Sensor.myenedis ou sensor.myelectricaldata
Bonsoir à vous
J’ai une petite question concernant les sensors pour MYELECTRICALDAT.
ils doivent s’appeler 'sensor.myenedis_0123456789 MyEnedis ou sensor.myelectricaldata
je ne les trouves pas dans ma configure et mes entités à par ceux d’ENEDIS
En vous remerciant
version | core-2023.10.3
dev | false
hassio | true
docker | true
user | root
virtualenv | false
python_version | 3.11.5
os_name | Linux
os_version | 6.1.21-v8
arch | aarch64
timezone | Europe/Paris
config_dir | /config
GitHub API | ok
GitHub Content | ok
GitHub Web | ok
GitHub API Calls Remaining | 4994
Installed Version | 1.33.0
Stage | running
Available Repositories | 1378
Downloaded Repositories | 26
</details>
logged_in | false
can_reach_cert_server | ok
can_reach_cloud_auth | ok
can_reach_cloud | ok
</details>
host_os | Home Assistant OS 11.0
update_channel | stable
supervisor_version | supervisor-2023.10.0
agent_version | 1.6.0
docker_version | 24.0.6
disk_total | 109.3 GB
disk_used | 12.3 GB
healthy | true
supported | true
board | rpi4-64
supervisor_api | ok
version_api | ok
installed_addons | File editor (5.6.0), Samba share (10.0.2), AirCast (3.6.1), motionEye (0.19.1), eWeLink Smart Home (1.4.3), Terminal & SSH (9.7.1), Example (7.0.4), Check Home Assistant configuration (3.11.0), Log Viewer (0.16.0), Duck DNS (1.15.0), Let's Encrypt (4.12.9), Advanced SSH & Web Terminal (15.1.0), Mosquitto broker (6.3.1), InfluxDB (4.8.0), MyElectricalData (0.9.2)
</details>
dashboards | 2
resources | 22
views | 2
mode | storage
</details>
oldest_recorder_run | 10 octobre 2023 à 14:00
current_recorder_run | 20 octobre 2023 à 17:21
estimated_db_size | 129.08 MiB
database_engine | sqlite
database_version | 3.41.2
</details>
<details><summary>Sonoff</summary>
version | 3.5.3 (a8c6d45)
cloud_online | 17 / 18
local_online | 17 / 17
debug | failed to load:
</details>
y a eu du changement dans les noms.
Chez moi c’est nommer sensor.linky_xxxxxxxxxxxxx_consumption.
Les entités sont créer par MQTT, tu les retrouvent dans appareils et services, dans l’intégration MQTT. Ta un appareil qui ce nomme Linky + numéro PDL et tu aura toutes les entités créer par MED.
Ok je regarde ceci demain car absent aujourd’hui
Je suis sur mon téléphone et voilà ce qu’il y a
En te remerciant
Voila, ces ca les entités , ta un appareil linky avec les entité consommation et un RTE EcoWatt pour les entitésj0 j+1 j+2.
Ok mais pourquoi je ne peux pas avoir une carte visible
Il te faut la carte pour MED. C’est celle que tu as ?
il faut la dernière beta v1.5.4.b3
bonsoir
merci pour le retour,
mais ou dois je mettre ce dossier car impossible de l’avoir avec HACS.
cdlt
Il y avais une mise à jour a faire c’est fait installation de la nouvelle carte faite après cette mise à jour mais toujours le même résultat
Faut ajouter la carte dans dépot personnalisé, elle y est pas par défaut dans HACS.
C’est décrit sur le github.
Dans un premier temps merci @WarC0zes pour ton aide sur les différents sujets, je regarde souvent les tips pour essayer d’appliquer les solutions :slight_smile:
Mais sur ce cas, je sèche… j’ai installé myenedis et myelectricaldata.
Au niveau installation :
Pour myelectricaldata:
  • Installation OK, tout est bien affiché dans l’option interface web utilisateur
  • Paramétrage : influxDB, MQTT => OK (en tout cas en terme de connexion).
    Voici ce qui remontent via Appareils et Services et MQTT
    mqtt
Au niveau sensors voici ce que je retrouve:
myenedis :
sensors1
Et pour myelectricaldata:
Du coup, si je peux avoir un coup de main svp, car j’ai passé toute la soirée d’hier à parcourir le forum sur les deux principaux sujets :
et /config/myelectricaldata/config.yaml est semble OK aussi en tout cas pas d’erreur lors du lancement du module et pas de traces d’erreurs sur les connexions.
J’ai déjà un doute sur le nom des senors et sur les modifications à appliquer.
pour MyElectricalData, ta un appareil dans MQTT qui s’appelle Linky_tonNuméroPDL et de même pour RTE. toutes les informations se trouve dans les attributs du sensor.
Recherche sensor.linky dans outils de dev / états.
Merci pour ton retour,
Oui, j’ai bien les informations suivantes pour le sensor
Et voici l’état des sensors pour sensor.linky:
Mais du coup, si je comprends bien, je n’aurai pas de sensor.myelectricaldata mais uniquement des sensor.linky_xxxx ?
Oui, ca changer de nom depuis. Chez pas pourquoi tu cherche des sensor.myelectricaldata , alors que dans les postes précédent ca parle de sensor.Linky.
Ah déjà cette info est importante ! je pensais avoir à renommer les sensors ou à devoir les déclarer dans un fichier sensors.yaml.
As-tu réussi à mettre en place ce type de carte avec le sensor.linky ?
Oui, faut utiliser c’est carte pour MED GitHub - MyElectricalData/content-card-linky: cardLinky comptatible with sensor apiEnedis
C’est pas la même que pour myenedis.
  - type: custom:content-card-linky
    entity: sensor.linky_xxxxxxxxxxxxxx_consumption
    showHistory: true
    showHeader: true
    showPeakOffPeak: true
    showIcon: true
    showInTableUnit: true
    showDayPrice: true
    showDayPriceHCHP: true
    showDayMaxPower: true
    showDayHCHP: true
    showDayName: short
    showError: true
    shoInformation: true
    showPrice: true
    showTitle: false
    showCurrentMonthRatio: true
    showMonthRatio: true
    showWeekRatio: true
    showYesterdayRatio: true
    showTitleLine: true
    showEcoWatt: true
    showEcoWattJ12: true
    showTempo: false
    titleName: Linky
    nbJoursAffichage: '7'
    showYearRatio: true
    showTitreLigne: true
    ewEntity: sensor.rte_ecowatt_j0
    ewEntityJ1: sensor.rte_ecowatt_j1
    ewEntityJ2: sensor.rte_ecowatt_j2
    tempoEntityInfo: sensor.edf_tempo_info
    tempoEntityJ0: sensor.rte_tempo_today
    tempoEntityJ1: sensor.rte_tempo_tomorrow
Ok très bien merci beaucoup, je vais tester cela ce soir !
Après, je vais essayer de mettre en place les cartes présentés ici: les-cartes-et-myelectricaldata
A voir sir le changement de
En :
>platform: template
  sensors:
    myelectricaldata_daily_cost:
      friendly_name: "Coût d'hier"
      unit_of_measurement: "€"
      value_template: "{{ states.sensor.linky_xxxxxxxxxxxxxx_consumption.attributes.daily_cost }}"
Ca devrais être bon en changeant le nom de l’entité et vérifier que les attributs ont les même noms.
Ok très bien ! Encore merci @WarC0zes !
Tout fonctionne :slight_smile: le top !
