Proxmox et HBA
j’ai un petit souci sous proxmox 8.2, ma carte QLogic LPe12002 FC 8Gb fige le boot pendant deux minutes.
et bien sûr, je ne la voit pas sous l’OS…
root@proxmox1:/home/bentou# dmesg | grep qla
[    1.196906] qla2xxx [0000:00:00.0]-0005: : QLogic Fibre Channel HBA Driver: 10.02.09.100-k.
[    1.197042] qla2xxx [0000:06:00.0]-001d: : Found an ISP2532 irq 16 iobase 0x000000002eaf4413.
[    1.219259] qla2xxx [0000:06:00.0]-0047:6: Unsupported FLT detected: version=0x0 length=0x0 checksum=0x0.
[    1.231717] qla2xxx [0000:06:00.0]-0059:6: No matching ROM signature.
[    1.232383] qla2xxx [0000:06:00.0]-005f:6: Unrecognized fw revision at 80000.
[    1.241307] qla2xxx [0000:06:00.0]-006b:6: Inconsistent NVRAM checksum=0x0 id= version=0x0.
[    1.241312] qla2xxx [0000:06:00.0]-006c:6: Falling back to functioning (yet invalid -- WWPN) defaults.
[    1.241315] qla2xxx [0000:06:00.0]-0070:6: NVRAM configuration failed.
[    1.241317] qla2xxx [0000:06:00.0]-ffff:6: FC4 priority set to FCP
[   31.343259] qla2xxx [0000:06:00.0]-d04c:6: MBX Command timeout for cmd 2, iocontrol=0 jiffies=fffbe5fd mb[0-3]=[0x4020 0x0 0x0 0xaa55] mb7 0x2525 host_status 0x40200011 hccr 0x40
[   31.343265] qla2xxx [0000:06:00.0]-d008:6: No buffer available for dump.
[   31.343269] qla2xxx [0000:06:00.0]-101c:6: Mailbox cmd timeout occurred, cmd=0x2, mb[0]=0x2, eeh_busy=0x0. Scheduling ISP abort.
[   61.355259] qla2xxx [0000:06:00.0]-d04c:6: MBX Command timeout for cmd 2, iocontrol=0 jiffies=fffc5b39 mb[0-3]=[0x4020 0x0 0x0 0xaa55] mb7 0x2525 host_status 0x40200011 hccr 0x40
[   61.355264] qla2xxx [0000:06:00.0]-d008:6: No buffer available for dump.
[   91.367260] qla2xxx [0000:06:00.0]-d04c:6: MBX Command timeout for cmd 2, iocontrol=0 jiffies=fffcd075 mb[0-3]=[0x4020 0x0 0x0 0xaa55] mb7 0x2525 host_status 0x40200011 hccr 0x40
[   91.367265] qla2xxx [0000:06:00.0]-d008:6: No buffer available for dump.
[  121.369264] qla2xxx [0000:06:00.0]-d04c:6: MBX Command timeout for cmd 2, iocontrol=0 jiffies=fffd45a7 mb[0-3]=[0x4020 0x0 0x0 0xaa55] mb7 0x2525 host_status 0x40200011 hccr 0x40
[  121.369270] qla2xxx [0000:06:00.0]-d008:6: No buffer available for dump.
[  151.372265] qla2xxx [0000:06:00.0]-d04c:6: MBX Command timeout for cmd 2, iocontrol=0 jiffies=fffdbada mb[0-3]=[0x4020 0x0 0x0 0xaa55] mb7 0x2525 host_status 0x40200011 hccr 0x40
[  151.372271] qla2xxx [0000:06:00.0]-d008:6: No buffer available for dump.
[  151.372277] qla2xxx [0000:06:00.0]-00cf:6: Setup chip ****FAILED****.
[  151.372294] qla2xxx [0000:06:00.0]-00d6:6: Failed to initialize adapter - Adapter flags 2.
si vous avez une idée ???
Bon, ca y est, je vois mon lecteur de bande…
une self à moitié dessoudée et la carte n’activait pas son bios…
root@proxmox1:/home/bentou# dmesg  | grep -i qla
[    1.190728] qla2xxx [0000:00:00.0]-0005: : QLogic Fibre Channel HBA Driver: 10.02.09.100-k.
[    1.190840] qla2xxx [0000:06:00.0]-001d: : Found an ISP2532 irq 16 iobase 0x00000000d67b094a.
[    1.241202] qla2xxx [0000:06:00.0]-ffff:6: FC4 priority set to FCP
[    1.618970] scsi host6: qla2xxx
[    1.619674] qla2xxx [0000:06:00.0]-00fb:6: QLogic HPAJ764A - HP 8Gb Dual Channel PCI-e 2.0 FC HBA.
[    1.619681] qla2xxx [0000:06:00.0]-00fc:6: ISP2532: PCIe (5.0GT/s x8) @ 0000:06:00.0 hdma- host#=6 fw=8.07.00 (90d5).
[    1.619821] qla2xxx [0000:06:00.1]-001d: : Found an ISP2532 irq 17 iobase 0x00000000189b740d.
[    1.670244] qla2xxx [0000:06:00.1]-ffff:7: FC4 priority set to FCP
[    1.859421] qla2xxx [0000:06:00.0]-500a:6: LOOP UP detected (8 Gbps).
[    2.041947] scsi host7: qla2xxx
[    2.042500] qla2xxx [0000:06:00.1]-00fb:7: QLogic HPAJ764A - HP 8Gb Dual Channel PCI-e 2.0 FC HBA.
[    2.042506] qla2xxx [0000:06:00.1]-00fc:7: ISP2532: PCIe (5.0GT/s x8) @ 0000:06:00.1 hdma- host#=7 fw=8.07.00 (90d5).
[   23.676732] qla2xxx [0000:06:00.1]-8038:7: Cable is unplugged...
root@proxmox1:/home/bentou#proxmox-tape changer list
│ name │ path                                       │ vendor  │ model          │ serial                │
│ i40  │ /dev/tape/by-id/scsi-QUANTUMD0H0112113_LLA │ QUANTUM │ Scalar_i40-i80 │ QUANTUMD0H0112113_LLA │
plus qu’a trouver un moyen de sauvegarder le Synology également…
en passant, est ce quelqu’un sait si il y a moyen de transformer un slot pci express x16 en 2 slots x8 ???
