alut,
J’ai des plantages intempestifs de Zigbee2mqtt dont je ne comprends pas l’origine.
Infos :
Zigbee2mqtt 1.35.3-1
Mosquitto broker 6.4.0
Core 2024.2.2
Supervisor 2024.02.0
OS : 11.5
Frontend 202402027.1
Raspberry Pi 3
rpi3-64
Clé : SONOFF ZigBee 3.0 USB Dongle Plus, EFR32MG21
Config :
Zigbee2mqtt
Mosquitto Broker
Logs :
Mosquitto
cont-init: info: running /etc/cont-init.d/mosquitto.sh
[10:40:53] INFO: SSL is not enabled
cont-init: info: /etc/cont-init.d/mosquitto.sh exited 0
cont-init: info: running /etc/cont-init.d/nginx.sh
cont-init: info: /etc/cont-init.d/nginx.sh exited 0
services-up: info: copying legacy longrun mosquitto (no readiness notification)
services-up: info: copying legacy longrun nginx (no readiness notification)
[10:41:20] INFO: Starting NGINX for authentication handling...
2024-02-22 10:41:25: mosquitto version 2.0.18 starting
2024-02-22 10:41:25: Config loaded from /etc/mosquitto/mosquitto.conf.
2024-02-22 10:41:25: Loading plugin: /usr/share/mosquitto/go-auth.so
[10:41:24] INFO: Starting mosquitto MQTT broker...
2024-02-22 10:41:25: Warning: Mosquitto should not be run as root/administrator.
2024-02-22 10:41:25: ├── Username/password checking enabled.
2024-02-22 10:41:25: ├── TLS-PSK checking enabled.
2024-02-22 10:41:25: └── Extended authentication not enabled.
2024-02-22 10:41:25: Opening ipv4 listen socket on port 1883.
2024-02-22 10:41:25: Opening ipv6 listen socket on port 1883.
2024-02-22 10:41:25: Opening websockets listen socket on port 1884.
2024-02-22 10:41:25: mosquitto version 2.0.18 running
2024-02-22 10:41:34: New connection from 127.0.0.1:53728 on port 1883.
2024-02-22 10:41:34: Client <unknown> disconnected due to protocol error.
[10:42:05] INFO: Successfully send discovery information to Home Assistant.
2024-02-22 10:42:07: New connection from x.x.x.2:57542 on port 1883.
2024-02-22 10:42:08: New client connected from x.x.x.2:57542 as mqttjs_3235ee8e (p2, c1, k60, u'addons').
[10:42:19] INFO: Successfully send service information to the Supervisor.
2024-02-22 10:42:24: New connection from x.x.x.1:42745 on port 1883.
2024-02-22 10:42:24: New client connected from x.x.x.1:42745 as 3VeiOYo0O7R4iUd6ZUysTg (p2, c1, k60, u'mqtt').
2024-02-22 10:42:32: New connection from x.x.x.2:42092 on port 1883.
2024-02-22 10:42:32: Client <unknown> closed its connection.
2024-02-22 10:44:32: New connection from x.x.x.2:52844 on port 1883.
2024-02-22 10:44:33: Client <unknown> closed its connection.
2024-02-22 10:46:33: New connection from x.x.x.2:33834 on port 1883.
2024-02-22 10:46:34: Client <unknown> closed its connection.
2024-02-22 10:48:34: New connection from x.x.x.2:42172 on port 1883.
2024-02-22 10:48:34: Client <unknown> closed its connection.
2024-02-22 10:50:35: New connection from x.x.x.2:42584 on port 1883.
2024-02-22 10:50:35: Client <unknown> closed its connection.
2024-02-22 10:52:35: New connection from x.x.x.2:49350 on port 1883.
2024-02-22 10:52:35: Client <unknown> closed its connection.
2024-02-22 10:54:36: New connection from x.x.x.2:54262 on port 1883.
2024-02-22 10:54:36: Client <unknown> closed its connection.
2024-02-22 10:56:36: New connection from x.x.x.2:50354 on port 1883.
2024-02-22 10:56:37: Client <unknown> closed its connection.
2024-02-22 10:56:51: Client mqttjs_3235ee8e closed its connection.
2024-02-22 10:58:22: New connection from x.x.x.2:38456 on port 1883.
2024-02-22 10:58:26: New client connected from x.x.x.2:38456 as mqttjs_56520819 (p2, c1, k60, u'addons').
2024-02-22 10:58:39: New connection from x.x.x.2:38346 on port 1883.
