## System Information
version | core-2023.10.0
dev | false
hassio | true
docker | true
user | root
virtualenv | false
python_version | 3.11.5
os_name | Linux
os_version | 6.1.45
arch | aarch64
timezone | Europe/Paris
config_dir | /config
GitHub API | ok
GitHub Content | ok
GitHub Web | ok
Installed Version | 1.33.0
Stage | running
Available Repositories | 1301
Downloaded Repositories | 43
</details>
logged_in | true
subscription_expiration | 12 juillet 2024 à 02:00
relayer_connected | true
relayer_region | eu-central-1
remote_enabled | true
remote_connected | true
alexa_enabled | true
google_enabled | true
remote_server | eu-central-1-7.ui.nabu.casa
certificate_status | ready
can_reach_cert_server | ok
can_reach_cloud_auth | ok
can_reach_cloud | ok
</details>
host_os | Home Assistant OS 10.5
update_channel | stable
supervisor_version | supervisor-2023.10.0
agent_version | 1.5.1
docker_version | 23.0.6
disk_total | 110.0 GB
disk_used | 18.5 GB
healthy | true
supported | true
board | khadas-vim3
supervisor_api | ok
version_api | ok
installed_addons | File editor (5.6.0), Samba share (10.0.2), Zigbee2MQTT (1.33.1-1), Mosquitto broker (6.3.1), Advanced SSH & Web Terminal (15.0.8), InfluxDB (4.7.0), Grafana (9.0.3), Linky (1.1.0), Studio Code Server (5.11.0)
</details>
dashboards | 2
resources | 31
views | 15
mode | storage
</details>
oldest_recorder_run | 28 août 2023 à 13:55
current_recorder_run | 6 octobre 2023 à 12:36
estimated_db_size | 6331.09 MiB
database_engine | sqlite
database_version | 3.41.2
</details>
<details><summary>Spotify</summary>
api_endpoint_reachable | ok
</details>
Avant de faire la mise à jour 10 (mais j’avais 2 mises à jour en attente en 9) je n’avais pas de soucis et depuis j’ai des erreurs dont sur mon « sensors.yaml »
Invalid config for [sensor]: required key not provided @ data['platform']. Got None. (See /config/sensors.yaml, line 2). Please check the docs at https://www.home-assistant.io/integrations/sensor
# moniteur système
- platform: systemmonitor
resources:
- type: disk_use_percent
arg: /config
- type: disk_use
- type: disk_free
- type: memory_use_percent
- type: memory_use
- type: memory_free
- type: swap_use_percent
- type: swap_use
- type: swap_free
- type: load_1m
- type: load_5m
- type: load_15m
- type: network_in
arg: eth0
- type: network_out
arg: eth0
- type: throughput_network_in
arg: eth0
- type: throughput_network_out
arg: eth0
- type: packets_in
arg: eth0
- type: packets_out
arg: eth0
- type: ipv4_address
arg: eth0
- type: ipv6_address
arg: eth0
- type: processor_use
- type: processor_temperature
- type: last_boot
#### Recup températeur du thermostat ####
sensors:
temperature:
friendly_name: "Température chambre bébé"
unit_of_measurement: '°C'
value_template: "{{ state_attr('climate.thermostat_chambre_bebe', 'current_temperature') }}"
J’ai vu que déjà j’aurais du avoir avant un « template: !include templates.yaml » avec un fichier « templates.yaml » pour température chambre bébé" que j’ai fait maintenant mais je n’ai toujours pas le sensor qui apparait.
Pouvez-vous m’orienter, je ne suis pas vieux sur Ha ?
Merci d’avance,
Bonne journée,
