Ce jour j’ai recu une notification de reconfiguration d’alexa sur HA donc je remets mon code 2FA et ilne le prends pas il me dedouble integration.
est que ca vous ai deja arrivé, avez vous une solution ?
Merci d’avance
System Health
| version |
core-2021.10.0b2 |
| installation_type |
Home Assistant Supervised |
| dev |
false |
| hassio |
true |
| docker |
true |
| user |
root |
| virtualenv |
false |
| python_version |
3.9.7 |
| os_name |
Linux |
| os_version |
4.19.0-17-amd64 |
| arch |
x86_64 |
| timezone |
Europe/Paris |
| GitHub API |
ok |
| Github API Calls Remaining |
3448 |
| Installed Version |
1.15.2 |
| Stage |
running |
| Available Repositories |
892 |
| Installed Repositories |
64 |
AccuWeather
| can_reach_server |
ok |
| remaining_requests |
9 |
| logged_in |
false |
| can_reach_cert_server |
ok |
| can_reach_cloud_auth |
ok |
| can_reach_cloud |
ok |
| host_os |
Debian GNU/Linux 10 (buster) |
| update_channel |
beta |
| supervisor_version |
supervisor-2021.09.6 |
| docker_version |
20.10.8 |
| disk_total |
113.6 GB |
| disk_used |
17.1 GB |
| healthy |
true |
| supported |
failed to load: Unsupported |
| supervisor_api |
ok |
| version_api |
ok |
| installed_addons |
Samba share (9.5.1), MQTT Server & Web client (1.2.0), Terminal & SSH (9.2.1), Spotify Connect (0.9.1), Grafana (7.2.0), Tydom2MQTT - Beta (release_1.2.1), InfluxDB (4.2.1), Glances (0.13.0), Dnsmasq (1.4.4), Duck DNS (1.14.0), Visual Studio Code (3.6.2), File editor (5.3.3), Node-RED (10.0.1), Zigbee2mqtt (1.21.2-1), Zigbee2mqtt Edge (edge), ESPHome (2021.9.2) |
Lovelace
| dashboards |
3 |
| resources |
42 |
| views |
17 |
| mode |
storage |
Spotify
| api_endpoint_reachable |
ok |
log d’erreur
Logger: alexapy.helpers
Source: /usr/local/lib/python3.9/site-packages/alexapy/helpers.py:192
First occurred: 22:19:56 (10 occurrences)
Last logged: 22:23:01
alexaapi.get_network_details((<alexapy.alexalogin.AlexaLogin object at 0x7f6272c72c10>,), {}): An error occured accessing AlexaAPI: An exception of type AlexapyLoginError occurred. Arguments: ()
alexaapi.get_devices((<alexapy.alexalogin.AlexaLogin object at 0x7f6272c72c10>,), {}): An error occured accessing AlexaAPI: An exception of type AlexapyLoginError occurred. Arguments: ('Login error detected; not contacting API',)
alexaapi.get_bluetooth((<alexapy.alexalogin.AlexaLogin object at 0x7f6272c72c10>,), {}): An error occured accessing AlexaAPI: An exception of type AlexapyLoginError occurred. Arguments: ('Login error detected; not contacting API',)
alexaapi.get_dnd_state((<alexapy.alexalogin.AlexaLogin object at 0x7f6272c72c10>,), {}): An error occured accessing AlexaAPI: An exception of type AlexapyLoginError occurred. Arguments: ('Login error detected; not contacting API',)
alexaapi.get_device_preferences((<alexapy.alexalogin.AlexaLogin object at 0x7f6272c72c10>,), {}): An error occured accessing AlexaAPI: An exception of type AlexapyLoginError occurred. Arguments: ('Login error detected; not contacting API',)
J’ai enfin reussi au bout de 2h,
1° supprimer l’integration
2° redemarrer
3° Reinstaller l’integration HACS alexa
4° redemarrer
5° il vous cree un new device donc vous pourvez mettre votre code 2FA