2024-02-22 10:58:39: Client <unknown> closed its connection.
2024-02-22 10:58:43: Client mqttjs_56520819 closed its connection.
2024-02-22 11:00:13: New connection from x.x.x.2:48010 on port 1883.
2024-02-22 11:00:19: New client connected from x.x.x.2:48010 as mqttjs_40d3b4ae (p2, c1, k60, u'addons').
2024-02-22 11:00:41: New connection from x.x.x.2:40772 on port 1883.
2024-02-22 11:00:41: Client <unknown> closed its connection.
2024-02-22 11:01:10: Client mqttjs_40d3b4ae disconnected.
Zigbee2mqtt
[11:03:42] INFO: Preparing to start...
[11:03:47] INFO: Socat not enabled
[11:03:54] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info 2024-02-22 11:04:55: Logging to console and directory: '/config/zigbee2mqtt/log/2024-02-22.11-04-52' filename: log.txt
Zigbee2MQTT:info 2024-02-22 11:04:56: Starting Zigbee2MQTT version 1.35.3 (commit #unknown)
Zigbee2MQTT:info 2024-02-22 11:04:56: Starting zigbee-herdsman (0.33.8)
Zigbee2MQTT:info 2024-02-22 11:05:20: zigbee-herdsman started (resumed)
Zigbee2MQTT:info 2024-02-22 11:05:21: Coordinator firmware version: '{"meta":{"maintrel":"3 ","majorrel":"6","minorrel":"10","product":8,"revision":"6.10.3.0 build 297"},"type":"EZSP v8"}'
Zigbee2MQTT:info 2024-02-22 11:05:21: Currently 4 devices are joined:
Zigbee2MQTT:info 2024-02-22 11:05:21: Température salon (0x54ef4410007def8b): VOCKQJK11LM - Aqara TVOC air quality monitor (EndDevice)
Zigbee2MQTT:info 2024-02-22 11:05:21: Détecteur ouverture porte baie vitrée (0xa4c1387421845932): TS0203 - TuYa Door sensor (EndDevice)
Zigbee2MQTT:info 2024-02-22 11:05:21: Radiateur Masterbedroom (0x90395efffe2763c2): SIN-4-FP-21 - NodOn Pilot wire heating module (Router)
Zigbee2MQTT:info 2024-02-22 11:05:21: Radiateur chambre invité (0x90395efffe4b1c01): SIN-4-FP-21 - NodOn Pilot wire heating module (Router)
Zigbee2MQTT:info 2024-02-22 11:05:21: Zigbee: disabling joining new devices.
Zigbee2MQTT:info 2024-02-22 11:05:22: Connecting to MQTT server at mqtt://core-mosquitto:1883
Zigbee2MQTT:info 2024-02-22 11:05:27: Connected to MQTT server
Zigbee2MQTT:info 2024-02-22 11:05:28: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"online"}'
Zigbee2MQTT:info 2024-02-22 11:05:40: Started frontend on port 8099
Zigbee2MQTT:info 2024-02-22 11:05:44: MQTT publish: topic 'homeassistant/binary_sensor/1221051039810110150109113116116_0xe0798dfffec6decb/connection_state/config', payload '{"device":{"hw_version":"EZSP v8 6.10.3.0 build 297","identifiers":["zigbee2mqtt_bridge_0xe0798dfffec6decb"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.35.3"},"device_class":"connectivity","entity_category":"diagnostic","name":"Connection state","object_id":"zigbee2mqtt_bridge_connection_state","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"payload_off":"offline","payload_on":"online","state_topic":"zigbee2mqtt/bridge/state","unique_id":"bridge_0xe0798dfffec6decb_connection_state_zigbee2mqtt","value_template":"{{ value_json.state }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:45: MQTT publish: topic 'homeassistant/binary_sensor/1221051039810110150109113116116_0xe0798dfffec6decb/restart_required/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","device":{"hw_version":"EZSP v8 6.10.3.0 build 297","identifiers":["zigbee2mqtt_bridge_0xe0798dfffec6decb"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.35.3"},"device_class":"problem","enabled_by_default":false,"entity_category":"diagnostic","name":"Restart required","object_id":"zigbee2mqtt_bridge_restart_required","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"payload_off":false,"payload_on":true,"state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0xe0798dfffec6decb_restart_required_zigbee2mqtt","value_template":"{{ value_json.restart_required }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:46: MQTT publish: topic 'homeassistant/button/1221051039810110150109113116116_0xe0798dfffec6decb/restart/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","command_topic":"zigbee2mqtt/bridge/request/restart","device":{"hw_version":"EZSP v8 6.10.3.0 build 297","identifiers":["zigbee2mqtt_bridge_0xe0798dfffec6decb"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.35.3"},"device_class":"restart","name":"Restart","object_id":"zigbee2mqtt_bridge_restart","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"payload_press":"","unique_id":"bridge_0xe0798dfffec6decb_restart_zigbee2mqtt"}'
