cette phase c’est que Ha a gardé toutes les infos sur mon installation solaire… J’ai pas l’impression que la désinstallation soit au top.
Ou je rate quelque chose! (c’est fort probable aussi)
