Logger: aiohttp.server
Source: components/zha/config_flow.py:410
First occurred: 22:14:14 (1 occurrences)
Last logged: 22:14:14
Error handling request
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 435, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 94, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 82, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 236, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 136, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 180, in post
return await super().post(request, flow_id)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 73, in wrapper
result = await method(view, request, data, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 110, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 276, in async_configure
result = await self._async_handle_step(
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 367, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/components/zha/config_flow.py", line 410, in async_step_form_new_network
await app.form_network()
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 217, in form_network
await self.backups.restore_backup(
File "/usr/local/lib/python3.10/site-packages/zigpy/backups.py", line 156, in restore_backup
await self.app.write_network_info(
File "/usr/local/lib/python3.10/site-packages/zigpy_zigate/zigbee/application.py", line 127, in write_network_info
await self.reset_network_info()
File "/usr/local/lib/python3.10/site-packages/zigpy_zigate/zigbee/application.py", line 122, in reset_network_info
await self._api.erase_persistent_data()
File "/usr/local/lib/python3.10/site-packages/zigpy_zigate/api.py", line 419, in erase_persistent_data
await self.command(CommandId.ERASE_PERSISTENT_DATA, wait_status=False, wait_response=ResponseId.PDM_LOADED, timeout=10)
File "/usr/local/lib/python3.10/site-packages/zigpy_zigate/api.py", line 378, in command
raise NoResponseError()
zigpy_zigate.api.NoResponseError
Il y a 2 infos intéressantes quand même :
L’info sur le pan_id et le read_parameter.
On dirait qu’une partie de la configuration n’est pas bonne. Ça donne quoi les informations de la pizigate dans la doc officielle ?
C’est pas récent mais il semble y avoir un certain nombre de pré-requis
Source: components/zha/config_flow.py:167
First occurred: 07:50:55 (1 occurrences)
Last logged: 07:50:55
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 280, in async_configure
File "/usr/src/homeassistant/homeassistant/components/zha/config_flow.py", line 265, in async_step_choose_serial_port
return await self.async_step_choose_formation_strategy()
File "/usr/src/homeassistant/homeassistant/components/zha/config_flow.py", line 373, in async_step_choose_formation_strategy
await self._async_load_network_settings()
File "/usr/src/homeassistant/homeassistant/components/zha/config_flow.py", line 354, in _async_load_network_settings
async with self._connect_zigpy_app() as app:
File "/usr/local/lib/python3.10/contextlib.py", line 199, in __aenter__
return await anext(self.gen)
File "/usr/src/homeassistant/homeassistant/components/zha/config_flow.py", line 167, in _connect_zigpy_app
await app.connect()
File "/usr/local/lib/python3.10/site-packages/zigpy_zigate/zigbee/application.py", line 44, in connect
(_, version), lqi = await api.version()
ValueError: too many values to unpack (expected 2)
Config_flow.py :
Logger: zigpy_deconz.api
Source: components/zha/config_flow.py:193
First occurred: 07:50:51 (1 occurrences)
Last logged: 07:50:51
No response to 'Command.read_parameter' command with seq id '0x02'
Je suis entrain de regarder, mais tout est bon comme dans la doc, je pense à des fichiers résiduels qui casseraient tout…
Tu as des conflits entre les applications et les addons. L’accès pizigate est exclusif donc le premier qui fonctionne, bloque les autres. Je ne sais pas ce qui tourne encore hors HA mais ZHA et Z2M en même temps c’est pas possible sauf à bien désactiver l’un ou l’autre