Zigbee2MQTT:info 2024-02-22 11:05:46: MQTT publish: topic 'homeassistant/select/1221051039810110150109113116116_0xe0798dfffec6decb/log_level/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","command_template":"{\"options\": {\"advanced\": {\"log_level\": \"{{ value }}\" } } }","command_topic":"zigbee2mqtt/bridge/request/options","device":{"hw_version":"EZSP v8 6.10.3.0 build 297","identifiers":["zigbee2mqtt_bridge_0xe0798dfffec6decb"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.35.3"},"entity_category":"config","name":"Log level","object_id":"zigbee2mqtt_bridge_log_level","options":["info","warn","error","debug"],"origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0xe0798dfffec6decb_log_level_zigbee2mqtt","value_template":"{{ value_json.log_level | lower }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:46: MQTT publish: topic 'homeassistant/sensor/1221051039810110150109113116116_0xe0798dfffec6decb/version/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","device":{"hw_version":"EZSP v8 6.10.3.0 build 297","identifiers":["zigbee2mqtt_bridge_0xe0798dfffec6decb"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.35.3"},"entity_category":"diagnostic","icon":"mdi:zigbee","name":"Version","object_id":"zigbee2mqtt_bridge_version","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0xe0798dfffec6decb_version_zigbee2mqtt","value_template":"{{ value_json.version }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:46: MQTT publish: topic 'homeassistant/sensor/1221051039810110150109113116116_0xe0798dfffec6decb/coordinator_version/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","device":{"hw_version":"EZSP v8 6.10.3.0 build 297","identifiers":["zigbee2mqtt_bridge_0xe0798dfffec6decb"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.35.3"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:chip","name":"Coordinator version","object_id":"zigbee2mqtt_bridge_coordinator_version","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0xe0798dfffec6decb_coordinator_version_zigbee2mqtt","value_template":"{{ value_json.coordinator.meta.revision }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:46: MQTT publish: topic 'homeassistant/sensor/1221051039810110150109113116116_0xe0798dfffec6decb/network_map/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","device":{"hw_version":"EZSP v8 6.10.3.0 build 297","identifiers":["zigbee2mqtt_bridge_0xe0798dfffec6decb"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.35.3"},"enabled_by_default":false,"entity_category":"diagnostic","json_attributes_template":"{{ value_json.data.value | tojson }}","json_attributes_topic":"zigbee2mqtt/bridge/response/networkmap","name":"Network map","object_id":"zigbee2mqtt_bridge_network_map","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/bridge/response/networkmap","unique_id":"bridge_0xe0798dfffec6decb_network_map_zigbee2mqtt","value_template":"{{ now().strftime('%Y-%m-%d %H:%M:%S') }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:46: MQTT publish: topic 'homeassistant/sensor/1221051039810110150109113116116_0xe0798dfffec6decb/permit_join_timeout/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","device":{"hw_version":"EZSP v8 6.10.3.0 build 297","identifiers":["zigbee2mqtt_bridge_0xe0798dfffec6decb"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.35.3"},"device_class":"duration","entity_category":"diagnostic","name":"Permit join timeout","object_id":"zigbee2mqtt_bridge_permit_join_timeout","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0xe0798dfffec6decb_permit_join_timeout_zigbee2mqtt","unit_of_measurement":"s","value_template":"{{ iif(value_json.permit_join_timeout is defined, value_json.permit_join_timeout, None) }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:46: MQTT publish: topic 'homeassistant/switch/1221051039810110150109113116116_0xe0798dfffec6decb/permit_join/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","command_topic":"zigbee2mqtt/bridge/request/permit_join","device":{"hw_version":"EZSP v8 6.10.3.0 build 297","identifiers":["zigbee2mqtt_bridge_0xe0798dfffec6decb"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.35.3"},"icon":"mdi:human-greeting-proximity","name":"Permit join","object_id":"zigbee2mqtt_bridge_permit_join","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"payload_off":"false","payload_on":"true","state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0xe0798dfffec6decb_permit_join_zigbee2mqtt","value_template":"{{ value_json.permit_join | lower }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:47: MQTT publish: topic 'homeassistant/sensor/0x54ef4410007def8b/device_temperature/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x54ef4410007def8b"],"manufacturer":"Aqara","model":"TVOC air quality monitor (VOCKQJK11LM)","name":"Température salon","sw_version":"2020\u0000www.","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"device_class":"temperature","enabled_by_default":true,"entity_category":"diagnostic","object_id":"température_salon_device_temperature","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/Température salon","unique_id":"0x54ef4410007def8b_device_temperature_zigbee2mqtt","unit_of_measurement":"°C","value_template":"{{ value_json.device_temperature }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:47: MQTT publish: topic 