bonjour,
je suis sandro, 55ans de Nice
je viens de flasher mon 1er sonoff basic R2 sous ESP HOME avec ce code :
esphome:
esp8266:
board: esp8285
wifi:
ssid: !secret wifi_ssid
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
binary_sensor:
- platform: gpio
pin:
number: GPIO0
mode: INPUT_PULLUP
inverted: True
name: "Sonoff Basic Button"
on_press:
- switch.toggle: fakebutton
switch:
name: "Sonoff Basic Relay"
optimistic: true
turn_on_action:
- switch.turn_on: relay
- light.turn_on: led
turn_off_action:
- switch.turn_off: relay
- light.turn_off: led
- platform: gpio
pin: GPIO12
output:
- platform: esp8266_pwm
pin:
number: GPIO13
inverted: True
light:
- platform: monochromatic
name: "Sonoff Basic Green LED"
output: basic_green_led
- platform: wifi_signal
name: "Sonoff Basic WiFi Signal"
update_interval: 60s
- platform: uptime
name: "Sonoff Basic Uptime"
text_sensor:
- platform: version
name: "Sonoff Basic ESPHome Version"
sur l’interface esphom
je vois mon esp Prise-1 je le valide mais pour aucun résultat : rien pas d’entités!
Dans les logs en revanche j’ai une erreur :
INFO Reading configuration /config/esphome/prise-1.yaml...
INFO Starting log output from prise-1.local using esphome API
INFO Successfully connected to prise-1.local
[15:06:00][I][app:102]: ESPHome version 2022.11.3 compiled on Nov 27 2022, 15:03:50
[15:06:00][C][wifi:504]: WiFi:
[15:06:00][C][wifi:362]: Local MAC: 4C:EB:D6:C9:1A:76
[15:06:00][C][wifi:363]: SSID: 'XXX'[redacted]
[15:06:00][C][wifi:364]: IP Address: 192.168.1.193
[15:06:00][C][wifi:365]: BSSID: 1C:61:B4:4C:43:CB[redacted]
[15:06:00][C][wifi:367]: Hostname: 'prise-1'
[15:06:00][C][wifi:369]: Signal strength: -51 dB ▂▄▆█
[15:06:00][C][wifi:373]: Channel: 7
[15:06:00][C][wifi:374]: Subnet: 255.255.255.0
[15:06:00][C][wifi:375]: Gateway: 192.168.1.254 #freebox
[15:06:00][C][wifi:376]: DNS1: 192.168.1.254
[15:06:00][C][wifi:377]: DNS2: 0.0.0.0
[15:06:00][C][logger:293]: Logger:
[15:06:00][C][logger:294]: Level: DEBUG
[15:06:00][C][logger:295]: Log Baud Rate: 115200
[15:06:00][C][logger:296]: Hardware UART: UART0
[15:06:00][C][template.switch:058]: Template Switch 'Sonoff Basic Relay'
[15:06:00][C][template.switch:059]: Restore State: NO
[15:06:00][C][template.switch:060]: Optimistic: YES
[15:06:00][C][switch.gpio:050]: GPIO Switch 'relay'
[15:06:00][C][switch.gpio:051]: Pin: GPIO12
[15:06:00][C][switch.gpio:073]: Restore Mode: Restore (Defaults to OFF)
[15:06:00][C][esp8266_pwm:022]: ESP8266 PWM:
[15:06:00][C][esp8266_pwm:023]: Pin: GPIO13
[15:06:00][C][esp8266_pwm:024]: Frequency: 1000.0 Hz
[15:06:00][C][uptime.sensor:031]: Uptime Sensor 'Sonoff Basic Uptime'
[15:06:00][C][uptime.sensor:031]: Device Class: 'duration'
[15:06:00][C][uptime.sensor:031]: State Class: 'total_increasing'
[15:06:00][C][uptime.sensor:031]: Unit of Measurement: 's'
[15:06:00][C][uptime.sensor:031]: Accuracy Decimals: 0
[15:06:00][C][uptime.sensor:031]: Icon: 'mdi:timer-outline'
[15:06:00][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'Sonoff Basic Button'
[15:06:00][C][gpio.binary_sensor:016]: Pin: GPIO0
[15:06:00][C][light:104]: Light 'Sonoff Basic Green LED'
[15:06:00][C][light:106]: Default Transition Length: 1.0s
[15:06:00][C][light:107]: Gamma Correct: 2.80
[15:06:00][C][version.text_sensor:021]: Version Text Sensor 'Sonoff Basic ESPHome Version'
[15:06:00][C][version.text_sensor:021]: Icon: 'mdi:new-box'
[15:06:00][C][mdns:103]: mDNS:
[15:06:00][C][mdns:104]: Hostname: prise-1
[15:06:00][C][ota:093]: Over-The-Air Updates:
[15:06:00][C][ota:094]: Address: prise-1.local:8266
[15:06:00][C][api:138]: API Server:
[15:06:00][C][api:139]: Address: prise-1.local:6053
[15:06:00][C][api:143]: Using noise encryption: NO
[15:06:00][C][wifi_signal.sensor:009]: WiFi Signal 'Sonoff Basic WiFi Signal'
[15:06:00][C][wifi_signal.sensor:009]: Device Class: 'signal_strength'
[15:06:00][C][wifi_signal.sensor:009]: State Class: 'measurement'
[15:06:00][C][wifi_signal.sensor:009]: Unit of Measurement: 'dBm'
[15:06:00][C][wifi_signal.sensor:009]: Accuracy Decimals: 0
[15:06:04][D][sensor:126]: 'Sonoff Basic WiFi Signal': Sending state -55.00000 dBm with 0 decimals of accuracy
[15:06:32][D][api:102]: Accepted 192.168.1.229 #'homeassistant
[15:06:32][W][api.connection:085]: 192.168.1.229: Reading failed: BAD_INDICATOR errno=11
si quelqu’un pouvais m’aider
merci
