Probleme integration template
J ai cette erreur
# Home Assistant Core
2024-10-30 18:45:55.126 WARNING (MainThread) [homeassistant.helpers.translation] Failed to load integration for translation: Integration 'window' not found.
2024-10-30 18:46:02.903 ERROR (MainThread) [homeassistant.setup] Setup failed for 'window': Integration not found.
sur l’intégration d’un template dont voici le contenu
  sensors:
    open_fenetres:
      friendly_name: toutes les fenetres
      device_class: window
      value_template: >
        {{ is_state('binary_sensor.capteur_fenetre_g_cuisine_contact', 'Ouvert')
          or is_state('binary_sensor.capteur_fenetre_chambre_parentale_b', 'Ouvert')
          or is_state('binary_sensor.door_window_sensor_window_door_is_open_11', 'Ouvert')
          or is_state('binary_sensor.door_window_sensor_window_door_is_open_bureau', 'Ouvert')
          or is_state('binary_sensor.capteur_fenetre_salle_a_manger_b', 'Ouvert')
          or is_state('binary_sensor.capteur_fenetre_salle_eau', 'Ouvert')
          or is_state('binary_sensor.capteur_fenetre_salle_de_bain_salle_de_bain_b', 'Ouvert')
          or is_state('binary_sensor.capteur_fenetre_palier', 'Ouvert')
          or is_state('binary_sensor.capteur_fenetre_cuisine_droite_contact', 'Ouvert')
          or is_state('binary_sensor.capteur_fenetre_salon', 'Ouvert')
Pouvez vous m’aider?
Marc
[center]## System Information
version core-2024.10.4
python_version 3.12.4
os_version 6.6.31-haos-raspi
Installed Version 2.0.1
Available Repositories 1457
Downloaded Repositories 9
logged_in true
subscription_expiration 1 janvier 2018 à 01:00
relayer_connected false
relayer_region null
remote_enabled false
remote_connected false
alexa_enabled true
google_enabled true
remote_server null
certificate_status null
instance_id 922112ff862e406c9e9d77e9a3abefa8
supervisor_version supervisor-2024.10.3
agent_version 1.6.0
docker_version 27.2.0
disk_total 28.3 GB
disk_used 14.3 GB
virtualization
board rpi4-64
installed_addons Z-Wave JS (0.8.1), Advanced SSH & Web Terminal (19.0.0), Studio Code Server (5.17.2), Zigbee2MQTT (1.40.2-1), Samba share (12.3.2), go2rtc (1.9.6), openWakeWord (1.10.0), Whisper (2.2.0), Piper (1.5.2), Node-RED (18.1.1)
dashboards 5
resources 4
views 18
oldest_recorder_run 22 octobre 2024 à 10:26
current_recorder_run 30 octobre 2024 à 18:45
estimated_db_size 504.18 MiB
database_version 3.45.3
[/center]
Première question tu veux faire quoi en fait ?
Et pense à mettre en forme ton code yaml la c’est illisible
Mets tous tes capteurs dans un groupe tu t’emmerderas moins.
C’est bien ce que je pensais aussi
ok je vais commencer a faire ca
Je voudrais avoir un retour d’état de tous mes ouvrants et voir rapidement que tout est fermé
Comme l’a dit @Tochy c’est d’un groupe de capteur que tu as besoin tout simplement
c est ce que je viens de faire mais je ne vois pas comment recupérer un état de tous les capteurs
Tu le veux dans quoi ?
Le dashboard ?
Comment ça un état de tous les capteurs ?
Quand tu fait un groupe de binary par exemple
  • le groupe sera a on si au moins un des binary est on
  • ou le groupe sera on si tous les binary sont a on
ceci en fonction de l’option tous les capteurs dans les paramètres du groupe.
Bonjour @Marco91390,
utilise la balise texte préformaté quand tu colles du code/log dans un message pour une meilleur visibilité.
Icône image.
J’ai modifié ton sujet.
Ah! ok , je n’avais pas connaissance de cette option
Merci beaucoup
Oui dans le dashboard, ca je sais faire . merci pour ton aide
