Bonjour a tous,
Je possede 3 pzem V3 sous esphome mais je n’arrive pas a faire un reset des valeurs j’ai le message suivant
INFO Reading configuration /config/esphome/3pzem.yaml...
INFO Detected timezone 'Europe/Paris'
Failed config
esphome: None
on_boot: None
- None
priority: -100.0
then: None
- None
pzemac.reset_energy: None
Couldn't find ID 'pzemac_1'. Please check you have defined an ID with that name in your configuration. These IDs look similar: "pzem".
build_path: .esphome/build/3pzem
platformio_options: {}
includes: []
libraries: []
name_add_mac_suffix: False
voici mon fichier
esphome:
platform: ESP8266
board: d1_mini
on_boot:
## configure controller settings at setup
## make sure priority is lower than setup_priority of modbus_controller
priority: -1
then:
- pzemac.reset_energy: pzemac_1
######## define adresss ########
# on_boot:
# priority: -100
# then:
# - lambda: |-
# auto new_address = 2; # adress destination
# if(new_address < 1 || new_address > 7) // sanity check
# ESP_LOGE("ModbusLambda", "Address needs to be between 0x01 and 0xF7");
# return;
# esphome::modbus_controller::ModbusController *controller = id(pzem);
# auto set_addr_cmd = esphome::modbus_controller::ModbusCommandItem::create_write_single_command(
# controller, 0x0002, new_address);
# delay(200) ;
# controller->queue_command(set_addr_cmd);
# ESP_LOGI("ModbusLambda", "PZEM Addr set");
#modbus:
# send_wait_time: 200ms
# id: mod_bus_pzem
#modbus_controller:
# - id: pzem
## the current device addr
# address: 3 # adresss source du PZEM
# modbus_id: mod_bus_pzem
# command_throttle: 0ms
# setup_priority: -10
# update_interval: 30s
# Enable logging
logger:
baud_rate: 0 # (UART logging interferes with pzem)
level: DEBUG
# Enable Home Assistant API
api:
ota:
password: "b6a4df3aca1d8b31c86d594edfadbb87"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "3Pzem Fallback Hotspot"
password: "nBqz0FUQIIt0"
captive_portal:
i2c:
sda: GPIO4
scl: GPIO5
scan: true
uart:
- id: ubus1
tx_pin: D6
rx_pin: D5
baud_rate: 9600
stop_bits: 1 #pour un ESP8266, essayer plutôt la valeur 1
time:
platform: sntp
on_time:
- seconds: 57
minutes: 59
hours: 23
then:
- sensor.template.publish:
state: !lambda return id(enedis_puissance_du_jour).state;
#### PZEM L'etage' ######
- platform: pzemac
address: 1
current:
accuracy_decimals: 2
voltage:
power:
unit_of_measurement: W
frequency:
unit_of_measurement: Hz
power_factor:
energy:
unit_of_measurement: Wh
accuracy_decimals: 1
update_interval: 5s
unit_of_measurement: "kWh"
update_interval: 5s
icon: mdi:power
lambda: return (( (id(p2_energy).state)/1000.0));
- platform: total_daily_energy
power_id: p2_puissance
filters:
# Multiplication factor from W to kW is 0.001
- multiply: 0.001
icon: mdi:counter
unit_of_measurement: "kwh"
icon: mdi:power
update_interval: 10s
unit_of_measurement: "VA"
icon: mdi:power
lambda: return ( (id(p2_puissance).state/id(p2_facteur_puissance).state));
unit_of_measurement: "VAr"
icon: mdi:power
#lambda: return ( ((id(enedis_puissance_reactive).state)*sin(acos((id(enedis_facteur_puissance).state))) ) );
lambda: return ( ( sqrt( (id(p2_puissance_reactive).state)*(id(p2_puissance_reactive).state) - (id(p2_facteur_puissance).state)*(id(p2_facteur_puissance).state) ) ) );
#### PZEM-ENEDIS ####
- platform: pzemac
address: 2
current:
voltage:
power:
frequency:
power_factor:
energy:
update_interval: 5s
update_interval: 5s
icon: mdi:power
lambda: return (( (id(enedis_energy).state)/1000.0));
