J’ai changé mon plan d’adressage IP,
reparamétré mon HA
changé les adresses des esp
tout marche bien sauf les mises à jour HACS. elles apparaissent, mais il ne se passe rien quand je clique dessus.
Cette erreur provient d'une intégration personnalisée
Enregistreur: custom_components.hacs
Source: custom_components/hacs/base.py:734
intégration: HACS (documentation, problèmes)
S'est produit pour la première fois: 25 juin 2024 à 17:04:51 (45 occurrences)
Dernier enregistrement: 08:33:06
A timeout of 60! seconds was encountered while downloading https://raw.githubusercontent.com/custom-components/ble_monitor/12.11.3/info.md, using over 60 seconds to download a single file is not normal. This is not a problem with HACS but how your host communicates with GitHub. Retrying up to 5 times to mask/hide your host/network problems to stop the flow of issues opened about it. Tries left 0
A timeout of 60! seconds was encountered while downloading https://raw.githubusercontent.com/cyr-ius/hass-livebox-component/2.2.7/README.md, using over 60 seconds to download a single file is not normal. This is not a problem with HACS but how your host communicates with GitHub. Retrying up to 5 times to mask/hide your host/network problems to stop the flow of issues opened about it. Tries left 1
A timeout of 60! seconds was encountered while downloading https://raw.githubusercontent.com/totaldebug/atomic-calendar-revive/v9.7.0/info.md, using over 60 seconds to download a single file is not normal. This is not a problem with HACS but how your host communicates with GitHub. Retrying up to 5 times to mask/hide your host/network problems to stop the flow of issues opened about it. Tries left 0
A timeout of 60! seconds was encountered while downloading https://raw.githubusercontent.com/dougiteixeira/proxmoxve/3.4.2/README.md, using over 60 seconds to download a single file is not normal. This is not a problem with HACS but how your host communicates with GitHub. Retrying up to 5 times to mask/hide your host/network problems to stop the flow of issues opened about it. Tries left 0
A timeout of 60! seconds was encountered while downloading https://raw.githubusercontent.com/cyr-ius/hass-livebox-component/2.2.7/README.md, using over 60 seconds to download a single file is not normal. This is not a problem with HACS but how your host communicates with GitHub. Retrying up to 5 times to mask/hide your host/network problems to stop the flow of issues opened about it. Tries left 0
depuis la console je teste:
config $ wget https://raw.githubusercontent.com/totaldebug/atomic-calendar-revive/v9.7.0/info.md
--2024-06-26 08:39:05-- https://raw.githubusercontent.com/totaldebug/atomic-calendar-revive/v9.7.0/info.md
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 2606:50c0:8002::154, 2606:50c0:8001::154, 2606:50c0:8000::154, ...
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|2606:50c0:8002::154|:443...
tiens, de lipv6 ? je teste en désactivant l’ipv6:
Échec de la modification des paramètres réseau
Can't update config on end0: ipv6.dns: this property is not allowed for 'method=link-local'
et Paf le chien…
un ping sur google.com ne passe pas en ipv6 mais est OK en ipv4:
config $ ping -6 google.com
PING google.com (2a00:1450:4007:81a::200e): 56 data bytes
^C
--- google.com ping statistics ---
5 packets transmitted, 0 packets received, 100% packet loss
config $ ping -4 google.com
PING google.com (142.250.201.174): 56 data bytes
64 bytes from 142.250.201.174: seq=0 ttl=116 time=2.616 ms
64 bytes from 142.250.201.174: seq=1 ttl=116 time=2.430 ms
64 bytes from 142.250.201.174: seq=2 ttl=116 time=2.461 ms
^C
3 packets transmitted, 3 packets received, 0% packet loss
round-trip min/avg/max = 2.430/2.502/2.616 ms
config $
