voici la solution
[{"id":"b95a8177cf74187e","type":"group","z":"5ea524e2.ed04ac","style":{"stroke":"#999999","stroke-opacity":"1","fill":"none","fill-opacity":"1","label":true,"label-position":"nw","color":"#a4a4a4"},"nodes":["2c77bb4551c7228a","cfa035f49de5b824","f3d265ce24b50acf","69a6d88706a3eb2f","3cbcb92c112b2ab3","104e716d871c02a9","c7adc6afa1c0cb3a","e8bb449da04df82a","13ac797b3b0938f7","9d642ad122f6230d","92c34e2b2157ca3e","308da87c44a65bbc","833a2a401425981d","2b5433c1f7f3ed70","4671a11d7f03270e","b2995067f109caf3","9ddbf7c0a55c0c5d","b1795d622be60a39"],"x":34,"y":379,"w":1212,"h":422},{"id":"2c77bb4551c7228a","type":"comment","z":"5ea524e2.ed04ac","g":"b95a8177cf74187e","name":"Router 2 radiateur","info":"","x":150,"y":420,"wires":[]},{"id":"cfa035f49de5b824","type":"server-state-changed","z":"5ea524e2.ed04ac","g":"b95a8177cf74187e","name":"PV router","server":"d50a0baf.aca4d8","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.pv_router","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"pvrouter","valueType":"str"}],"x":140,"y":480,"wires":[["69a6d88706a3eb2f"]]},{"id":"f3d265ce24b50acf","type":"server-state-changed","z":"5ea524e2.ed04ac","g":"b95a8177cf74187e","name":"Dimmer router","server":"d50a0baf.aca4d8","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.dimmer_router","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"pvdimmer","valueType":"str"}],"x":150,"y":660,"wires":[["69a6d88706a3eb2f"]]},{"id":"69a6d88706a3eb2f","type":"join","z":"5ea524e2.ed04ac","g":"b95a8177cf74187e","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":370,"y":620,"wires":[["c7adc6afa1c0cb3a"]]},{"id":"3cbcb92c112b2ab3","type":"inject","z":"5ea524e2.ed04ac","g":"b95a8177cf74187e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"pvrouter","payload":"-400","payloadType":"num","x":150,"y":540,"wires":[["69a6d88706a3eb2f"]]},{"id":"104e716d871c02a9","type":"inject","z":"5ea524e2.ed04ac","g":"b95a8177cf74187e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"pvdimmer","payload":"100","payloadType":"num","x":150,"y":720,"wires":[["69a6d88706a3eb2f"]]},{"id":"c7adc6afa1c0cb3a","type":"function","z":"5ea524e2.ed04ac","g":"b95a8177cf74187e","name":"","func":"var pvdimmer = Number(msg.payload.pvdimmer);\nvar pvrouter = Number(msg.payload.pvrouter);\n\nnode.status({text:pvdimmer+\" \"+pvrouter});\n\nif (pvrouter <= -200 && pvdimmer >= 100) {\n msg.payload = 2;\n}\nelse {\n msg.payload = 3;\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":540,"y":620,"wires":[["e8bb449da04df82a"]]},{"id":"e8bb449da04df82a","type":"switch","z":"5ea524e2.ed04ac","g":"b95a8177cf74187e","name":"Filtre","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"2","vt":"str"},{"t":"eq","v":"3","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":690,"y":620,"wires":[["4671a11d7f03270e"],["9ddbf7c0a55c0c5d"]]},{"id":"13ac797b3b0938f7","type":"inject","z":"5ea524e2.ed04ac","g":"b95a8177cf74187e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"pvrouter","payload":"100","payloadType":"str","x":150,"y":580,"wires":[["69a6d88706a3eb2f"]]},{"id":"9d642ad122f6230d","type":"inject","z":"5ea524e2.ed04ac","g":"b95a8177cf74187e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"pvdimmer","payload":"40","payloadType":"str","x":150,"y":760,"wires":[["69a6d88706a3eb2f"]]},{"id":"92c34e2b2157ca3e","type":"api-call-service","z":"5ea524e2.ed04ac","g":"b95a8177cf74187e","name":"Lampe TV plus","server":"d50a0baf.aca4d8","version":3,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.lampe_tv","data":"","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":920,"y":600,"wires":[["833a2a401425981d"]]},{"id":"308da87c44a65bbc","type":"api-call-service","z":"5ea524e2.ed04ac","g":"b95a8177cf74187e","name":"Lampe TV Min","server":"d50a0baf.aca4d8","version":3,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.lampe_tv","data":"","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":920,"y":660,"wires":[["833a2a401425981d"]]},{"id":"833a2a401425981d","type":"debug","z":"5ea524e2.ed04ac","g":"b95a8177cf74187e","name":"","active":true,"tosidebar":true,"console":true,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1150,"y":620,"wires":[]},{"id":"2b5433c1f7f3ed70","type":"function","z":"5ea524e2.ed04ac","g":"b95a8177cf74187e","name":"","func":"newmsg = {};\n\n brightness = msg.data.attributes.brightness + 10;\n if (brightness < 30)\n { msg.payload = \"off\";}\n\n\nmsg.data = {\"brightness\":brightness};\n\nnewmsg.payload = { data: {\"brightness\":brightness} };\n\nreturn newmsg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":780,"y":500,"wires":[["92c34e2b2157ca3e"]]},{"id":"4671a11d7f03270e","type":"api-current-state","z":"5ea524e2.ed04ac","g":"b95a8177cf74187e","name":"etat","server":"d50a0baf.aca4d8","version":2,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"light.lampe_tv","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":370,"y":500,"wires":[["b1795d622be60a39"]]},{"id":"b2995067f109caf3","type":"function","z":"5ea524e2.ed04ac","g":"b95a8177cf74187e","name":"","func":"newmsg = {};\n\n brightness = msg.data.attributes.brightness - 10;\n if (brightness < 10)\n { msg.payload = \"off\";}\n\n\nmsg.data = {\"brightness\":brightness};\n\nnewmsg.payload = { data: {\"brightness\":brightness} };\n\nreturn newmsg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":740,"y":720,"wires":[["308da87c44a65bbc"]]},{"id":"9ddbf7c0a55c0c5d","type":"api-current-state","z":"5ea524e2.ed04ac","g":"b95a8177cf74187e","name":"etat","server":"d50a0baf.aca4d8","version":2,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"light.lampe_tv","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":370,"y":720,"wires":[["b2995067f109caf3"]]},{"id":"b1795d622be60a39","type":"api-call-service","z":"5ea524e2.ed04ac","g":"b95a8177cf74187e","name":"Lampe TV On","server":"d50a0baf.aca4d8","version":3,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.lampe_tv","data":"","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":560,"y":500,"wires":[["2b5433c1f7f3ed70"]]},{"id":"d50a0baf.aca4d8","type":"server","name":"Home Assistant","version":1,"legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