'homeassistant/sensor/0x54ef4410007def8b/battery/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x54ef4410007def8b"],"manufacturer":"Aqara","model":"TVOC air quality monitor (VOCKQJK11LM)","name":"Température salon","sw_version":"2020\u0000www.","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"device_class":"battery","enabled_by_default":true,"entity_category":"diagnostic","object_id":"température_salon_battery","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/Température salon","unique_id":"0x54ef4410007def8b_battery_zigbee2mqtt","unit_of_measurement":"%","value_template":"{{ value_json.battery }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:47: MQTT publish: topic 'homeassistant/sensor/0x54ef4410007def8b/voltage/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x54ef4410007def8b"],"manufacturer":"Aqara","model":"TVOC air quality monitor (VOCKQJK11LM)","name":"Température salon","sw_version":"2020\u0000www.","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"device_class":"voltage","enabled_by_default":false,"entity_category":"diagnostic","object_id":"température_salon_voltage","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/Température salon","unique_id":"0x54ef4410007def8b_voltage_zigbee2mqtt","unit_of_measurement":"mV","value_template":"{{ value_json.voltage }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:47: MQTT publish: topic 'homeassistant/sensor/0x54ef4410007def8b/air_quality/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x54ef4410007def8b"],"manufacturer":"Aqara","model":"TVOC air quality monitor (VOCKQJK11LM)","name":"Température salon","sw_version":"2020\u0000www.","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"enabled_by_default":true,"name":"Air quality","object_id":"température_salon_air_quality","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/Température salon","unique_id":"0x54ef4410007def8b_air_quality_zigbee2mqtt","value_template":"{{ value_json.air_quality }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:47: MQTT publish: topic 'homeassistant/sensor/0x54ef4410007def8b/voc/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x54ef4410007def8b"],"manufacturer":"Aqara","model":"TVOC air quality monitor (VOCKQJK11LM)","name":"Température salon","sw_version":"2020\u0000www.","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"enabled_by_default":true,"name":"Voc","object_id":"température_salon_voc","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/Température salon","unique_id":"0x54ef4410007def8b_voc_zigbee2mqtt","unit_of_measurement":"ppb","value_template":"{{ value_json.voc }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:47: MQTT publish: topic 'homeassistant/sensor/0x54ef4410007def8b/temperature/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x54ef4410007def8b"],"manufacturer":"Aqara","model":"TVOC air quality monitor (VOCKQJK11LM)","name":"Température salon","sw_version":"2020\u0000www.","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"device_class":"temperature","enabled_by_default":true,"object_id":"température_salon_temperature","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/Température salon","unique_id":"0x54ef4410007def8b_temperature_zigbee2mqtt","unit_of_measurement":"°C","value_template":"{{ value_json.temperature }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:47: MQTT publish: topic 'homeassistant/sensor/0x54ef4410007def8b/humidity/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x54ef4410007def8b"],"manufacturer":"Aqara","model":"TVOC air quality monitor (VOCKQJK11LM)","name":"Température salon","sw_version":"2020\u0000www.","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"device_class":"humidity","enabled_by_default":true,"object_id":"température_salon_humidity","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/Température salon","unique_id":"0x54ef4410007def8b_humidity_zigbee2mqtt","unit_of_measurement":"%","value_template":"{{ value_json.humidity }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:47: MQTT publish: topic 'homeassistant/sensor/0x54ef4410007def8b/display_unit/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x54ef4410007def8b"],"manufacturer":"Aqara","model":"TVOC air quality monitor (VOCKQJK11LM)","name":"Température salon","sw_version":"2020\u0000www.","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"enabled_by_default":false,"name":"Display unit","object_id":"température_salon_display_unit","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/Température salon","unique_id":"0x54ef4410007def8b_display_unit_zigbee2mqtt","value_template":"{{ value_json.display_unit }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:47: MQTT publish: topic 'homeassistant/select/0x54ef4410007def8b/display_unit/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/Température salon/set/display_unit","device":{"identifiers":["zigbee2mqtt_0x54ef4410007def8b"],"manufacturer":"Aqara","model":"TVOC