Sonof Zigbee USB3 dongle Plus et canal 25
Bonjour a tous les processeurs de dongle USB sonoff.
Est-ce que vous avez réussi a la mettre sous le canal 25 ? voir un autre que le 11 avec Zigbee2MQTT ?
Pour info, sous ZHA il est en 15 mais meme en forçant la config a 25 ou 11 il ne le prend pas.
Merci a vous
Salut…
20 ça passe
Humm bizarre.
Sous le 11 ilmarche mais dès que je change il n’a pas l’air de changer dans la clé
Zigbee2MQTT:error 2023-01-19 18:35:06: Error: startup failed - configuration-adapter mismatch - see logs above for more information
    at ZnpAdapterManager.determineStrategy (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:229:35)
    at ZnpAdapterManager.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:63:26)
    at Zigbee.start (/app/lib/zigbee.ts:58:27)
    at Controller.start (/app/lib/controller.ts:101:27)
    at start (/app/index.js:107:5)
Using '/app/data' as data directory
Zigbee2MQTT:info  2023-01-19 18:35:20: Logging to console and directory: '/app/data/log/2023-01-19.18-35-20' filename: log.txt
Zigbee2MQTT:info  2023-01-19 18:35:20: Starting Zigbee2MQTT version 1.29.2 (commit #bb3e8f6)
Zigbee2MQTT:info  2023-01-19 18:35:20: Starting zigbee-herdsman (0.14.83-hotfix.0)
Zigbee2MQTT:error 2023-01-19 18:35:21: Configuration is not consistent with adapter state/backup!
Zigbee2MQTT:error 2023-01-19 18:35:21: - PAN ID: configured=6452, adapter=6452
Zigbee2MQTT:error 2023-01-19 18:35:21: - Extended PAN ID: configured=dd0ddddddddddddd, adapter=dd0ddddddddddddd
Zigbee2MQTT:error 2023-01-19 18:35:21: - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
Zigbee2MQTT:error 2023-01-19 18:35:21: - Channel List: configured=20, adapter=11
Zigbee2MQTT:error 2023-01-19 18:35:21: Please update configuration to prevent further issues.
Zigbee2MQTT:error 2023-01-19 18:35:21: If you wish to re-commission your network, please remove coordinator backup at /app/data/coordinator_backup.json.
Zigbee2MQTT:error 2023-01-19 18:35:21: Re-commissioning your network will require re-pairing of all devices!
Zigbee2MQTT:error 2023-01-19 18:35:21: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2023-01-19 18:35:21: Failed to start zigbee
Zigbee2MQTT:error 2023-01-19 18:35:21: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
35:21: Exiting...
J’ai deja
  • reset la clé,
  • reflashe plusieurs fois (via la methode docker)
  • essayé de changer directement via le fichier de conf
  • J’ai essayé d’ajouter mon user au group dialout (celui de la clé
Bizarre, j’ai rien.trouvé dans les issues, ni sur internet.
Versio z2mqtt 1.29.3 (dernière) sous docker.
les dossiers sont en root:root
Pas certain que tu puisse changer sans tout refaire
oui ce n'est pas un probleme je suis en train de migrer sur une VM de proxmox
Donc go sans oublier de virer coordinator_backup.json
c’est peut etre ca que je fais pas lol
enfin je l’ai deja lu donc j’ai du essayer mais a force d’essayer plein de truc on sait plus
il est dans /config/zigbee2mqtt/
Super merci, ben en recommençant à tête reposée, c’est good.
Depuis ce matin, je suis sur ça et le broker.
C’est enfin réglé, merci
