L’integration est’elle toujours dispo sur HACS ? Je ne la trouve pas, ptetre raté qqchose d’evident ![]()
Le recherche myEnedis ne donne rien du coup je les ai tous fait défiler sans succes
Dans la documentation, il est indiqué d’ajouter le dépôt à HACS car l’intégration n’est pas disponible nativement.
L’as tu fait ?
Je ne connaissais pas cette alternative, merci
Hello tout le monde,
Ca dit quelque chose à quelqu’un cette erreur ? Affichée sur ma carte Lovelace.
Et voici ce qui est affiché dans mes logs :
Logger: myEnedis
Source: custom_components/myEnedis/sensorEnedis.py:41
First occurred: 10:08:15 PM (1 occurrences)
Last logged: 10:08:15 PM
myEnedis err I/O must be done in the executor; Use `await hass.async_add_executor_job()` at custom_components/myEnedis/myEnedis.py, line 114: response = session.post(url, params=params, data=json.dumps(data), headers=headers, timeout=30)
Logger: myEnedis
Source: custom_components/myEnedis/myEnedis.py:96
First occurred: 10:09:25 PM (36 occurrences)
Last logged: 10:40:10 PM
data : {"type": "daily_consumption", "usage_point_id": "pdl", "start": "2020-04-20", "end": "2020-04-22"}
Error JSON : {"tag":"enedis_return_ko","error_code":"no_data_found","description":"no measure found for this usage point","alert_user":true,"enedis_return":true,"support":"https://discord.gg/DfVJZme"}
data : {"type": "daily_consumption", "usage_point_id": "pdl", "start": "2020-04-01", "end": "2020-04-27"}
Error JSON : {"tag":"enedis_return_ko","error_code":"429","description":"Quota Q3 reached. Call threshold allowed on -18:-20:-7","alert_user":true,"enedis_return":true,"support":"https://discord.gg/DfVJZme"}
Logger: myEnedis
Source: custom_components/myEnedis/myEnedis.py:93
First occurred: 10:08:38 PM (6 occurrences)
myEnedis ...pdl update lancé, status precedent : True, lastCall :None
22423010100096 - Erreur call ERROR ('call', 'error', '429')
22423010100096 - last call : updateYesterdayConsumptionMaxPower
22423010100096 - last call : updateCurrentMonthLastYear
bonjour
je n’arrive pas a installer la custom card
j’ai ce message d’erreur
j’ai installer la custom-card par hacs
j’ai bien le fichier dans le dossier www. / community
après j’ajoute une carte perso en collant mon texte et après j’ai mon message d’erreur .
voila je dois rater une étape.
As-tu rafraîchi (actualisé) la page afin de recharger les ressources ?
Oui même redémarrer ha
Quand tu vas dans HACS puis frontend puis custom card ( … en haut à droite) vois tu tes 2 dépôts Enedis ?
Oui j’ai bien les deux
bonjour
j’ai réussi a installer la carte linky en redémarrant mon raspberry .
Mais j’ai un autre probleme
j’ai refait l’installation du module hacs mais toujours pareil
j’ai cette erreur dans le journal
Logger: homeassistant.components.http
Source: helpers/config_validation.py:738
Integration: HTTP (documentation, issues)
First occurred: 9:58:02 (1 occurrences)
Last logged: 9:58:02
The ‹ base_url › option near /config/configuration.yaml:5 is deprecated, please remove it from your configuration
je pense avoir un probleme dans mon fichier yaml
Si tu l’as vraiment installé depuis HACS, tu n’as pas besoin de créer ces lignes dans ton configuration.yaml.
oui j’ai installé depuis hacs
j’ai trouver mon probleme dans le yaml il manquait « sensor » avant
mais vu ce que tu me dit ca sert a rien
L’installation de l’intégration depuis HACS concerne seulement l’installation. ![]()
Son intégration se fait soit par l’interface graphique Configuration → Intégration → Ajouter une integration soit en YAML
En YAML, il y a besoin de redémarrer.
Dans tous les cas, l’idéal est d’installer depuis HACS
C’est infiniment plus simple et en plus permet d’être informé automatiquement des mises à jour
Super
Ça ne sert effectivement à rien si tu as installé depuis HACS et ensuite intégré dans le menu intégration qui te posera les bonnes questions concernant ton pdl, token et tarifs
Oui je suis d’accord mais installation et Intégration ne font pas la même chose.
C’est juste pour ne pas induire les débutant en erreur.
@Pbranly merci pour ta participation sur le forum et le support que tu apporte ici et ailleurs ![]()
Pourquoi je n’ai aucun retour sur NAN rapport à hier et rapport à semaine ?
Moi aussi NaN comme @sas
attribution: ''
version: 1.1.4.3
versionGit: 1.1.4.3
versionUpdateAvailable: false
typeCompteur: consommation
activationDate: '2021-03-26'
lastUpdate: '2021-05-02T11:16:35.909583'
timeLastCall: '2021-05-02T11:16:35.909574'
yesterday: 9725
last_week: 66470
yesterdayLastYear: 0
yesterdayConsumptionMaxPower: 3660
day_1_HP: 9725
day_2_HP: 11306
day_3_HP: 8086
day_4_HP: 8052
day_5_HP: 7489
day_6_HP: 8348
day_7_HP: 6719
day_1_HC: 0
day_2_HC: 0
day_3_HC: 0
day_4_HC: 0
day_5_HC: 0
day_6_HC: 0
day_7_HC: 0
dailyweek_cost:
- '0.00'
- '0.00'
- '0.00'
- '0.00'
- '0.00'
- '0.00'
- '0.00'
dailyweek_costHC:
- '0.00'
- '0.00'
- '0.00'
- '0.00'
- '0.00'
- '0.00'
- '0.00'
dailyweek_HC:
- '0.000'
- '0.000'
- '0.000'
- '0.000'
- '0.000'
- '0.000'
- '0.000'
dailyweek:
- '2021-05-01'
- '2021-04-30'
- '2021-04-29'
- '2021-04-28'
- '2021-04-27'
- '2021-04-26'
- '2021-04-25'
dailyweek_costHP:
- '0.00'
- '0.00'
- '0.00'
- '0.00'
- '0.00'
- '0.00'
- '0.00'
dailyweek_HP:
- '9.725'
- '11.306'
- '8.086'
- '8.052'
- '7.489'
- '8.348'
- '6.719'
day_1: '9.72'
day_2: '11.31'
day_3: '8.09'
day_4: '8.05'
day_5: '7.49'
day_6: '8.35'
day_7: '6.72'
daily:
- '9.72'
- '11.31'
- '8.09'
- '8.05'
- '7.49'
- '8.35'
- '6.72'
halfhourly: []
offpeak_hours: '0.000'
peak_hours: '9.725'
peak_offpeak_percent: '100.00'
yesterday_HC_cost: '0.000'
yesterday_HP_cost: '0.000'
daily_cost: '0.00'
yesterday_HC: '0.000'
yesterday_HP: '9.725'
current_week: '53.006'
errorLastCall: ''
errorLastCallInterne: ''
unit_of_measurement: kWh
