Désolé mais je n’avais pas envie d’encombrer le topic et je ne suis pas sûr que ce soit pertinent, il me renseigne casi toutes les intégrations :
2024-10-03 20:58:06.548 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration powercalc which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-03 20:58:06.550 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration better_thermostat which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-03 20:58:06.551 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration alarmo which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-03 20:58:06.552 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration carbu_com which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-03 20:58:06.554 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration tapo_control which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-03 20:58:06.555 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration alexa_media which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-03 20:58:06.556 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration mass which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-03 20:58:06.558 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-03 20:58:06.559 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration frigate which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-03 20:58:06.560 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration oralb_ble which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-03 20:58:06.561 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration average which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-03 20:58:06.561 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration icloud3 which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-03 20:58:06.563 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration recycle_app which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-03 20:58:06.564 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration meross_cloud which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-03 20:58:06.565 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration places which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-03 20:58:06.566 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration meteoalarm_m which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-03 20:58:06.567 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration garmin_connect which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-03 20:58:06.568 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration localtuya which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-03 20:58:06.569 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration spotcast which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-03 20:58:06.570 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration irm_kmi which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-03 20:58:06.571 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration samsungtv_smart which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-03 20:58:06.572 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration ha_strava which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-03 20:58:08.446 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2024-10-03 20:58:08.481 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=356 from 2024-10-03 18:53:34.222078)
2024-10-03 20:58:10.071 ERROR (MainThread) [homeassistant.helpers.event] Error while processing template: Template<template=(De {{ as_timestamp(states('sensor.heure_debut_avertissement')) | timestamp_custom('%A %Hh%M') | replace("Monday", "lundi") | replace("Tuesday", "mardi") | replace("Wednesday", "mercredi") | replace("Thursday", "jeudi") | replace("Friday", "vendredi") | replace("Saturday", "samedi") | replace("Sunday", "dimanche") }}
à {{ as_timestamp(states('sensor.heure_fin_avertissement')) | timestamp_custom('%A %Hh%M')| replace("Monday", "lundi") | replace("Tuesday", "mardi") | replace("Wednesday", "mercredi") | replace("Thursday", "jeudi") | replace("Friday", "vendredi") | replace("Saturday", "samedi") | replace("Sunday", "dimanche") }}) renders=2>
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2110, in forgiving_as_timestamp
return dt_util.as_timestamp(value)
File "/usr/src/homeassistant/homeassistant/util/dt.py", line 153, in as_timestamp
raise ValueError("not a valid date/time.")
ValueError: not a valid date/time.
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 631, in async_render
render_result = _render_with_context(self.template, compiled, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2727, in _render_with_context
return template.render(**kwargs)
File "/usr/local/lib/python3.12/site-packages/jinja2/environment.py", line 1304, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.12/site-packages/jinja2/environment.py", line 939, in handle_exception
raise rewrite_traceback_stack(source=source)
File "<template>", line 1, in top-level template code
File "/usr/local/lib/python3.12/site-packages/jinja2/sandbox.py", line 394, in call
