Bonjour la communauté et merci pour vos partages !
Je fais aussi mes premiers pas dans le domaine de la domotique et je me suis largement inspiré de vos échanges pour automatiser mes éclairages.
Je partage mon synoptique node red.
Bonne soirée tout le monde !
[{"id":"af865ee53874746e","type":"tab","label":"Lumières","disabled":false,"info":"","env":[]},{"id":"8ac7b057376f3ae5","type":"server-state-changed","z":"af865ee53874746e","name":"Mouvement WC","server":"61614394.82253c","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.mouvement_wc_motion","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":100,"y":120,"wires":[["0565ac6185c9f542"]]},{"id":"0565ac6185c9f542","type":"link out","z":"af865ee53874746e","name":"Mvt_WC","mode":"link","links":["3fb730ceedb95e19"],"x":265,"y":120,"wires":[]},{"id":"249e02e3e43fbecb","type":"link in","z":"af865ee53874746e","name":"link in 1","links":["dd0f3f33f813c94f"],"x":75,"y":500,"wires":[["49fb03c1bff9d678"]]},{"id":"767a999fdad826f6","type":"switch","z":"af865ee53874746e","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":710,"y":500,"wires":[["313e6d85ce0514bf"],["ede01679695f92c2"]]},{"id":"d89ecf124cca55aa","type":"api-call-service","z":"af865ee53874746e","name":"","server":"61614394.82253c","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":["455b765abe93d6a9676184691287a26d"],"entityId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1410,"y":420,"wires":[[]]},{"id":"6db0859b0ccb6a35","type":"api-call-service","z":"af865ee53874746e","name":"","server":"61614394.82253c","version":5,"debugenabled":false,"domain":"light","service":"turn_off","areaId":[],"deviceId":["455b765abe93d6a9676184691287a26d"],"entityId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1400,"y":580,"wires":[[]]},{"id":"313e6d85ce0514bf","type":"api-current-state","z":"af865ee53874746e","name":"Lumière déjà allllumée ?","server":"61614394.82253c","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"light.light_buanderie_light","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":940,"y":420,"wires":[[],["fb69f6b519c81f94"]]},{"id":"ede01679695f92c2","type":"api-current-state","z":"af865ee53874746e","name":"Détection mouvements ?","server":"61614394.82253c","version":3,"outputs":2,"halt_if":"on","halt_if_type":"msg","halt_if_compare":"is","entity_id":"binary_sensor.mouvement_buanderie_motion","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":950,"y":580,"wires":[["fb69f6b519c81f94"],["6db0859b0ccb6a35"]]},{"id":"241c8d57864b65dc","type":"inject","z":"af865ee53874746e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"off","payloadType":"str","x":330,"y":420,"wires":[["adc5469d377dfc36"]]},{"id":"b6a12847a1d8e0e6","type":"server-state-changed","z":"af865ee53874746e","name":"Mouvement Buanderie","server":"61614394.82253c","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.mouvement_buanderie_motion","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":120,"y":180,"wires":[["dd0f3f33f813c94f"]]},{"id":"dd0f3f33f813c94f","type":"link out","z":"af865ee53874746e","name":"Mvt_Buanderie","mode":"link","links":["249e02e3e43fbecb"],"x":265,"y":180,"wires":[]},{"id":"3fb730ceedb95e19","type":"link in","z":"af865ee53874746e","name":"link in 2","links":["0565ac6185c9f542"],"x":65,"y":820,"wires":[["93243034a62a6e7e"]]},{"id":"bb2b2c1b1199a7fc","type":"switch","z":"af865ee53874746e","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":730,"y":820,"wires":[["1c4e8083ae07d0c6"],["2e1fd75fd3900493"]]},{"id":"9d6e2c619e5d81e4","type":"api-call-service","z":"af865ee53874746e","name":"","server":"61614394.82253c","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":["59dd5c6247512cb442fcf2531676e036"],"entityId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1420,"y":740,"wires":[[]]},{"id":"73ed634c00886cd8","type":"api-call-service","z":"af865ee53874746e","name":"","server":"61614394.82253c","version":5,"debugenabled":false,"domain":"light","service":"turn_off","areaId":[],"deviceId":["59dd5c6247512cb442fcf2531676e036"],"entityId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1420,"y":880,"wires":[[]]},{"id":"1c4e8083ae07d0c6","type":"api-current-state","z":"af865ee53874746e","name":"Lumière déjà allllumée ?","server":"61614394.82253c","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"light.light_wc_light","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":980,"y":740,"wires":[[],["de963d2e915752be"]]},{"id":"2e1fd75fd3900493","type":"api-current-state","z":"af865ee53874746e","name":"Détection mouvements ?","server":"61614394.82253c","version":3,"outputs":2,"halt_if":"on","halt_if_type":"msg","halt_if_compare":"is","entity_id":"binary_sensor.mouvement_wc_motion","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":960,"y":880,"wires":[["de963d2e915752be"],["73ed634c00886cd8"]]},{"id":"084f9b21a930c0ba","type":"inject","z":"af865ee53874746e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"off","payloadType":"str","x":290,"y":740,"wires":[["522b7730e8fefdca"]]},{"id":"49fb03c1bff9d678","type":"time-range-switch","z":"af865ee53874746e","name":"Du couché au levé du Soleil","lat":"47.76128","lon":"7.14653","startTime":"sunset","endTime":"sunrise","startOffset":"-90","endOffset":"90","x":250,"y":500,"wires":[["adc5469d377dfc36"],[]]},{"id":"93243034a62a6e7e","type":"time-range-switch","z":"af865ee53874746e","name":"Du couché au levé du Soleil","lat":"47.76128","lon":"7.14653","startTime":"sunset","endTime":"sunrise","startOffset":"-60","endOffset":"60","x":240,"y":820,"wires":[["522b7730e8fefdca"],[]]},{"id":"0e6237b749097aa3","type":"comment","z":"af865ee53874746e","name":"Buanderie - Allumage via capteur mouvements","info":"","x":190,"y":320,"wires":[]},{"id":"57f66853a07ab59e","type":"comment","z":"af865ee53874746e","name":"WC - Allumage via capteur mouvements","info":"","x":170,"y":640,"wires":[]},{"id":"4dbf1a270a97b58e","type":"comment","z":"af865ee53874746e","name":"Déclaration variables","info":"","x":120,"y":40,"wires":[]},{"id":"de963d2e915752be","type":"trigger","z":"af865ee53874746e","name":"","op1":"","op2":"","op1type":"date","op2type":"date","duration":"2","extend":false,"overrideDelay":false,"units":"min","reset":"","bytopic":"all","topic":"topic","outputs":2,"x":1200,"y":780,"wires":[["9d6e2c619e5d81e4"],["2e1fd75fd3900493"]]},{"id":"36a0a303f8376db2","type":"inject","z":"af865ee53874746e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"on","payloadType":"str","x":290,"y":700,"wires":[["522b7730e8fefdca"]]},{"id":"fb69f6b519c81f94","type":"trigger","z":"af865ee53874746e","name":"","op1":"","op2":"","op1type":"pay","op2type":"pay","duration":"1","extend":false,"overrideDelay":false,"units":"min","reset":"","bytopic":"all","topic":"topic","outputs":2,"x":1210,"y":480,"wires":[["d89ecf124cca55aa"],["ede01679695f92c2"]]},{"id":"8d976b5a83a0dc03","type":"inject","z":"af865ee53874746e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"on","payloadType":"str","x":330,"y":380,"wires":[["adc5469d377dfc36"]]},{"id":"e93d9813fc703601","type":"server-state-changed","z":"af865ee53874746e","name":"Mouvement Sous-sol 1","server":"61614394.82253c","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.mouvement_ss1_motion_2","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":420,"y":120,"wires":[["dc49aea5df3463b5"]]},{"id":"05244ea9920608cb","type":"server-state-changed","z":"af865ee53874746e","name":"Mouvement Sous-sol 2","server":"61614394.82253c","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.ewelink_ms01_motion","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":420,"y":180,"wires":[["7433270e88395a05"]]},{"id":"dc49aea5df3463b5","type":"link out","z":"af865ee53874746e","name":"Mvt_SS1","mode":"link","links":["d55cac68dfc57098"],"x":635,"y":120,"wires":[]},{"id":"7433270e88395a05","type":"link out","z":"af865ee53874746e","name":"Mvt_SS2","mode":"link","links":["d55cac68dfc57098"],"x":635,"y":180,"wires":[]},{"id":"d55cac68dfc57098","type":"link in","z":"af865ee53874746e","name":"link in 3","links":["7433270e88395a05","dc49aea5df3463b5"],"x":75,"y":1120,"wires":[["9d026cfb43c676e6"]]},{"id":"aa2fb998ac8d1ce2","type":"switch","z":"af865ee53874746e","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":590,"y":1120,"wires":[["dac50c98af92ac3c"],["6a12fa1bec511777"]]},{"id":"ddd8cf734b9d7e5b","type":"api-call-service","z":"af865ee53874746e","name":"","server":"61614394.82253c","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.lampe_sous_sol_socket_1"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1320,"y":1060,"wires":[[]]},{"id":"dac50c98af92ac3c","type":"api-current-state","z":"af865ee53874746e","name":"Lumière