Récupère info de mon onduleur
Super. Alors du coup comment as-tu procédé ?
Ce serait intéressant de connaître comment tu t y es pris.
je vais faire des photo de tous et je posterais le code en même temps
je continuerais a poste en fonction de l’évolutions des découvertes
oui car la liste est comme ca
les codes suivant les opsion voulus
corespondance suivant la doc de votre onduleur
commenter la ligne pour d’eactive l’option
# interval:
   # - interval: 2s
     # then:
        # - uart.write: "Q1\r"   ##"\x51\x31\x1B\xFC\x0D"                               #"Q1"
        # - delay: 2s
        # - uart.write: "QPI\r"  ##"\x51\x50\x49\x82\x61\x0D"                           #"QPI"
        # - delay: 2s
        # - uart.write: "QID\r"  ##"\x51\x49\x44\x18\x0B\x0D"                           #"QID"
        # - delay: 2s
        # - uart.write: "QVFW\r"  ##"\x51\x56\x46\x57\x67\x3E\x0D"                      #"QVFW"
        # - delay: 2s
        # - uart.write: "QVFW2\r"  ##"\x51\x56\x46\x57\x32\xA3\xD5\x0D"                 #"QVFW2"
        # - delay: 2s
        # - uart.write: "QVFW3\r" ##"\x51\x46\x4C\x41\x47\x25\x43\x0D"                  #"QVFW3"
        # - delay: 2s
        # - uart.write: "QPIGS\r"  ##"\x51\x50\x49\x47\x53\xB7\xA9\x0D"                 #"QPIGS"
        # - delay: 2s
        # - uart.write: "QMOD\r"  ##"\x51\x4D\x4F\x44\x96\x1F\x0D"                      #"QMOD"
        # - delay: 2s
        # - uart.write: "QPIWS\r"  ##"\x51\x50\x49\x57\x53\xE8\x95\x0D"                 #"QPIWS"
        # - delay: 2s
        # - uart.write: "QDI\r"  ##"\x51\x44\x49\x71\x1B\x0D"                           #"QDI"
        # - delay: 2s
        # - uart.write: "QMCHGCR\r"  ##"\x51\x4D\x43\x48\x47\x43\x52\xD8\x55\x0D"       #"QMCHGCR"
        # - delay: 2s
        # - uart.write: "QMUCHGCR\r"  ##"\x51\x4D\x55\x43\x48\x47\x43\x52\x26\x34\x0D"  #"QMUCHGCR"
        # - delay: 2s
        # - uart.write: "QBOOT\r"  ##"\x51\x42\x4F\x4F\x54\x0A\x88\x0D"                 #"QBOOT"
        # - delay: 2s
        # - uart.write: "QOPM\r"  ##"\x51\x4F\x50\x4D\xA5\xC5\x0D"                      #"QOPM"
        # - delay: 2s
        # - uart.write: "QPIRI\r" ## "\x51\x50\x49\x52\x49\xF8\x54\x0D"                 #"QPIRI"
        # - delay: 2s
        # - uart.write: "QPGS0\r"  ##"\x51\x50\x47\x53\x30\x3F\xDA\x0D"                 #"QPGS0"
        # - delay: 2s
        # - uart.write: "QBV\r"  ##"\x51\x42\x56\x38\x63\x0D"                           #"QBV"
        # - delay: 2s
        # - uart.write: "PF\r"  ##"\x50\x46\x26\xBD\x0D"                                #"PF"
        # - delay: 2s
        # - uart.write: "POP02\r"  ##"\x50\x4F\x50\x30\x32\xE2\x0A\x0D"   #"POP02"
        # - delay: 2s
        # - uart.write: "POP01\r"  ##"\x50\x4F\x50\x30\x31\xD2\x69\x0D"   #"POP01"
        # - delay: 2s
        # - uart.write: "POP00\r"  ##"\x50\x4F\x50\x30\x30\xC2\x48\x0D"   #"POP00"
        # - delay: 2s
        # - uart.write: "PCP00\r" ## "\x50\x43\x50\x30\x30\x8D\x7A\x0D"   #"PCP00"
        # - delay: 2s
        # - uart.write: "PCP01\r"  ##"\x50\x43\x50\x30\x31\x9D\x5B\x0D"   #"PCP01"
        # - delay: 2s
        # - uart.write: "PCP02\r"  ##"\x50\x43\x50\x30\x32\xAD\x38\x0D"   #"PCP02"
        # - delay: 2s
        # - uart.write: " MUCHGC002\r"  ##"\x4D\x55\x43\x48\x47\x43\x30\x30\x32\xB5\xD1\x0D"   #"MUCHGC002"
        # - delay: 2s
        # - uart.write: "MUCHGC010\r"  ##"\x4D\x55\x43\x48\x47\x43\x30\x31\x30\xA6\xA2\x0D"    #"MUCHGC010"
        # - delay: 2s
        # - uart.write: "MUCHGC020\r"  ##"\x4D\x55\x43\x48\x47\x43\x30\x32\x30\xF3\xF1\x0D"    #"MUCHGC020"
        # - delay: 2s
        # - uart.write: "MUCHGC030\r"  ##"\x4D\x55\x43\x48\x47\x43\x30\x33\x30\xC0\xC0\x0D"    #"MUCHGC030"
        # - delay: 2s
        # - uart.write: "PPCP000\r"  ##"\x50\x50\x43\x50\x30\x30\x30\xE6\xE1\x0D"              #"PPCP000"
        # - delay: 2s
        # - uart.write: "PPCP001\r" ##"\x50\x50\x43\x50\x30\x30\x31\xF6\xC0\x0D"               #"PPCP001"
        # - delay: 2s
        # - uart.write: "PPCP002\r " ##"\x50\x50\x43\x50\x30\x30\x32\xC6\xA3\x0D"              #"PPCP002
        # - delay: 2s
        # - uart.write: "QPIGS2\r"  ##"\x51\x50\x49\x47\x53\x32\x68\x2D\x0D"                   #"QPIGS2"
        # - delay: 2s
        # - uart.write: "POP03\r" ## "\x50\x4F\x50\x30\x33\xF2\x2B\x0D"                        #"POP03"
        # - delay: 2s   `
 et je suppose qu'il faut y mettre  des   "" sensor    binary sensor  texte select    ect dans chaque ligne
