Hello, cela aura tenu presque 2 jours avant que Z2M plante.
Je peux donc exclure les problèmes d’USB du DELL Optiplex vu que j’obtiens les mêmes messages d’erreur sur ce PC portable Toshiba de test.
[09:14:48] INFO: Preparing to start...
[09:14:48] INFO: Socat not enabled
[09:14:48] INFO: Zigbee Herdsman debug logging enabled
[09:14:49] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:debug 2023-08-31 09:14:52: Loaded state from file /config/zigbee2mqtt/state.json
Zigbee2MQTT:info 2023-08-31 09:14:52: Logging to console and directory: '/config/zigbee2mqtt/log/2023-08-31.09-14-52' filename: log.txt
Zigbee2MQTT:debug 2023-08-31 09:14:52: Removing old log directory '/config/zigbee2mqtt/log/2023-08-31.06-36-17'
Zigbee2MQTT:info 2023-08-31 09:14:52: Starting Zigbee2MQTT version 1.32.2 (commit #unknown)
Zigbee2MQTT:info 2023-08-31 09:14:52: Starting zigbee-herdsman (0.17.2)
Zigbee2MQTT:debug 2023-08-31 09:14:52: Using zigbee-herdsman with settings: '{"adapter":{"concurrent":null,"delay":null,"disableLED":false},"backupPath":"/config/zigbee2mqtt/coordinator_backup.json","databaseBackupPath":"/config/zigbee2mqtt/database.db.backup","databasePath":"/config/zigbee2mqtt/database.db","network":{"channelList":[11],"extendedPanID":[221,221,221,221,221,221,221,221],"networkKey":"HIDDEN","panID":6754},"serialPort":{"adapter":"ezsp","path":"/dev/ttyACM0"}}'
2023-08-31T07:14:52.341Z zigbee-herdsman:adapter Failed to validate path: 'Error: spawn udevadm ENOENT'
2023-08-31T07:14:52.343Z zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11]},"serialPort":{"path":"/dev/ttyACM0","adapter":"ezsp"},"databasePath":"/config/zigbee2mqtt/database.db","databaseBackupPath":"/config/zigbee2mqtt/database.db.backup","backupPath":"/config/zigbee2mqtt/coordinator_backup.json","adapter":{"disableLED":false,"concurrent":null,"delay":null}}'
2023-08-31T07:14:52.346Z zigbee-herdsman:adapter:ezsp:uart Opening SerialPort with {"path":"/dev/ttyACM0","baudRate":115200,"rtscts":false,"autoOpen":false}
2023-08-31T07:14:52.357Z zigbee-herdsman:adapter:ezsp:uart Serialport opened
2023-08-31T07:14:52.357Z zigbee-herdsman:adapter:ezsp:uart Uart reseting
2023-08-31T07:14:52.358Z zigbee-herdsman:adapter:ezsp:uart --> Write reset
2023-08-31T07:14:52.360Z zigbee-herdsman:adapter:ezsp:uart --> [1ac038bc7e]
2023-08-31T07:14:52.362Z zigbee-herdsman:adapter:ezsp:uart -?- waiting reset
2023-08-31T07:14:53.448Z zigbee-herdsman:adapter:ezsp:uart <-- [8d70a021212aff]
2023-08-31T07:15:02.366Z zigbee-herdsman:adapter:ezsp:uart --> Error: Error: {"sequence":-1} after 10000ms
2023-08-31T07:15:02.367Z zigbee-herdsman:adapter:ezsp:driv Reset connection. Try 0
2023-08-31T07:15:02.368Z zigbee-herdsman:adapter:ezsp:driv Stop driver
2023-08-31T07:15:02.368Z zigbee-herdsman:adapter:ezsp:ezsp Stop ezsp
2023-08-31T07:15:02.369Z zigbee-herdsman:adapter:ezsp:ezsp Close ezsp
2023-08-31T07:15:02.369Z zigbee-herdsman:adapter:ezsp:driv Close driver
Error: Reset error: Error: {"sequence":-1} after 10000ms
at /app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:299:23
at Queue.executeNext (/app/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