return __context.call(__obj, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2113, in forgiving_as_timestamp
raise_no_default("as_timestamp", value)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1904, in raise_no_default
raise ValueError(
ValueError: Template error: as_timestamp got invalid input 'unknown' when rendering template 'De {{ as_timestamp(states('sensor.heure_debut_avertissement')) | timestamp_custom('%A %Hh%M') | replace("Monday", "lundi") | replace("Tuesday", "mardi") | replace("Wednesday", "mercredi") | replace("Thursday", "jeudi") | replace("Friday", "vendredi") | replace("Saturday", "samedi") | replace("Sunday", "dimanche") }}
à {{ as_timestamp(states('sensor.heure_fin_avertissement')) | timestamp_custom('%A %Hh%M')| replace("Monday", "lundi") | replace("Tuesday", "mardi") | replace("Wednesday", "mercredi") | replace("Thursday", "jeudi") | replace("Friday", "vendredi") | replace("Saturday", "samedi") | replace("Sunday", "dimanche") }}' but no default was specified
The above exception was the direct cause of the following exception:
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 748, in async_render_to_info
render_info._result = self.async_render( # noqa: SLF001
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 633, in async_render
raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: ValueError: Template error: as_timestamp got invalid input 'unknown' when rendering template 'De {{ as_timestamp(states('sensor.heure_debut_avertissement')) | timestamp_custom('%A %Hh%M') | replace("Monday", "lundi") | replace("Tuesday", "mardi") | replace("Wednesday", "mercredi") | replace("Thursday", "jeudi") | replace("Friday", "vendredi") | replace("Saturday", "samedi") | replace("Sunday", "dimanche") }}
2024-10-03 20:58:13.067 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to load_verify_locations with args (<ssl.SSLContext object at 0x7f844a5750>, '/usr/local/lib/python3.12/site-packages/certifi/cacert.pem', None, None) inside the event loop by custom integration 'alexa_media' at custom_components/alexa_media/__init__.py, line 341: AlexaLogin( (offender: /usr/local/lib/python3.12/ssl.py, line 708: context.load_verify_locations(cafile, capath, cadata)), please create a bug report at https://github.com/alandtse/alexa_media_player/issues
For developers, please see https://developers.home-assistant.io/docs/asyncio_blocking_operations/#load_verify_locations
File "<frozen runpy>", line 198, in _run_module_as_main
File "<frozen runpy>", line 88, in _run_code
File "/usr/src/homeassistant/homeassistant/__main__.py", line 223, in <module>
sys.exit(main())
File "/usr/src/homeassistant/homeassistant/__main__.py", line 209, in main
exit_code = runner.run(runtime_conf)
File "/usr/src/homeassistant/homeassistant/runner.py", line 189, in run
return loop.run_until_complete(setup_and_run_hass(runtime_config))
File "/usr/local/lib/python3.12/asyncio/base_events.py", line 674, in run_until_complete
self.run_forever()
File "/usr/local/lib/python3.12/asyncio/base_events.py", line 641, in run_forever
self._run_once()
File "/usr/local/lib/python3.12/asyncio/base_events.py", line 1990, in _run_once
handle._run()
File "/usr/local/lib/python3.12/asyncio/events.py", line 88, in _run
self._context.run(self._callback, *self._args)
File "/usr/src/homeassistant/homeassistant/setup.py", line 165, in async_setup_component
result = await _async_setup_component(hass, domain, config)
File "/usr/src/homeassistant/homeassistant/setup.py", line 461, in _async_setup_component
await asyncio.gather(
File "/usr/src/homeassistant/homeassistant/setup.py", line 463, in <genexpr>
create_eager_task(
File "/usr/src/homeassistant/homeassistant/util/async_.py", line 45, in create_eager_task
return Task(coro, loop=loop, name=name, eager_start=True)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 742, in async_setup_locked
await self.async_setup(hass, integration=integration)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 594, in async_setup
result = await component.async_setup_entry(hass, self)
File "/config/custom_components/alexa_media/__init__.py", line 341, in async_setup_entry
AlexaLogin(
2024-10-03 20:58:13.107 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to open with args (PosixPath('/config/.storage/alexa_media.lionelboulangerpv@gmail.com.pickle'),) inside the event loop by custom integration 'alexa_media' at custom_components/alexa_media/__init__.py, line 361: await login.login(cookies=await login.load_cookie()) (offender: /usr/local/lib/python3.12/site-packages/aiohttp/cookiejar.py, line 126: with file_path.open(mode="rb") as f:), please create a bug report at https://github.com/alandtse/alexa_media_player/issues
For developers, please see https://developers.home-assistant.io/docs/asyncio_blocking_operations/#open
sys.exit(main())
self.run_forever()
self._run_once()
handle._run()
File "/config/custom_components/alexa_media/__init__.py", line 361, in async_setup_entry
2024-10-03 20:58:14.947 WARNING (MainThread) [custom_components.meross_cloud]
Meross Cloud Custom component
Developed by Alberto Geniola
Low level library version: 0.4.7.3
This custom component is under development and not yet ready for production use.