air quality monitor (VOCKQJK11LM)","name":"Température salon","sw_version":"2020\u0000www.","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"name":"Display unit","object_id":"température_salon_display_unit","options":["mgm3_celsius","ppb_celsius","mgm3_fahrenheit","ppb_fahrenheit"],"origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/Température salon","unique_id":"0x54ef4410007def8b_display_unit_zigbee2mqtt","value_template":"{{ value_json.display_unit }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:47: MQTT publish: topic 'homeassistant/sensor/0x54ef4410007def8b/linkquality/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x54ef4410007def8b"],"manufacturer":"Aqara","model":"TVOC air quality monitor (VOCKQJK11LM)","name":"Température salon","sw_version":"2020\u0000www.","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:signal","name":"Linkquality","object_id":"température_salon_linkquality","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/Température salon","unique_id":"0x54ef4410007def8b_linkquality_zigbee2mqtt","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:47: MQTT publish: topic 'homeassistant/sensor/0x54ef4410007def8b/update_state/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x54ef4410007def8b"],"manufacturer":"Aqara","model":"TVOC air quality monitor (VOCKQJK11LM)","name":"Température salon","sw_version":"2020\u0000www.","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:update","name":"Update state","object_id":"température_salon_update_state","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/Température salon","unique_id":"0x54ef4410007def8b_update_state_zigbee2mqtt","value_template":"{{ value_json['update']['state'] }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:47: MQTT publish: topic 'homeassistant/binary_sensor/0x54ef4410007def8b/update_available/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x54ef4410007def8b"],"manufacturer":"Aqara","model":"TVOC air quality monitor (VOCKQJK11LM)","name":"Température salon","sw_version":"2020\u0000www.","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"device_class":"update","enabled_by_default":false,"entity_category":"diagnostic","name":null,"object_id":"température_salon_update_available","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"payload_off":false,"payload_on":true,"state_topic":"zigbee2mqtt/Température salon","unique_id":"0x54ef4410007def8b_update_available_zigbee2mqtt","value_template":"{{ value_json['update']['state'] == \"available\" }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:47: MQTT publish: topic 'homeassistant/update/0x54ef4410007def8b/update/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/bridge/request/device/ota_update/update","device":{"identifiers":["zigbee2mqtt_0x54ef4410007def8b"],"manufacturer":"Aqara","model":"TVOC air quality monitor (VOCKQJK11LM)","name":"Température salon","sw_version":"2020\u0000www.","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"device_class":"firmware","entity_category":"config","entity_picture":"https://github.com/Koenkk/zigbee2mqtt/raw/master/images/logo.png","json_attributes_template":"{\"in_progress\": {{ iif(value_json['update']['state'] == 'updating', 'true', 'false') }} }","json_attributes_topic":"zigbee2mqtt/Température salon","latest_version_template":"{{ value_json['update']['latest_version'] }}","latest_version_topic":"zigbee2mqtt/Température salon","name":null,"object_id":"température_salon","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"payload_install":"{\"id\": \"0x54ef4410007def8b\"}","state_topic":"zigbee2mqtt/Température salon","unique_id":"0x54ef4410007def8b_update_zigbee2mqtt","value_template":"{{ value_json['update']['installed_version'] }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:47: MQTT publish: topic 'homeassistant/binary_sensor/0xa4c1387421845932/contact/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0xa4c1387421845932"],"manufacturer":"TuYa","model":"Door sensor (TS0203)","name":"Détecteur ouverture porte baie vitrée","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"device_class":"door","object_id":"détecteur_ouverture_porte_baie_vitrée_contact","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"payload_off":true,"payload_on":false,"state_topic":"zigbee2mqtt/Détecteur ouverture porte baie vitrée","unique_id":"0xa4c1387421845932_contact_zigbee2mqtt","value_template":"{{ value_json.contact }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:47: MQTT publish: topic 'homeassistant/binary_sensor/0xa4c1387421845932/battery_low/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0xa4c1387421845932"],"manufacturer":"TuYa","model":"Door sensor (TS0203)","name":"Détecteur ouverture porte baie