déjà allllumée ?","server":"61614394.82253c","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.lampe_sous_sol_socket_1","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":870,"y":1060,"wires":[[],["493c64a8c38e5882"]]},{"id":"6a12fa1bec511777","type":"api-current-state","z":"af865ee53874746e","name":"Détection mouvements ?","server":"61614394.82253c","version":3,"outputs":2,"halt_if":"on","halt_if_type":"msg","halt_if_compare":"is","entity_id":"binary_sensor.mouvement_ss1_motion_2","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":830,"y":1160,"wires":[["493c64a8c38e5882"],["8e1a539b09ab5d36"]]},{"id":"d2cca2453a9a90fd","type":"inject","z":"af865ee53874746e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"off","payloadType":"str","x":170,"y":1080,"wires":[["9d026cfb43c676e6"]]},{"id":"3e3bf78687de7ac2","type":"comment","z":"af865ee53874746e","name":"Sous-sol - Allumage via capteur mouvements","info":"","x":200,"y":960,"wires":[]},{"id":"493c64a8c38e5882","type":"trigger","z":"af865ee53874746e","name":"","op1":"","op2":"","op1type":"date","op2type":"date","duration":"1","extend":false,"overrideDelay":false,"units":"min","reset":"","bytopic":"all","topic":"topic","outputs":2,"x":1090,"y":1100,"wires":[["ddd8cf734b9d7e5b"],["6a12fa1bec511777"]]},{"id":"cc59e44c73ce336b","type":"inject","z":"af865ee53874746e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"on","payloadType":"str","x":170,"y":1040,"wires":[["9d026cfb43c676e6"]]},{"id":"c9a49828a7999441","type":"api-call-service","z":"af865ee53874746e","name":"","server":"61614394.82253c","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.lampe_sous_sol_socket_1"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1320,"y":1200,"wires":[[]]},{"id":"8e1a539b09ab5d36","type":"api-current-state","z":"af865ee53874746e","name":"Détection mouvements ?","server":"61614394.82253c","version":3,"outputs":2,"halt_if":"on","halt_if_type":"msg","halt_if_compare":"is","entity_id":"binary_sensor.ewelink_ms01_motion","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":830,"y":1220,"wires":[["493c64a8c38e5882"],["c9a49828a7999441"]]},{"id":"adc5469d377dfc36","type":"api-current-state","z":"af865ee53874746e","name":"En vacances ?","server":"61614394.82253c","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.vacances","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"on","valueType":"str"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":520,"y":500,"wires":[["767a999fdad826f6"],[]]},{"id":"522b7730e8fefdca","type":"api-current-state","z":"af865ee53874746e","name":"En vacances ?","server":"61614394.82253c","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.vacances","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"on","valueType":"str"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":520,"y":820,"wires":[["bb2b2c1b1199a7fc"],[]]},{"id":"9d026cfb43c676e6","type":"api-current-state","z":"af865ee53874746e","name":"En vacances ?","server":"61614394.82253c","version":3,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.vacances","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"on","valueType":"str"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":400,"y":1120,"wires":[["aa2fb998ac8d1ce2"],[]]},{"id":"52b3c3a0994c695b","type":"server-state-changed","z":"af865ee53874746e","name":"En vacances","server":"61614394.82253c","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_boolean.vacances","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":790,"y":120,"wires":[["34bae7aff415fac1"]]},{"id":"34bae7aff415fac1","type":"link out","z":"af865ee53874746e","name":"Vac","mode":"link","links":["4f9ddaf807861c62","e7f11a23969f0fcf","7b187fb27d7a4e6b"],"x":955,"y":120,"wires":[]},{"id":"4f9ddaf807861c62","type":"link in","z":"af865ee53874746e","name":"link in 4","links":["34bae7aff415fac1"],"x":325,"y":560,"wires":[["adc5469d377dfc36"]]},{"id":"e7f11a23969f0fcf","type":"link in","z":"af865ee53874746e","name":"link in 5","links":["34bae7aff415fac1"],"x":365,"y":880,"wires":[["522b7730e8fefdca"]]},{"id":"7b187fb27d7a4e6b","type":"link in","z":"af865ee53874746e","name":"link in 6","links":["34bae7aff415fac1"],"x":255,"y":1180,"wires":[["9d026cfb43c676e6"]]},{"id":"61614394.82253c","type":"server","name":"Home Assistant","addon":true}]
