| version | core-2025.7.1 |
| dev | false |
| hassio | true |
| docker | true |
| container_arch | amd64 |
| user | root |
| virtualenv | false |
| python_version | 3.13.3 |
| os_name | Linux |
| os_version | 6.12.35-haos |
| arch | x86_64 |
| timezone | Europe/Paris |
| config_dir | /config |
| GitHub API | ok |
| GitHub Content | ok |
| GitHub Web | ok |
| HACS Data | ok |
| Installed Version | 2.0.5 |
| Stage | running |
| Available Repositories | 2110 |
| Downloaded Repositories | 7 |
| logged_in | false |
| can_reach_cloud_auth | ok |
| can_reach_cloud | ok |
| host_os | Home Assistant OS 16.0 |
| update_channel | stable |
| supervisor_version | supervisor-2025.07.1 |
| agent_version | 1.7.2 |
| docker_version | 28.3.0 |
| disk_total | 62.3 GB |
| disk_used | 42.3 GB |
| healthy | true |
| supported | true |
| host_connectivity | true |
| supervisor_connectivity | true |
| ntp_synchronized | true |
| virtualization | kvm |
| board | ova |
| supervisor_api | ok |
| version_api | ok |
| installed_addons | Silicon Labs Multiprotocol (2.4.5), Matter Server (8.0.0), Mosquitto broker (6.5.1), Zigbee2MQTT (2.5.1-1), File editor (5.8.0), Terminal & SSH (9.18.0), Samba Backup (5.2.0), ZeroTier One (0.22.0), Hoymiles DTU Solar: Home Assistant Add-on (0.9.8), HoyMiles Solar Gateway stable Addon (1.4.4), Studio Code Server (5.19.3), Frigate (0.15.2), Samba share (12.5.2) |
| dashboards | 5 |
| resources | 4 |
| views | 7 |
| mode | storage |
Network Configuration
| adapters | lo (disabled), enp0s3 (enabled, default, auto), docker0 (disabled), hassio (disabled), ztosikwvhz (disabled), veth4a5407f (disabled), veth994850b (disabled), veth0774200 (disabled), vethe134d90 (disabled), veth1187c25 (disabled), vethce35478 (disabled), veth050a40a (disabled), wpan0 (disabled) |
| ipv4_addresses | lo (127.0.0.1/8), enp0s3 (192.168.1.82/24), docker0 (172.30.232.1/23), hassio (172.30.32.1/23), ztosikwvhz (192.168.192.119/24), veth4a5407f (), veth994850b (), veth0774200 (), vethe134d90 (), veth1187c25 (), vethce35478 (), veth050a40a (), wpan0 () |
| ipv6_addresses | lo (::1/128), enp0s3 (2a02:842a:7600:d201:9477:1986:4eaa:93d5/64, fe80::185c:64a:5425:d7da/64), docker0 (fe80::60ae:26ff:fed3:fc91/64), hassio (fe80::89f:6eff:fefe:5a2d/64), ztosikwvhz (fe80::bc2e:cff:fe30:a4db/64), veth4a5407f (fe80::1801:a8ff:feae:5c2c/64), veth994850b (fe80::b86c:7dff:fed0:3889/64), veth0774200 (fe80::b86a:aeff:fe1a:7915/64), vethe134d90 (fe80::9891:8fff:fe14:b9f/64), veth1187c25 (fe80::3ccb:55ff:feb0:6ddc/64), vethce35478 (fe80::9cd8:39ff:fefa:d4c9/64), veth050a40a (fe80::44b2:41ff:fe7c:2def/64), wpan0 (fdc0:2d11:8604:1:acd4:ef57:7b3f:e765/64, fd81:c4a7:4b3a:4e1e:0:ff:fe00:fc10/64, fd81:c4a7:4b3a:4e1e:0:ff:fe00:fc38/64, fd81:c4a7:4b3a:4e1e:0:ff:fe00:fc00/64, fd81:c4a7:4b3a:4e1e:0:ff:fe00:7800/64, fd81:c4a7:4b3a:4e1e:693c:1878:485d:29a6/64, fe80::f088:d10e:22a9:4a9d/64) |
| announce_addresses | 192.168.1.82, 2a02:842a:7600:d201:9477:1986:4eaa:93d5, fe80::185c:64a:5425:d7da |
| oldest_recorder_run | 4 juillet 2025 à 22:39 |
| current_recorder_run | 9 juillet 2025 à 18:06 |
| estimated_db_size | 408.47 MiB |
| database_engine | sqlite |
| database_version | 3.48.0 |
Je ne parviens pas utiliser « Ajouter un stockage réseau » pour ajouter un partage créé sur mon NAS.
que ce soit en SAMBA :
ou en NFS :
J’ai cette erreur ?
Si je comprends bien il me dit d’aller voir les logs sur mon NAS mais je ne sais pas ou les trouver si c’est ça ?
De mon PC je vois bien et je peux écrire sur le partage.
J’ai même essayé de monter le disque via Terminal & SSH
mais j’ai aussi une erreur ?
un problème d’autorisation ?
Merci d’avance à la communauté.