vitrée","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"device_class":"battery","entity_category":"diagnostic","object_id":"détecteur_ouverture_porte_baie_vitrée_battery_low","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"payload_off":false,"payload_on":true,"state_topic":"zigbee2mqtt/Détecteur ouverture porte baie vitrée","unique_id":"0xa4c1387421845932_battery_low_zigbee2mqtt","value_template":"{{ value_json.battery_low }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:47: MQTT publish: topic 'homeassistant/sensor/0xa4c1387421845932/battery/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0xa4c1387421845932"],"manufacturer":"TuYa","model":"Door sensor (TS0203)","name":"Détecteur ouverture porte baie vitrée","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"device_class":"battery","enabled_by_default":true,"entity_category":"diagnostic","object_id":"détecteur_ouverture_porte_baie_vitrée_battery","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/Détecteur ouverture porte baie vitrée","unique_id":"0xa4c1387421845932_battery_zigbee2mqtt","unit_of_measurement":"%","value_template":"{{ value_json.battery }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:47: MQTT publish: topic 'homeassistant/sensor/0xa4c1387421845932/voltage/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0xa4c1387421845932"],"manufacturer":"TuYa","model":"Door sensor (TS0203)","name":"Détecteur ouverture porte baie vitrée","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"device_class":"voltage","enabled_by_default":false,"entity_category":"diagnostic","object_id":"détecteur_ouverture_porte_baie_vitrée_voltage","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/Détecteur ouverture porte baie vitrée","unique_id":"0xa4c1387421845932_voltage_zigbee2mqtt","unit_of_measurement":"mV","value_template":"{{ value_json.voltage }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:47: MQTT publish: topic 'homeassistant/binary_sensor/0xa4c1387421845932/tamper/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0xa4c1387421845932"],"manufacturer":"TuYa","model":"Door sensor (TS0203)","name":"Détecteur ouverture porte baie vitrée","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"device_class":"tamper","object_id":"détecteur_ouverture_porte_baie_vitrée_tamper","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"payload_off":false,"payload_on":true,"state_topic":"zigbee2mqtt/Détecteur ouverture porte baie vitrée","unique_id":"0xa4c1387421845932_tamper_zigbee2mqtt","value_template":"{{ value_json.tamper }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:47: MQTT publish: topic 'homeassistant/sensor/0xa4c1387421845932/linkquality/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0xa4c1387421845932"],"manufacturer":"TuYa","model":"Door sensor (TS0203)","name":"Détecteur ouverture porte baie vitrée","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:signal","name":"Linkquality","object_id":"détecteur_ouverture_porte_baie_vitrée_linkquality","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/Détecteur ouverture porte baie vitrée","unique_id":"0xa4c1387421845932_linkquality_zigbee2mqtt","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:47: MQTT publish: topic 'homeassistant/sensor/0x90395efffe2763c2/power/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x90395efffe2763c2"],"manufacturer":"NodOn","model":"Pilot wire heating module (SIN-4-FP-21)","name":"Radiateur Masterbedroom","sw_version":"3.0.0-1.4.4","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"device_class":"power","enabled_by_default":true,"entity_category":"diagnostic","object_id":"radiateur_masterbedroom_power","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/Radiateur Masterbedroom","unique_id":"0x90395efffe2763c2_power_zigbee2mqtt","unit_of_measurement":"W","value_template":"{{ value_json.power }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:47: MQTT publish: topic 'homeassistant/sensor/0x90395efffe2763c2/energy/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x90395efffe2763c2"],"manufacturer":"NodOn","model":"Pilot wire heating module (SIN-4-FP-21)","name":"Radiateur Masterbedroom","sw_version":"3.0.0-1.4.4","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"device_class":"energy","enabled_by_default":true,"object_id":"radiateur_masterbedroom_energy","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_class":"total_increasing","state_topic":"zigbee2mqtt/Radiateur Masterbedroom","unique_id":"0x90395efffe2763c2_energy_zigbee2mqtt","unit_of_measurement":"kWh","value_template":"{{ value_json.energy }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:47: MQTT publish: topic 'homeassistant/sensor/0x90395efffe2763c2/pilot_wire_mode/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x90395efffe2763c2"],"manufacturer":"NodOn","model":"Pilot wire heating module (SIN-4-FP-21)","name":"Radiateur Masterbedroom","sw_version":"3.0.0-1.4.4","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"enabled_by_default":false,"name":"Pilot