In case of errors/misbehave, please report it here:
https://github.com/albertogeniola/meross-homeassistant/issues
If you like this extension and you want to support it, please consider donating.
List of devices reported by HTTP API:
- Frigo garage (gauche) (mss305) - OnlineStatus.ONLINE
- Porte de garage Bouboul & Mary (msg100) - OnlineStatus.ONLINE
- Prise Intelligente Extérieure (mss620) - OnlineStatus.ONLINE
- Frigo garage (droite) (mss305) - OnlineStatus.ONLINE
2024-10-03 20:58:15.156 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to load_default_certs with args (<ssl.SSLContext object at 0x7f7e2cd350>,) inside the event loop by custom integration 'meross_cloud' at custom_components/meross_cloud/__init__.py, line 189: await self._manager.async_device_discovery() (offender: /usr/local/lib/python3.12/site-packages/paho/mqtt/client.py, line 806: context.load_default_certs()), please create a bug report at https://github.com/albertogeniola/meross-homeassistant
For developers, please see https://developers.home-assistant.io/docs/asyncio_blocking_operations/#load_default_certs
sys.exit(main())
self.run_forever()
self._run_once()
handle._run()
File "/config/custom_components/meross_cloud/__init__.py", line 419, in async_setup_entry
await meross_coordinator.initial_setup()
File "/config/custom_components/meross_cloud/__init__.py", line 189, in initial_setup
2024-10-03 20:58:15.593 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'localtuya' accesses hass.helpers.service. This is deprecated and will stop working in Home Assistant 2024.11, it should be updated to import functions used from service directly at custom_components/localtuya/__init__.py, line 165: hass.helpers.service.async_register_admin_service(, please create a bug report at https://github.com/rospogrigio/localtuya/issues
2024-10-03 20:58:15.610 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to open with args (PosixPath('/config/.storage/alexa_media.lionelboulangerpv@gmail.com.pickle'),) inside the event loop by custom integration 'alexa_media' at custom_components/alexa_media/__init__.py, line 361: await login.login(cookies=await login.load_cookie()) (offender: /usr/local/lib/python3.12/site-packages/aiohttp/cookiejar.py, line 121: with file_path.open(mode="wb") as f:), please create a bug report at https://github.com/alandtse/alexa_media_player/issues
sys.exit(main())
self.run_forever()
self._run_once()
handle._run()
2024-10-03 20:58:15.635 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to load_verify_locations with args (<ssl.SSLContext object at 0x7f7dfb4850>,) inside the event loop by custom integration 'alexa_media' at custom_components/alexa_media/__init__.py, line 922: http2 = HTTP2EchoClient( (offender: /usr/local/lib/python3.12/site-packages/httpx/_config.py, line 149: context.load_verify_locations(cafile=cafile)), please create a bug report at https://github.com/alandtse/alexa_media_player/issues
sys.exit(main())
self.run_forever()
self._run_once()
handle._run()
File "/config/custom_components/alexa_media/__init__.py", line 363, in async_setup_entry
await setup_alexa(hass, config_entry, login)
File "/config/custom_components/alexa_media/__init__.py", line 1312, in setup_alexa
await http2_connect()
File "/config/custom_components/alexa_media/__init__.py", line 922, in http2_connect
2024-10-03 20:58:16.129 ERROR (MainThread) [homeassistant.components.climate] Error adding entity None for domain climate with platform localtuya
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 595, in _async_add_entities
await coro
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 813, in _async_add_entity
capabilities=entity.capability_attributes,
File "/usr/src/homeassistant/homeassistant/components/climate/__init__.py", line 324, in __getattribute__
return super().__getattribute__(__name)
File "/usr/src/homeassistant/homeassistant/components/climate/__init__.py", line 496, in capability_attributes
ATTR_MIN_TEMP: show_temp(hass, self.min_temp, temperature_unit, precision),
File "/config/custom_components/localtuya/climate.py", line 427, in min_temp
return self._config[CONF_TEMP_MIN]
KeyError: 'min_temperature_const'
2024-10-03 20:58:16.171 WARNING (MainThread) [custom_components.localtuya.common] [658...1b8] Disconnected - waiting for discovery broadcast
2024-10-03 20:58:16.246 ERROR (MainThread) [homeassistant.setup] The 'tuya' integration does not support YAML setup, please remove it from your configuration
2024-10-03 20:58:16.627 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'meross_cloud' calls async_forward_entry_setup for integration, meross_cloud with title: https://iot.meross.com and entry_id: 12615ddfbb80aaa6dae60f37a609fa64, which is deprecated and will stop working in Home Assistant 2025.6, await async_forward_entry_setups instead at custom_components/meross_cloud/__init__.py, line 426: hass.async_create_task(, please create a bug report at https://github.com/albertogeniola/meross-homeassistant
2024-10-03 20:58:16.808 WARNING (MainThread) [meross_iot.manager] Found a new device Prise Intelligente Extérieure (mss620, HW 7.0.0, FW 7.3.5, class: mss620:7.0.0:7.3.5) that has become online while we were offline.
