Bonjours à tous, j’ai créer une entitée pour suivre ma consommation électrique journalière, mais l’entitée ne ce réinitialise pas à 00h chaque jour…
Configuration :
utility_meter:
energie_quotidienne:
source: sensor.index
cycle: daily
energie_mensuelle:
cycle: monthly
consommation_hourly:
cycle: hourly
energie_annuelle:
cycle: yearly
Sensor :
sensors:
energie_horaire_kwh:
friendly_name: "energie_horaire_kwh"
unit_of_measurement: 'kWh'
value_template: "{{(states('sensor.energie_horaire') | int / 1000) }}"
energie_journaliere_kwh:
friendly_name: "energie_journaliere_kwh"
value_template: "{{(states('sensor.energie_journaliere') | int / 1000) }}"
energie_mensuelle_kwh:
friendly_name: "energie_mensuelle_kwh"
value_template: "{{(states('sensor.energie_mensuelle') | int / 1000) }}"
energie_annuelle_kwh:
friendly_name: "energie_annuelle_kwh"
value_template: "{{(states('sensor.energie_annuelle') | int / 1000) }}"
Le tutoriel d’origine
System Health
| version |
core-2021.12.8 |
| installation_type |
Home Assistant OS |
| dev |
false |
| hassio |
true |
| docker |
true |
| user |
root |
| virtualenv |
false |
| python_version |
3.9.7 |
| os_name |
Linux |
| os_version |
5.10.63-v8 |
| arch |
aarch64 |
| timezone |
Europe/Paris |
| GitHub API |
ok |
| Github API Calls Remaining |
4565 |
| Installed Version |
1.18.0 |
| Stage |
running |
| Available Repositories |
933 |
| Installed Repositories |
23 |
| logged_in |
false |
| can_reach_cert_server |
ok |
| can_reach_cloud_auth |
ok |
| can_reach_cloud |
failed to load: timeout |
| host_os |
Home Assistant OS 7.1 |
| update_channel |
stable |
| supervisor_version |
supervisor-2021.12.2 |
| docker_version |
20.10.9 |
| disk_total |
111.1 GB |
| disk_used |
6.4 GB |
| healthy |
true |
| supported |
true |
| board |
rpi4-64 |
| supervisor_api |
ok |
| version_api |
ok |
| installed_addons |
Duck DNS (1.14.0), File editor (5.3.3), RPC Shutdown (2.2), Samba share (9.5.1), ESPHome (2021.12.3), Home Assistant Google Drive Backup (0.105.2), Terminal & SSH (9.3.0), Glances (0.14.1), ZeroTier One (0.12.1) |
Lovelace
| dashboards |
1 |
| resources |
15 |
| views |
5 |
| mode |
storage |
Bonjours à tous, je suis le seul à avoir ce problème ?