wire mode","object_id":"radiateur_masterbedroom_pilot_wire_mode","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/Radiateur Masterbedroom","unique_id":"0x90395efffe2763c2_pilot_wire_mode_zigbee2mqtt","value_template":"{{ value_json.pilot_wire_mode }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:47: MQTT publish: topic 'homeassistant/select/0x90395efffe2763c2/pilot_wire_mode/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/Radiateur Masterbedroom/set/pilot_wire_mode","device":{"identifiers":["zigbee2mqtt_0x90395efffe2763c2"],"manufacturer":"NodOn","model":"Pilot wire heating module (SIN-4-FP-21)","name":"Radiateur Masterbedroom","sw_version":"3.0.0-1.4.4","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"name":"Pilot wire mode","object_id":"radiateur_masterbedroom_pilot_wire_mode","options":["comfort","eco","frost_protection","off","comfort_-1","comfort_-2"],"origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/Radiateur Masterbedroom","unique_id":"0x90395efffe2763c2_pilot_wire_mode_zigbee2mqtt","value_template":"{{ value_json.pilot_wire_mode }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:47: MQTT publish: topic 'homeassistant/sensor/0x90395efffe2763c2/linkquality/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x90395efffe2763c2"],"manufacturer":"NodOn","model":"Pilot wire heating module (SIN-4-FP-21)","name":"Radiateur Masterbedroom","sw_version":"3.0.0-1.4.4","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:signal","name":"Linkquality","object_id":"radiateur_masterbedroom_linkquality","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/Radiateur Masterbedroom","unique_id":"0x90395efffe2763c2_linkquality_zigbee2mqtt","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:47: MQTT publish: topic 'homeassistant/sensor/0x90395efffe2763c2/update_state/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x90395efffe2763c2"],"manufacturer":"NodOn","model":"Pilot wire heating module (SIN-4-FP-21)","name":"Radiateur Masterbedroom","sw_version":"3.0.0-1.4.4","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:update","name":"Update state","object_id":"radiateur_masterbedroom_update_state","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/Radiateur Masterbedroom","unique_id":"0x90395efffe2763c2_update_state_zigbee2mqtt","value_template":"{{ value_json['update']['state'] }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:47: MQTT publish: topic 'homeassistant/binary_sensor/0x90395efffe2763c2/update_available/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x90395efffe2763c2"],"manufacturer":"NodOn","model":"Pilot wire heating module (SIN-4-FP-21)","name":"Radiateur Masterbedroom","sw_version":"3.0.0-1.4.4","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"device_class":"update","enabled_by_default":false,"entity_category":"diagnostic","name":null,"object_id":"radiateur_masterbedroom_update_available","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"payload_off":false,"payload_on":true,"state_topic":"zigbee2mqtt/Radiateur Masterbedroom","unique_id":"0x90395efffe2763c2_update_available_zigbee2mqtt","value_template":"{{ value_json['update']['state'] == \"available\" }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:48: MQTT publish: topic 'homeassistant/update/0x90395efffe2763c2/update/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/bridge/request/device/ota_update/update","device":{"identifiers":["zigbee2mqtt_0x90395efffe2763c2"],"manufacturer":"NodOn","model":"Pilot wire heating module (SIN-4-FP-21)","name":"Radiateur Masterbedroom","sw_version":"3.0.0-1.4.4","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"device_class":"firmware","entity_category":"config","entity_picture":"https://github.com/Koenkk/zigbee2mqtt/raw/master/images/logo.png","json_attributes_template":"{\"in_progress\": {{ iif(value_json['update']['state'] == 'updating', 'true', 'false') }} }","json_attributes_topic":"zigbee2mqtt/Radiateur Masterbedroom","latest_version_template":"{{ value_json['update']['latest_version'] }}","latest_version_topic":"zigbee2mqtt/Radiateur Masterbedroom","name":null,"object_id":"radiateur_masterbedroom","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"payload_install":"{\"id\": \"0x90395efffe2763c2\"}","state_topic":"zigbee2mqtt/Radiateur Masterbedroom","unique_id":"0x90395efffe2763c2_update_zigbee2mqtt","value_template":"{{ value_json['update']['installed_version'] }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:48: MQTT publish: topic 'homeassistant/sensor/0x90395efffe4b1c01/power/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x90395efffe4b1c01"],"manufacturer":"NodOn","model":"Pilot wire heating module (SIN-4-FP-21)","name":"Radiateur chambre invité","sw_version":"3.0.0-1.4.4","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"device_class":"power","enabled_by_default":true,"entity_category":"diagnostic","object_id":"radiateur_chambre_invité_power","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/Radiateur