[Resolu] Erreur lors du démarrage de l'addon Open Thread Border Router
j’ai acheté slzb-mr4u qui fait zigbee et thread sur 2 antennes différentes.
Pour zigbee, l’installation est opérationnelle, pour thread j’ai cette erreur :
[15:59:02] INFO: Enabled socat-otbr-tcp.
s6-rc: info: service socat-otbr-tcp: starting
s6-rc: info: service mdns: starting
s6-rc: info: service mdns successfully started
s6-rc: info: service banner: starting
[15:59:02] INFO: Starting mDNS Responder...
Default: mDNSResponder (Engineering Build) (Dec 15 2025 09:14:53) starting
[15:59:02] INFO: Starting socat TCP client for OTBR daemon...
 Add-on: OpenThread Border Router
 OpenThread Border Router add-on
 Add-on version: 2.15.3
 You are running the latest version of this add-on.
 System: Home Assistant OS 16.3  (amd64 / generic-x86-64)
 Home Assistant Core: 2026.1.2
 Home Assistant Supervisor: 2026.01.1
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service banner successfully started
s6-rc: info: service socat-otbr-tcp successfully started
s6-rc: info: service otbr-agent: starting
[15:59:02] INFO: Setup OTBR firewall...
[15:59:02] INFO: Migrating OTBR settings if needed...
2026-01-18 15:59:02 homeassistant asyncio[246] DEBUG Using selector: EpollSelector
2026-01-18 15:59:02 homeassistant zigpy.serial[246] DEBUG Opening a serial connection to '/tmp/ttyOTBR' (baudrate=460800, xonxoff=False, rtscts=False)
2026-01-18 15:59:02 homeassistant serialx.platforms.serial_posix[246] DEBUG Configuring serial port '/tmp/ttyOTBR'
2026-01-18 15:59:02 homeassistant serialx.platforms.serial_posix[246] DEBUG Configuring serial port: [0, 0, 3248, 0, 4100, 4100, [b'\x03', b'\x1c', b'\x7f', b'\x15', b'\x04', 0, 0, b'\x00', b'\x11', b'\x13', b'\x1a', b'\x00', b'\x12', b'\x0f', b'\x17', b'\x16', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00', b'\x00']]
2026-01-18 15:59:02 homeassistant serialx.platforms.serial_posix[246] DEBUG Setting low latency mode: True
2026-01-18 15:59:02 homeassistant serialx.platforms.serial_posix[246] DEBUG Device is not a serial port, cannot set low latency
2026-01-18 15:59:02 homeassistant serialx.platforms.serial_posix[246] DEBUG Setting modem pins: ModemPins[!dtr !rts]
2026-01-18 15:59:02 homeassistant serialx.platforms.serial_posix[246] DEBUG TIOCMBIC: 0x00000006
2026-01-18 15:59:02 homeassistant serialx.platforms.serial_posix[246] DEBUG Device is not a serial port, cannot set modem pins
2026-01-18 15:59:02 homeassistant zigpy.serial[246] DEBUG Connection made: <serialx.platforms.serial_posix.PosixSerialTransport object at 0x7ff6d265f950>
2026-01-18 15:59:02 homeassistant universal_silabs_flasher.spinel[246] DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=0, network_link_id=0, flag=2), command_id=<CommandID.RESET: 1>, data=b'\x02')
2026-01-18 15:59:02 homeassistant universal_silabs_flasher.spinel[246] DEBUG Sending data b'~\x80\x01\x02\xea\xf0~'
2026-01-18 15:59:02 homeassistant serialx.descriptor_transport[246] DEBUG Immediately writing b'~\x80\x01\x02\xea\xf0~'
2026-01-18 15:59:02 homeassistant serialx.descriptor_transport[246] DEBUG Sent 7 of 7 bytes
2026-01-18 15:59:02 homeassistant serialx.descriptor_transport[246] DEBUG Event loop woke up reader
2026-01-18 15:59:02 homeassistant serialx.descriptor_transport[246] DEBUG Received b'~\x80\x06\x00p\xeet~'
2026-01-18 15:59:02 homeassistant universal_silabs_flasher.spinel[246] DEBUG Decoded HDLC frame: HDLCLiteFrame(data=b'\x80\x06\x00p')
2026-01-18 15:59:02 homeassistant universal_silabs_flasher.spinel[246] DEBUG Parsed frame SpinelFrame(header=SpinelHeader(transaction_id=0, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_IS: 6>, data=b'\x00p')
2026-01-18 15:59:02 homeassistant universal_silabs_flasher.spinel[246] DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x08')
2026-01-18 15:59:02 homeassistant universal_silabs_flasher.spinel[246] DEBUG Sending data b'~\x83\x02\x08\xbc\x9a~'