2024-10-03 20:58:16.810 WARNING (MainThread) [meross_iot.manager] Found a new device Frigo garage (droite) (mss305, HW 8.0.0, FW 8.3.12, class: mss305:8.0.0:8.3.12) that has become online while we were offline.
2024-10-03 20:58:16.810 WARNING (MainThread) [meross_iot.manager] Found a new device Frigo garage (gauche) (mss305, HW 8.0.0, FW 8.3.12, class: mss305:8.0.0:8.3.12) that has become online while we were offline.
2024-10-03 20:58:16.810 WARNING (MainThread) [meross_iot.manager] Found a new device Porte de garage Bouboul & Mary (msg100, HW 3.0.0, FW 3.2.7, class: msg100:3.0.0:3.2.7) that has become online while we were offline.
2024-10-03 20:58:17.022 WARNING (ImportExecutor_0) [homeassistant.components.media_player.const] MEDIA_CLASS_ALBUM was used from mass, this is a deprecated constant which will be removed in HA Core 2025.10. Use MediaClass.ALBUM instead, please report it to the author of the 'mass' custom integration
2024-10-03 20:58:17.029 WARNING (ImportExecutor_0) [homeassistant.components.media_player.const] MEDIA_CLASS_ARTIST was used from mass, this is a deprecated constant which will be removed in HA Core 2025.10. Use MediaClass.ARTIST instead, please report it to the author of the 'mass' custom integration
2024-10-03 20:58:17.034 WARNING (ImportExecutor_0) [homeassistant.components.media_player.const] MEDIA_CLASS_DIRECTORY was used from mass, this is a deprecated constant which will be removed in HA Core 2025.10. Use MediaClass.DIRECTORY instead, please report it to the author of the 'mass' custom integration
2024-10-03 20:58:17.039 WARNING (ImportExecutor_0) [homeassistant.components.media_player.const] MEDIA_CLASS_MUSIC was used from mass, this is a deprecated constant which will be removed in HA Core 2025.10. Use MediaClass.MUSIC instead, please report it to the author of the 'mass' custom integration
2024-10-03 20:58:17.048 WARNING (ImportExecutor_0) [homeassistant.components.media_player.const] MEDIA_CLASS_PLAYLIST was used from mass, this is a deprecated constant which will be removed in HA Core 2025.10. Use MediaClass.PLAYLIST instead, please report it to the author of the 'mass' custom integration
2024-10-03 20:58:17.054 WARNING (ImportExecutor_0) [homeassistant.components.media_player.const] MEDIA_CLASS_TRACK was used from mass, this is a deprecated constant which will be removed in HA Core 2025.10. Use MediaClass.TRACK instead, please report it to the author of the 'mass' custom integration
2024-10-03 20:58:17.059 WARNING (ImportExecutor_0) [homeassistant.components.media_player.const] MEDIA_TYPE_ALBUM was used from mass, this is a deprecated constant which will be removed in HA Core 2025.10. Use MediaType.ALBUM instead, please report it to the author of the 'mass' custom integration
2024-10-03 20:58:17.063 WARNING (ImportExecutor_0) [homeassistant.components.media_player.const] MEDIA_TYPE_ARTIST was used from mass, this is a deprecated constant which will be removed in HA Core 2025.10. Use MediaType.ARTIST instead, please report it to the author of the 'mass' custom integration
2024-10-03 20:58:17.069 WARNING (ImportExecutor_0) [homeassistant.components.media_player.const] MEDIA_TYPE_PLAYLIST was used from mass, this is a deprecated constant which will be removed in HA Core 2025.10. Use MediaType.PLAYLIST instead, please report it to the author of the 'mass' custom integration
2024-10-03 20:58:17.074 WARNING (ImportExecutor_0) [homeassistant.components.media_player.const] MEDIA_TYPE_TRACK was used from mass, this is a deprecated constant which will be removed in HA Core 2025.10. Use MediaType.TRACK instead, please report it to the author of the 'mass' custom integration
2024-10-03 20:58:17.854 WARNING (ImportExecutor_0) [py.warnings] /usr/local/lib/python3.12/site-packages/paramiko/pkey.py:100: CryptographyDeprecationWarning: TripleDES has been moved to cryptography.hazmat.decrepit.ciphers.algorithms.TripleDES and will be removed from this module in 48.0.0.