power_id: enedis_puissance
filters:
- multiply: 0.001
icon: mdi:counter
icon: mdi:power
icon: mdi:power
lambda: return ( (id(enedis_puissance).state/id(enedis_facteur_puissance).state));
icon: mdi:power
lambda: return ( ( sqrt( (id(enedis_puissance_reactive).state)*(id(enedis_puissance_reactive).state) - (id(enedis_facteur_puissance).state)*(id(enedis_facteur_puissance).state) ) ) );
#### Pzem PV ######
- platform: pzemac
address: 3
current:
voltage:
power:
frequency:
power_factor:
energy:
update_interval: 5s
update_interval: 5s
icon: mdi:power
lambda: return (( (id(pv_energy).state)/1000.0));
power_id: pv_puissance
filters:
- multiply: 0.001
icon: mdi:counter
icon: mdi:power
icon: mdi:power
lambda: return ( (id(pv_puissance).state/id(pv_facteur_puissance).state));
icon: mdi:power
lambda: return ( ( sqrt( (id(pv_puissance_reactive).state)*(id(pv_puissance_reactive).state) - (id(pv_facteur_puissance).state)*(id(pv_facteur_puissance).state) ) ) );
- platform: wifi_signal
- platform: uptime
switch:
- platform: restart
binary_sensor:
- platform: status
text_sensor:
lambda: |-
int seconds = (id(uptime_sec).state);
int days = seconds / (24 * 3600);
seconds = seconds % (24 * 3600);
int hours = seconds / 3600;
seconds = seconds % 3600;
int minutes = seconds / 60;
seconds = seconds % 60;
return { (String(days) +"d " + String(hours) +"h " + String(minutes) +"m "+ String(seconds) +"s").c_str() };
icon: mdi:clock-start
update_interval: 113s
Je vous remercie pour votre aide
System Health
version |
core-2022.2.3 |
installation_type |
Home Assistant Supervised |
dev |
false |
hassio |
true |
docker |
true |
user |
root |
virtualenv |
false |
python_version |
3.9.7 |
os_name |
Linux |
os_version |
4.19.0-17-amd64 |
arch |
x86_64 |
timezone |
Europe/Paris |
GitHub API |
ok |
Github API Calls Remaining |
5000 |
Installed Version |
1.22.0 |
Stage |
running |
Available Repositories |
988 |
Downloaded Repositories |
70 |
AccuWeather
can_reach_server |
ok |
remaining_requests |
49 |
logged_in |
false |
can_reach_cert_server |
ok |
can_reach_cloud_auth |
ok |
can_reach_cloud |
ok |
host_os |
Debian GNU/Linux 10 (buster) |
update_channel |
beta |
supervisor_version |
supervisor-2022.01.1 |
docker_version |
20.10.8 |
disk_total |
113.6 GB |
disk_used |
20.1 GB |
healthy |
true |
supported |
failed to load: Unsupported |
supervisor_api |
ok |
version_api |
ok |
installed_addons |
Samba share (9.5.1), MQTT Server & Web client (1.2.0), Terminal & SSH (9.3.0), Spotify Connect (0.10.0), Grafana (7.4.1), Tydom2MQTT - Beta (release_v1.2.4), InfluxDB (4.3.0), Glances (0.14.2), Dnsmasq (1.4.4), Duck DNS (1.14.0), Studio Code Server (4.1.0), File editor (5.3.3), Zigbee2mqtt (1.23.0-1), Zigbee2mqtt Edge (edge), ESPHome (2022.1.3), Node-RED (10.4.0), Check Home Assistant configuration (3.9.0), Mosquitto broker (6.0.1) |
Lovelace
dashboards |
3 |
resources |
45 |
views |
17 |
mode |
storage |
Spotify
api_endpoint_reachable |
ok |
J’ai également 3 PZEM sur un ESP32, et j’ai qq soucis sur le reset automatique des 3 simultanément, alors qu’ils fonctionnent avec un bouton…
En tout cas, il faudrait commencer par les identifier dans ta config :
- platform: pzemac
address: 1
Pour pouvoir ensuite faire un reset dessus :
button:
on_press:
then:
- pzemac.reset_energy: pzem1
- logger.log: "Energy Reset 1"
on_press:
then:
- pzemac.reset_energy: pzem2
- logger.log: "Energy Reset 2"
on_press:
then:
- pzemac.reset_energy: pzem3
- logger.log: "Energy Reset 3"
Damien.