2026-01-18 15:59:02 homeassistant serialx.descriptor_transport[246] DEBUG Immediately writing b'~\x83\x02\x08\xbc\x9a~'
2026-01-18 15:59:02 homeassistant serialx.descriptor_transport[246] DEBUG Received b'~\x83\x06\x08\x00\x12K\x003\xc7|\xccF\xe3~'
2026-01-18 15:59:02 homeassistant universal_silabs_flasher.spinel[246] DEBUG Decoded HDLC frame: HDLCLiteFrame(data=b'\x83\x06\x08\x00\x12K\x003\xc7|\xcc')
2026-01-18 15:59:02 homeassistant universal_silabs_flasher.spinel[246] DEBUG Parsed frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_IS: 6>, data=b'\x08\x00\x12K\x003\xc7|\xcc')
2026-01-18 15:59:02 homeassistant serialx.descriptor_transport[246] DEBUG Closing at the request of the application
2026-01-18 15:59:02 homeassistant zigpy.serial[246] DEBUG Waiting for serial port to close
2026-01-18 15:59:02 homeassistant serialx.descriptor_transport[246] DEBUG Closing connection: None
2026-01-18 15:59:02 homeassistant serialx.descriptor_transport[246] DEBUG Closing file descriptor 7
2026-01-18 15:59:02 homeassistant serialx.descriptor_transport[246] DEBUG Calling protocol `connection_lost` with exc=None
2026-01-18 15:59:02 homeassistant zigpy.serial[246] DEBUG Connection lost: None
Adapter settings file /data/thread/0_124b0033c77ccc.data is the most recently used, skipping
[15:59:02] INFO: Starting otbr-agent...
[NOTE]-AGENT---: Running 0.3.0-b067e5ac-dirty
[NOTE]-AGENT---: Thread version: 1.3.0
tiocmbic: Inappropriate ioctl for device
[NOTE]-AGENT---: Thread interface: wpan0
[NOTE]-AGENT---: Radio URL: spinel+hdlc+uart:///tmp/ttyOTBR?uart-baudrate=460800&uart-init-deassert
[NOTE]-AGENT---: Radio URL: trel://enp0s31f6
[NOTE]-ILS-----: Infra link selected: enp0s31f6
49d.17:55:26.928 [C] P-SpinelDrive-: Software reset co-processor successfully
00:00:00.072 [N] RoutingManager: BR ULA prefix: fdf9:720e:8ae9::/48 (loaded)
00:00:00.072 [N] RoutingManager: Local on-link prefix: fd32:c101:4daf:de9f::/64
00:00:00.099 [N] Mle-----------: Role disabled -> detached
00:00:00.106 [N] P-Netif-------: Changing interface state to up.
00:00:00.119 [W] P-Netif-------: Failed to process request#2: No such process
00:00:00.120 [W] P-Netif-------: Failed to process request#6: No such process
s6-rc: info: service otbr-agent successfully started
s6-rc: info: service otbr-agent-configure: starting
Done
s6-rc: info: service otbr-agent-configure successfully started
s6-rc: info: service otbr-agent-rest-discovery: starting
[15:59:03] INFO: Successfully sent discovery information to Home Assistant.
s6-rc: info: service otbr-agent-rest-discovery successfully started
00:00:27.215 [N] Mle-----------: RLOC16 1000 -> fffe
00:00:27.277 [N] Mle-----------: Attach attempt 1, AnyPartition reattaching with Active Dataset
00:00:33.777 [N] RouterTable---: Allocate router id 4
00:00:33.777 [N] Mle-----------: RLOC16 fffe -> 1000
00:00:33.782 [N] Mle-----------: Role detached -> leader
00:00:33.782 [N] Mle-----------: Partition ID 0x1f614422
[NOTE]-BBA-----: BackboneAgent: Backbone Router becomes Primary!
00:00:35.713 [W] DuaManager----: Failed to perform next registration: NotFound
J’ai tenté pas mal de choses mais sans succès.
Ça semble pourtant ok
J’ai eu le même problème avec le SLZB-MR1
J’ai pu le régler (après m’être bien énervé) en reflashant le firmware (même dernière version depuis l’interface firmware update
Le module complémentaire OT border router. Démarré immédiatement ensuite.
Bizzare
Merci j’ai résolu le problème de mon côté aussi.
J’ai tenté pas mal de choses donc je ne sais pas ce qui a réglé le problème in finé.
Par exemple, mon coordinateur était branché sur une borne Deco xe75 qui a son propre routeur donc c’était peut être ça …
Pour ceux qui ont des problèmes exclusivement avec Thread/matter, une des choses importantes a faire, c’est simplifier au max son réseau entre le coordinateur et le hote home assistant.