"cipher": algorithms.TripleDES,
2024-10-03 20:58:17.951 WARNING (ImportExecutor_0) [py.warnings] /usr/local/lib/python3.12/site-packages/paramiko/transport.py:258: CryptographyDeprecationWarning: TripleDES has been moved to cryptography.hazmat.decrepit.ciphers.algorithms.TripleDES and will be removed from this module in 48.0.0.
"class": algorithms.TripleDES,
2024-10-03 20:58:18.761 ERROR (SyncWorker_26) [homeassistant.components.unifi_direct.device_tracker] Failed to connect to accesspoint
2024-10-03 20:58:18.762 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform legacy unifi_direct
2024-10-03 20:58:19.240 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.cout_journalier_appareils_2 (<class 'homeassistant.components.utility_meter.sensor.UtilityMeterSensor'>) is using state class 'total_increasing' which is impossible considering device class ('monetary') it is using; expected None or one of 'total'; Please update your configuration if your entity is manually configured, otherwise create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+utility_meter%22
2024-10-03 20:58:19.247 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.cout_hebdomadaire_appareils (<class 'homeassistant.components.utility_meter.sensor.UtilityMeterSensor'>) is using state class 'total_increasing' which is impossible considering device class ('monetary') it is using; expected None or one of 'total'; Please update your configuration if your entity is manually configured, otherwise create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+utility_meter%22
2024-10-03 20:58:19.252 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.cout_journalier_appareils (<class 'homeassistant.components.utility_meter.sensor.UtilityMeterSensor'>) is using state class 'total_increasing' which is impossible considering device class ('monetary') it is using; expected None or one of 'total'; Please update your configuration if your entity is manually configured, otherwise create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+utility_meter%22
2024-10-03 20:58:19.254 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.cout_journalier_eau (<class 'homeassistant.components.utility_meter.sensor.UtilityMeterSensor'>) is using state class 'total_increasing' which is impossible considering device class ('monetary') it is using; expected None or one of 'total'; Please update your configuration if your entity is manually configured, otherwise create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+utility_meter%22
2024-10-03 20:58:19.579 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration meross_cloud with title: https://iot.meross.com and entry_id: 12615ddfbb80aaa6dae60f37a609fa64, during setup without awaiting async_forward_entry_setup, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1. Please report this issue.
