Bonjour tous le monde,
Depuis deux jours un petit problème me taraude. Le module d’identification double facteur se désactive. Bien peur d’une faille dans mon système.
Là sur l’image c’est activé bien sur:
Suis sur DUCK DNS en https. Une idée? Merki et Bonne journée!!
| version |
core-2023.9.2 |
| installation_type |
Home Assistant OS |
| dev |
false |
| hassio |
true |
| docker |
true |
| user |
root |
| virtualenv |
false |
| python_version |
3.11.5 |
| os_name |
Linux |
| os_version |
6.1.21-v8 |
| arch |
aarch64 |
| timezone |
Europe/Paris |
| config_dir |
/config |
| GitHub API |
ok |
| GitHub Content |
ok |
| GitHub Web |
ok |
5000 |
| Installed Version |
1.32.1 |
| Stage |
running |
| Available Repositories |
1297 |
| Downloaded Repositories |
20 |
| logged_in |
false |
| can_reach_cert_server |
ok |
| can_reach_cloud_auth |
ok |
| can_reach_cloud |
ok |
| host_os |
Home Assistant OS 10.5 |
| update_channel |
stable |
| supervisor_version |
supervisor-2023.09.2 |
| agent_version |
1.5.1 |
| docker_version |
23.0.6 |
| disk_total |
28.5 GB |
| disk_used |
4.9 GB |
| healthy |
true |
| supported |
true |
| board |
rpi3-64 |
| supervisor_api |
ok |
| version_api |
ok |
| installed_addons |
Terminal & SSH (9.7.1), Duck DNS (1.15.0), File editor (5.6.0), Let’s Encrypt (4.12.9), ESPHome (2023.8.3) |
| dashboards |
6 |
| resources |
10 |
| views |
18 |
| mode |
storage |
| oldest_recorder_run |
11 septembre 2023 à 06:44 |
| current_recorder_run |
20 septembre 2023 à 21:39 |
| estimated_db_size |
50.22 MiB |
| database_engine |
sqlite |
| database_version |
3.41.2 |
Spotify
| api_endpoint_reachable |
ok |
