depuis cette mise a jour ma config ModBus est signalé avec des problèmes de syntaxe. Alors que je n’ai rien changé et que le guide HA dit toujours la même chose. Quelqu’un a t-il un problème identique?
mon système
version |
core-2024.4.2 |
installation_type |
Home Assistant OS |
dev |
false |
hassio |
true |
docker |
true |
user |
root |
virtualenv |
false |
python_version |
3.12.2 |
os_name |
Linux |
os_version |
6.6.20-haos |
arch |
aarch64 |
timezone |
Europe/Paris |
config_dir |
/config |
GitHub API |
ok |
GitHub Content |
ok |
GitHub Web |
ok |
GitHub API Calls Remaining |
4998 |
Installed Version |
1.34.0 |
Stage |
running |
Available Repositories |
1467 |
Downloaded Repositories |
14 |
HACS Data |
ok |
logged_in |
false |
can_reach_cert_server |
ok |
can_reach_cloud_auth |
ok |
can_reach_cloud |
ok |
host_os |
Home Assistant OS 12.1 |
update_channel |
stable |
supervisor_version |
supervisor-2024.04.0 |
agent_version |
1.6.0 |
docker_version |
24.0.7 |
disk_total |
114.1 GB |
disk_used |
47.3 GB |
healthy |
true |
supported |
true |
board |
odroid-n2 |
supervisor_api |
ok |
version_api |
ok |
installed_addons |
ESPHome (2024.3.2), MariaDB (2.6.1), Samba share (12.3.1), File editor (5.8.0), AirSonos (4.2.1), Z-Wave JS (0.4.5), VLC (0.3.0), Tor (5.0.0), Advanced SSH & Web Terminal (17.2.0), Log Viewer (0.17.0), motionEye (0.20.0), Let’s Encrypt (5.0.15), Node-RED (17.0.11), Samba Backup (5.2.0), Studio Code Server (5.15.0), Duck DNS (1.16.0) |
dashboards |
14 |
resources |
5 |
views |
15 |
mode |
storage |
oldest_recorder_run |
1 avril 2024 à 16:45 |
current_recorder_run |
9 avril 2024 à 16:35 |
estimated_db_size |
368.16 MiB |
database_engine |
sqlite |
database_version |
3.44.2 |
Euh tu as vu cette note dans le changelog ?
The Modbus integration does not allow a configuration with the device only (no entities); this will create an issue, and the entry will not be loaded.
For the special cases (like some custom_components) where it is wanted, please add a dummy entity.
Bah voilà je n’ai pas tout lu visiblement. Mea culpa. Par contre je ne comprends pas trop ce que cela veux dire.
