shido
1
je n’arrive pas a faire fonctionner ma sirène Heiman en utilisant le script ci-dessous
alarm_heiman_siren_2_turn_on:
alias: Heiman Siren 2 - Turn ON
sequence:
- service: mqtt.publish
topic: zigbee2mqtt/sirene/set
payload: '{"warning": {"duration": 1, "mode": "burglar", "level": "very_high",
"strobe": true}}'
icon: mdi:alarm-light-off
par contre le déclenchement se fait correctement en passant par zigbee2mqtt
Merci d’avance pour vos suggestions.
_
__
[center]## System Information
version |
core-2024.4.3 |
installation_type |
Home Assistant OS |
dev |
false |
hassio |
true |
docker |
true |
user |
root |
virtualenv |
false |
python_version |
3.12.2 |
os_name |
Linux |
os_version |
6.1.73-haos-raspi |
arch |
aarch64 |
timezone |
Europe/Paris |
config_dir |
/config |
GitHub API |
ok |
GitHub Content |
ok |
GitHub Web |
ok |
GitHub API Calls Remaining |
4996 |
Installed Version |
1.34.0 |
Stage |
running |
Available Repositories |
1401 |
Downloaded Repositories |
6 |
logged_in |
false |
can_reach_cert_server |
ok |
can_reach_cloud_auth |
ok |
can_reach_cloud |
ok |
host_os |
Home Assistant OS 12.2 |
update_channel |
stable |
supervisor_version |
supervisor-2024.04.0 |
agent_version |
1.6.0 |
docker_version |
25.0.5 |
disk_total |
57.3 GB |
disk_used |
6.6 GB |
healthy |
true |
supported |
true |
board |
rpi3-64 |
supervisor_api |
ok |
version_api |
ok |
installed_addons |
Mosquitto broker (6.4.0), Zigbee2MQTT (1.36.1-1), File editor (5.8.0), Terminal & SSH (9.13.0), ESPHome (2024.3.2) |
dashboards |
2 |
resources |
3 |
views |
6 |
mode |
storage |
oldest_recorder_run |
9 avril 2024 à 09:11 |
current_recorder_run |
16 avril 2024 à 21:50 |
estimated_db_size |
42.19 MiB |
database_engine |
sqlite |
database_version |
3.44.2 |
Sonoff
version |
3.6.0 (8dd8af9) |
cloud_online |
0 / 0 |
local_online |
0 / 0 |
debug |
failed to load: |