Stack (most recent call last):
sys.exit(main())
self.run_forever()
self._run_once()
handle._run()
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 2218, in async_forward_entry_setup
_report_non_awaited_platform_forwards(entry, "async_forward_entry_setup")
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1192, in _report_non_awaited_platform_forwards
report(
File "/usr/src/homeassistant/homeassistant/helpers/frame.py", line 155, in report
_LOGGER.warning(msg, stack_info=True)
2024-10-03 20:58:19.594 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration meross_cloud with title: https://iot.meross.com and entry_id: 12615ddfbb80aaa6dae60f37a609fa64, during setup without awaiting async_forward_entry_setup, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1. Please report this issue.
sys.exit(main())
self.run_forever()
self._run_once()
handle._run()
report(
2024-10-03 20:58:19.599 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration meross_cloud with title: https://iot.meross.com and entry_id: 12615ddfbb80aaa6dae60f37a609fa64, during setup without awaiting async_forward_entry_setup, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1. Please report this issue.
sys.exit(main())
self.run_forever()
self._run_once()
handle._run()
report(
2024-10-03 20:58:19.955 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration meross_cloud with title: https://iot.meross.com and entry_id: 12615ddfbb80aaa6dae60f37a609fa64, during setup without awaiting async_forward_entry_setup, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1. Please report this issue.
sys.exit(main())
self.run_forever()
self._run_once()
handle._run()
report(
2024-10-03 20:58:20.470 ERROR (MainThread) [homeassistant.components.trend.binary_sensor] float() argument must be a string or a real number, not 'NoneType'
2024-10-03 20:58:20.825 WARNING (ImportExecutor_0) [homeassistant.const] STATE_LOCKED was used from alarmo, this is a deprecated constant which will be removed in HA Core 2025.10. Use LockState.LOCKED instead, please report it to the author of the 'alarmo' custom integration
2024-10-03 20:58:20.831 WARNING (ImportExecutor_0) [homeassistant.const] STATE_UNLOCKED was used from alarmo, this is a deprecated constant which will be removed in HA Core 2025.10. Use LockState.UNLOCKED instead, please report it to the author of the 'alarmo' custom integration
2024-10-03 20:58:20.884 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'alarmo' registers an entity service with a non entity service schema which will stop working in HA Core 2025.9 at custom_components/alarmo/alarm_control_panel.py, line 97: platform.async_register_entity_service(, please create a bug report at https://github.com/nielsfaber/alarmo/issues
2024-10-03 20:58:20.891 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'alarmo' registers an entity service with a non entity service schema which will stop working in HA Core 2025.9 at custom_components/alarmo/alarm_control_panel.py, line 102: platform.async_register_entity_service(, please create a bug report at https://github.com/nielsfaber/alarmo/issues
2024-10-03 20:58:20.903 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration meross_cloud with title: https://iot.meross.com and entry_id: 12615ddfbb80aaa6dae60f37a609fa64, during setup without awaiting async_forward_entry_setup, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1. Please report this issue.
sys.exit(main())
self.run_forever()
self._run_once()
handle._run()
report(
2024-10-03 20:58:21.126 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'garmin_connect' registers an entity service with a non entity service schema which will stop working in HA Core 2025.9 at custom_components/garmin_connect/sensor.py, line 99: platform.async_register_entity_service(, please create a bug report at https://github.com/cyberjunky/home-assistant-garmin_connect/issues
2024-10-03 20:58:21.132 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'garmin_connect' registers an entity service with a non entity service schema which will stop working in HA Core 2025.9 at custom_components/garmin_connect/sensor.py, line 103: platform.async_register_entity_service(, please create a bug report at https://github.com/cyberjunky/home-assistant-garmin_connect/issues
2024-10-03 20:58:21.642 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration meross_cloud with title: https://iot.meross.com and entry_id: 12615ddfbb80aaa6dae60f37a609fa64, during setup without awaiting async_forward_entry_setup, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1. Please report this issue.
sys.exit(main())
self.run_forever()
self._run_once()
handle._run()
report(
2024-10-03 20:58:32.269 ERROR (MainThread) [custom_components.powercalc.strategy.lut] light.escalier: Lookup table not found for color mode (model: LXN60-LS27-Z30, color_mode: brightness)
2024-10-03 20:58:32.483 WARNING (MainThread) [custom_components.hacs] You have 'marcokreeft87/room-card' installed with HACS this repository has been removed from HACS, please consider removing it. Removal reason (Repository is archived)
2024-10-03 20:58:36.902 ERROR (MainThread) [custom_components.powercalc.strategy.lut] light.escalier: Lookup table not found for color mode (model: LXN60-LS27-Z30, color_mode: brightness)
