Bonsoir,
j’ai un PC Giada i39b sur lequel j’y ait installer Proxmox VE 8.1.4
J’ai bien la connexion en root, navigateur, filezilla, ssh…
Problème, j’essaie de monter une VM HA, quelque soit la version, la dernière ou même la haos_ova-11.3.qcow2 je retombe toujours sur le même problème
J’ai réinstaller quemu
apt-get install qemu-guest-agent
systemctl start qemu-guest-agent
et/ou
systemctl enable qemu-guest-agent
Mais encore une fois une erreur et là je déprime
Avez-vous la solution SVP ?
Subject: A new session 5 has been created for user root
░░ Defined-By: systemd
░░ Support: https://www.debian.org/support
░░ Documentation: sd-login(3)
░░ A new session with the ID 5 has been created for the user root.
░░ The leading process of the session is 4124.
Feb 19 00:10:58 pve systemd[1]: Started session-5.scope - Session 5 of User root.
░░ Subject: A start job for unit session-5.scope has finished successfully
░░ A start job for unit session-5.scope has finished successfully.
░░ The job identifier is 957.
Feb 19 00:10:58 pve sshd[4124]: pam_env(sshd:session): deprecated reading of user environment enabled
Feb 19 00:12:30 pve systemd[1]: dev-virtio\x2dports-org.qemu.guest_agent.0.device: Job dev-virtio\x2dports-org.qemu.guest_agent>
Feb 19 00:12:30 pve systemd[1]: Timed out waiting for device dev-virtio\x2dports-org.qemu.guest_agent.0.device - /dev/virtio-po>
░░ Subject: A start job for unit dev-virtio\x2dports-org.qemu.guest_agent.0.device has failed
░░ A start job for unit dev-virtio\x2dports-org.qemu.guest_agent.0.device has finished with a failure.
░░ The job identifier is 1153 and the job result is timeout.
Feb 19 00:12:30 pve systemd[1]: Dependency failed for qemu-guest-agent.service - QEMU Guest Agent.
░░ Subject: A start job for unit qemu-guest-agent.service has failed
░░ A start job for unit qemu-guest-agent.service has finished with a failure.
░░ The job identifier is 1057 and the job result is dependency.
Feb 19 00:12:30 pve systemd[1]: qemu-guest-agent.service: Job qemu-guest-agent.service/start failed with result 'dependency'.
lines 2545-2580/2580 (END)
