Resources lovelace
j’ai récemment, refait mon mini pc. j’ai fait des VM Proxmox.
j’ai repris HA depuis 0, j’ai tout réinstaller.
Quand je crée un tableau de bord, je n’ai pas accès a mes cards…
exemple: Mushroom
j’ai pourtant mit les lovelace:
lovelace:
  mode: yaml
  resources:
    [ { url: /hacsfiles/bar-card/bar-card.js,                               type: module },
      { url: /hacsfiles/button-card/button-card.js,                         type: module },
      { url: /hacsfiles/kiosk-mode/kiosk-mode.js,                           type: module },
      { url: /hacsfiles/light-entity-card/light-entity-card.js,             type: module },
      { url: /hacsfiles/light-popup-card/light-popup-card.js,               type: module },
      { url: /hacsfiles/lovelace-card-mod/card-mod.js,                      type: module },
      { url: /hacsfiles/lovelace-layout-card/layout-card.js,                type: module },
      { url: /hacsfiles/lovelace-slider-entity-row/slider-entity-row.js,    type: module },
      { url: /hacsfiles/lovelace-valetudo-map-card/valetudo-map-card.js,    type: module },
      { url: /hacsfiles/mini-graph-card/mini-graph-card-bundle.js,          type: module },
      { url: /hacsfiles/swipe-card/swipe-card.js,                           type: module },
      { url: /hacsfiles/lovelace-hui-element/hui-element.js,                type: module },
      { url: /hacsfiles/spotify-card/spotify-card.js,                       type: module },
      { url: /hacsfiles/mini-media-player/mini-media-player-bundle.js,      type: module },
      { url: /hacsfiles/vertical-stack-in-card/vertical-stack-in-card.js,   type: module },
      { url: /hacsfiles/lovelace-paper-buttons-row/paper-buttons-row.js,    type: module },
      { url: /hacsfiles/custom-ui/custom-ui.js,                             type: module },
      { url: /hacsfiles/lovelace-mushroom/mushroom.js,                      type: module },
      { url: '/local/calendar-card.js?v=31091',                             type: module },
      { url: '/local/stack-in-card.js?v=101',                               type: module },
      { url: '/local/custom_icons.js?v=25052001',                           type: module },
      { url: '/local/font.css',                                             type: css}   ]
d’où pensez vous que cela peut venir…
version core-2023.11.3
python_version 3.11.6
os_version 6.1.59
arch x86_64
GitHub API Calls Remaining 4970
Installed Version 1.33.0
Available Repositories 1346
Downloaded Repositories 18
host_os Home Assistant OS 11.1
supervisor_version supervisor-2023.11.3
agent_version 1.6.0
docker_version 24.0.6
disk_total 30.8 GB
disk_used 5.6 GB
board ova
installed_addons File editor (5.7.0), Terminal & SSH (9.8.1), Duck DNS (1.15.0), Home Assistant Google Drive Backup (0.111.1), Mosquitto broker (6.4.0), Zigbee2MQTT (1.33.2-1), NGINX Home Assistant SSL proxy (3.5.0), Samba share (12.1.0)
dashboards 3
resources 23
error /config/ui-lovelace.yaml not found
views 29
mode yaml
oldest_recorder_run 15 novembre 2023 à 10:07
current_recorder_run 25 novembre 2023 à 18:56
estimated_db_size 94.15 MiB
database_version 3.41.2
ta une mauvaise indexion.
exemple:
lovelace:
  mode: yaml
  resources:
    - url: /hacsfiles/bar-card/bar-card.js
      type: module
    - url: /hacsfiles/button-card/button-card.js
      type: module
Ohhh un grand merci. :ok_hand:
