En installant #solcast j’ai ce pb qui apparait : 500 Internal Server Error Server got itself in trouble
Dans les journaux j’ai ceci
Cette erreur provient d’une intégration personnalisée
Enregistreur: custom_components.solcast_solar.solcastapi
Source: custom_components/solcast_solar/solcastapi.py:576
intégration: Solcast PV Forecast (documentation, problèmes)
S'est produit pour la première fois: 17:38:20 (1 occurrences)
Dernier enregistrement: 17:38:20
HTTP session returned status 404/Not found in __sites_data(), trying cache
Alors que l’adresse utilisée pour la connexion fonctionne bien
| version |
core-2024.12.5 |
| installation_type |
Home Assistant OS |
| dev |
false |
| hassio |
true |
| docker |
true |
| user |
root |
| virtualenv |
false |
| python_version |
3.13.0 |
| os_name |
Linux |
| os_version |
6.6.66-haos |
| arch |
x86_64 |
| timezone |
Europe/Paris |
| config_dir |
/config |
| GitHub API |
ok |
| GitHub Content |
ok |
| GitHub Web |
ok |
| HACS Data |
ok |
5000 |
| Installed Version |
2.0.1 |
| Stage |
running |
| Available Repositories |
1498 |
| Downloaded Repositories |
9 |
| logged_in |
true |
| subscription_expiration |
25 décembre 2024 à 01:00 |
| relayer_connected |
true |
| relayer_region |
eu-central-1 |
| remote_enabled |
true |
| remote_connected |
true |
| alexa_enabled |
true |
| google_enabled |
true |
| cloud_ice_servers_enabled |
true |
| remote_server |
eu-central-1-24.ui.nabu.casa |
| certificate_status |
ready |
| instance_id |
7c41baf6b3eb462e81fa149bf8ca0ea0 |
| can_reach_cert_server |
ok |
| can_reach_cloud_auth |
ok |
| can_reach_cloud |
ok |
| host_os |
Home Assistant OS 14.1 |
| update_channel |
stable |
| supervisor_version |
supervisor-2024.12.0 |
| agent_version |
1.6.0 |
| docker_version |
27.2.0 |
| disk_total |
30.8 GB |
| disk_used |
9.7 GB |
| healthy |
true |
| supported |
true |
| host_connectivity |
true |
| supervisor_connectivity |
true |
| ntp_synchronized |
true |
| virtualization |
vmware |
| board |
ova |
| supervisor_api |
ok |
| version_api |
ok |
| installed_addons |
Terminal & SSH (9.16.0), Studio Code Server (5.17.3), Matter Server (6.6.1), Zigbee2MQTT (1.42.0-2), Mosquitto broker (6.4.1), Matterbridge (2.9.0-PSA-121), InfluxDB (5.0.1), Grafana (10.2.2) |
| dashboards |
2 |
| resources |
3 |
| views |
8 |
| mode |
storage |
| oldest_recorder_run |
11 décembre 2024 à 20:44 |
| current_recorder_run |
22 décembre 2024 à 12:38 |
| estimated_db_size |
334.06 MiB |
| database_engine |
sqlite |
| database_version |
3.45.3 |
Solcast PV Forecast
