Probleme zigee2mqtt depuis MAJ
bonjour,
plus de zigbee2mqtt depuis les MAJ de ce soir. ci dessous les logs, config et matos, qu’en dites vous ?
[21:05:35] INFO: Preparing to start...
[21:05:35] INFO: Socat not enabled
[21:05:36] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info  2024-02-09 21:05:39: Logging to console and directory: '/config/zigbee2mqtt/log/2024-02-09.21-05-39' filename: log.txt
Zigbee2MQTT:info  2024-02-09 21:05:39: Starting Zigbee2MQTT version 1.35.3 (commit #unknown)
Zigbee2MQTT:info  2024-02-09 21:05:39: Starting zigbee-herdsman (0.33.8)
Zigbee2MQTT:error 2024-02-09 21:05:44: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2024-02-09 21:05:44: Failed to start zigbee
Zigbee2MQTT:error 2024-02-09 21:05:44: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2024-02-09 21:05:44: Exiting...
Zigbee2MQTT:error 2024-02-09 21:05:45: Error: failed to connect to zigate adapter [object Object] after 5000ms
    at ZiGateAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/zigate/adapter/zigateAdapter.ts:101:19)
    at runNextTicks (node:internal/process/task_queues:60:5)
    at listOnTimeout (node:internal/timers:538:9)
    at processTimers (node:internal/timers:512:7)
    at Zigbee.start (/app/lib/zigbee.ts:60:27)
    at Controller.start (/app/lib/controller.ts:109:27)
    at start (/app/index.js:107:5)
tts usb1
Sous-système:
tty
Chemin d’accès au périphérique:
/dev/ttyUSB1
ID:
/dev/serial/by-id/usb-Silicon_Labs_ZiGate_0001-if00-port0
Attributs:
DEVLINKS: >-
  /dev/serial/by-path/pci-0000:01:1b.0-usb-0:4:1.0-port0
DEVNAME: /dev/ttyUSB1
DEVPATH: >-
  /devices/pci0000:00/0000:00:1e.0/0000:01:1b.0/usb2/2-4/2-4:1.0/ttyUSB1/tty/ttyUSB1
ID_BUS: usb
ID_MODEL: ZiGate
ID_MODEL_ENC: ZiGate
ID_MODEL_ID: ea60
ID_PATH: pci-0000:01:1b.0-usb-0:4:1.0
ID_PATH_TAG: pci-0000_01_1b_0-usb-0_4_1_0
ID_REVISION: '0100'
ID_SERIAL: Silicon_Labs_ZiGate_0001
ID_SERIAL_SHORT: '0001'
ID_TYPE: generic
ID_USB_DRIVER: cp210x
ID_USB_INTERFACES: ':ff0000:'
ID_USB_INTERFACE_NUM: '00'
ID_USB_MODEL: ZiGate
ID_USB_MODEL_ENC: ZiGate
ID_USB_MODEL_ID: ea60
ID_USB_REVISION: '0100'
ID_USB_SERIAL: Silicon_Labs_ZiGate_0001
ID_USB_SERIAL_SHORT: '0001'
ID_USB_TYPE: generic
ID_USB_VENDOR: Silicon_Labs
ID_USB_VENDOR_ENC: Silicon\x20Labs
ID_USB_VENDOR_ID: 10c4
ID_VENDOR: Silicon_Labs
ID_VENDOR_ENC: Silicon\x20Labs
ID_VENDOR_ID: 10c4
MAJOR: '188'
MINOR: '1'
SUBSYSTEM: tty
TAGS: ':systemd:'
USEC_INITIALIZED: '5020085'
data_path: /config/zigbee2mqtt
socat:
  enabled: false
  master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
  slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
  options: "-d -d"
  log: false
mqtt: {}
serial:
  serial:
    port: /dev/serial/by-id/usb-Silicon_Labs_ZiGate_0001-if00-port0
    adapter: zigate
tu as fait la mise à jour de quoi exactement ?
Si c’st celle de HA 2024.02 ça ne colle pas… Zigbee2MQTT est un add-on indépendant et ce n’est même pas redémarré ou touché pendant une mise à jour de HA. Ce sont des container docker séparés.
T’aurai pas ré-activé ZHA par hasard?
Y’avait-il une nouvelle version de l’add-on Z2M aussi?
Vu le message c’est la Zigate qui ne répond plus…
Qu’as tu essayé de faire par rapport à ça?
MAJ core et 2024.02 et oui, MAJ de zigbeetomqtt avant les 2 premieres citées et ca marchait toujours
je n’ai jamais utilisé ZHA
par rapport a la zigate, ben … rien fait, je ne sais que faire …
as-tu essayé de retirer la clé et la réinsérer ?
J’ai enlevé puis remis la zigate, rien mais je n’ai peut etre pas attendu assez longtemps … le journal de zigbeetomqtt s’est rempli de choses du genre
Zigbee2MQTT:info  2024-02-10 07:09:54: MQTT publish: topic 'zigbee2mqtt/Humidité SdB', payload '{"battery":77,"humidity":68.57,"last_seen":"2024-02-10T06:09:54.872Z","linkquality":132,"power_outage_count":5,"pressure":972.7,"temperature":18.59,"voltage":2965}'
Zigbee2MQTT:info  2024-02-10 07:09:54: MQTT publish: topic 'zigbee2mqtt/Humidité SdB', payload '{"battery":77,"humidity":68.57,"last_seen":"2024-02-10T06:09:54.878Z","linkquality":132,"power_outage_count":5,"pressure":972.7,"temperature":18.59,"voltage":2965}'
Zigbee2MQTT:info  2024-02-10 07:09:54: MQTT publish: topic 'zigbee2mqtt/Humidité SdB', payload '{"battery":77,"humidity":68.57,"last_seen":"2024-02-10T06:09:54.885Z","linkquality":132,"power_outage_count":5,"pressure":972.7,"temperature":18.59,"voltage":2965}'
Zigbee2MQTT:info  2024-02-10 07:09:54: MQTT publish: topic 'zigbee2mqtt/Humidité SdB', payload '{"battery":77,"humidity":68.57,"last_seen":"2024-02-10T06:09:54.891Z","linkquality":132,"power_outage_count":5,"pressure":972.7,"temperature":18.59,"voltage":2965}'
Zigbee2MQTT:info  2024-02-10 07:09:54: MQTT publish: topic 'zigbee2mqtt/Humidité SdB', payload '{"battery":77,"humidity":68.57,"last_seen":"2024-02-10T06:09:54.897Z","linkquality":132,"power_outage_count":5,"pressure":972.7,"temperature":18.59,"voltage":2965}'
mais mes entités étaient toujours indispo après 5 min.
J’ai finalement coupé toutes les VM, redémarré Proxmox, etc … le journal s’est rempli du même genre de choses puis en activant les capteurs, les entités sont revenues …
je pense que j’ai manqué de patience lors du debranche/rebranche la zigate …
Merci de votre aide
Bonjour, n’hésites pas à marquer ce problème comme résolu afin de garder le forum à jour.
