Quelqu’un ayant un nvr Réolink et ayant fait la dernière MAJ a-t-il le même problème que moi ?
Ca ne fonctionne plus, et quand je tente une nouvelle intégration, j’ai une 'erreur inconnue dès le module d’ip/login.
J’ai çà dans les journaux, mais je ne sais pas ce qui bug*.
Cette erreur provient d’une intégration personnalisée
Logger: custom_components.reolink_dev.config_flow
Source: custom_components/reolink_dev/base.py:219
Integration: Reolink IP camera (documentation, issues)
First occurred: 17:39:29 (2 occurrences)
Last logged: 17:40:03
Unexpected exception
File "/usr/local/lib/python3.10/site-packages/aiohttp/connector.py", line 986, in _wrap_create_connection
return await self._loop.create_connection(*args, **kwargs) # type: ignore[return-value] # noqa
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 1089, in create_connection
transport, protocol = await self._create_connection_transport(
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 1119, in _create_connection_transport
await waiter
File "/usr/local/lib/python3.10/asyncio/sslproto.py", line 534, in data_received
ssldata, appdata = self._sslpipe.feed_ssldata(data)
File "/usr/local/lib/python3.10/asyncio/sslproto.py", line 188, in feed_ssldata
self._sslobj.do_handshake()
File "/usr/local/lib/python3.10/ssl.py", line 975, in do_handshake
ssl.SSLError: [SSL: SSLV3_ALERT_HANDSHAKE_FAILURE] sslv3 alert handshake failure (_ssl.c:997)
The above exception was the direct cause of the following exception:
File "/config/custom_components/reolink_dev/config_flow.py", line 70, in async_step_user
self.info = await self.async_validate_input(self.hass, user_input)
File "/config/custom_components/reolink_dev/config_flow.py", line 138, in async_validate_input
if not await self.base.connect_api():
File "/config/custom_components/reolink_dev/base.py", line 219, in connect_api
if not await self._api.get_settings():
File "/usr/local/lib/python3.10/site-packages/reolink/camera_api.py", line 496, in get_settings
response = await self.send(body)
File "/usr/local/lib/python3.10/site-packages/reolink/camera_api.py", line 1652, in send
if not await self.login():
File "/usr/local/lib/python3.10/site-packages/reolink/camera_api.py", line 845, in login
response = await self.send(body, param)
File "/usr/local/lib/python3.10/site-packages/reolink/camera_api.py", line 1696, in send
async with session.post(
File "/usr/local/lib/python3.10/site-packages/aiohttp/client.py", line 1138, in __aenter__
self._resp = await self._coro
File "/usr/local/lib/python3.10/site-packages/aiohttp/client.py", line 535, in _request
conn = await self._connector.connect(
File "/usr/local/lib/python3.10/site-packages/aiohttp/connector.py", line 542, in connect
proto = await self._create_connection(req, traces, timeout)
File "/usr/local/lib/python3.10/site-packages/aiohttp/connector.py", line 907, in _create_connection
_, proto = await self._create_direct_connection(req, traces, timeout)
File "/usr/local/lib/python3.10/site-packages/aiohttp/connector.py", line 1206, in _create_direct_connection
raise last_exc
File "/usr/local/lib/python3.10/site-packages/aiohttp/connector.py", line 1175, in _create_direct_connection
transp, proto = await self._wrap_create_connection(
File "/usr/local/lib/python3.10/site-packages/aiohttp/connector.py", line 990, in _wrap_create_connection
raise ClientConnectorSSLError(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorSSLError: Cannot connect to host 192.168.2.14:443 ssl:default [[SSL: SSLV3_ALERT_HANDSHAKE_FAILURE] sslv3 alert handshake failure (_ssl.c:997)]