chambre invité","unique_id":"0x90395efffe4b1c01_power_zigbee2mqtt","unit_of_measurement":"W","value_template":"{{ value_json.power }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:48: MQTT publish: topic 'homeassistant/sensor/0x90395efffe4b1c01/energy/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x90395efffe4b1c01"],"manufacturer":"NodOn","model":"Pilot wire heating module (SIN-4-FP-21)","name":"Radiateur chambre invité","sw_version":"3.0.0-1.4.4","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"device_class":"energy","enabled_by_default":true,"object_id":"radiateur_chambre_invité_energy","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_class":"total_increasing","state_topic":"zigbee2mqtt/Radiateur chambre invité","unique_id":"0x90395efffe4b1c01_energy_zigbee2mqtt","unit_of_measurement":"kWh","value_template":"{{ value_json.energy }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:48: MQTT publish: topic 'homeassistant/sensor/0x90395efffe4b1c01/pilot_wire_mode/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x90395efffe4b1c01"],"manufacturer":"NodOn","model":"Pilot wire heating module (SIN-4-FP-21)","name":"Radiateur chambre invité","sw_version":"3.0.0-1.4.4","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"enabled_by_default":false,"name":"Pilot wire mode","object_id":"radiateur_chambre_invité_pilot_wire_mode","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/Radiateur chambre invité","unique_id":"0x90395efffe4b1c01_pilot_wire_mode_zigbee2mqtt","value_template":"{{ value_json.pilot_wire_mode }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:48: MQTT publish: topic 'homeassistant/select/0x90395efffe4b1c01/pilot_wire_mode/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/Radiateur chambre invité/set/pilot_wire_mode","device":{"identifiers":["zigbee2mqtt_0x90395efffe4b1c01"],"manufacturer":"NodOn","model":"Pilot wire heating module (SIN-4-FP-21)","name":"Radiateur chambre invité","sw_version":"3.0.0-1.4.4","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"name":"Pilot wire mode","object_id":"radiateur_chambre_invité_pilot_wire_mode","options":["comfort","eco","frost_protection","off","comfort_-1","comfort_-2"],"origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/Radiateur chambre invité","unique_id":"0x90395efffe4b1c01_pilot_wire_mode_zigbee2mqtt","value_template":"{{ value_json.pilot_wire_mode }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:48: MQTT publish: topic 'homeassistant/sensor/0x90395efffe4b1c01/linkquality/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x90395efffe4b1c01"],"manufacturer":"NodOn","model":"Pilot wire heating module (SIN-4-FP-21)","name":"Radiateur chambre invité","sw_version":"3.0.0-1.4.4","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:signal","name":"Linkquality","object_id":"radiateur_chambre_invité_linkquality","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/Radiateur chambre invité","unique_id":"0x90395efffe4b1c01_linkquality_zigbee2mqtt","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:48: MQTT publish: topic 'homeassistant/sensor/0x90395efffe4b1c01/update_state/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x90395efffe4b1c01"],"manufacturer":"NodOn","model":"Pilot wire heating module (SIN-4-FP-21)","name":"Radiateur chambre invité","sw_version":"3.0.0-1.4.4","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:update","name":"Update state","object_id":"radiateur_chambre_invité_update_state","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/Radiateur chambre invité","unique_id":"0x90395efffe4b1c01_update_state_zigbee2mqtt","value_template":"{{ value_json['update']['state'] }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:48: MQTT publish: topic 'homeassistant/binary_sensor/0x90395efffe4b1c01/update_available/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x90395efffe4b1c01"],"manufacturer":"NodOn","model":"Pilot wire heating module (SIN-4-FP-21)","name":"Radiateur chambre invité","sw_version":"3.0.0-1.4.4","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"device_class":"update","enabled_by_default":false,"entity_category":"diagnostic","name":null,"object_id":"radiateur_chambre_invité_update_available","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"payload_off":false,"payload_on":true,"state_topic":"zigbee2mqtt/Radiateur chambre invité","unique_id":"0x90395efffe4b1c01_update_available_zigbee2mqtt","value_template":"{{ value_json['update']['state'] == \"available\" }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:48: MQTT publish: topic 'homeassistant/update/0x90395efffe4b1c01/update/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/bridge/request/device/ota_update/update","device":{"identifiers":["zigbee2mqtt_0x90395efffe4b1c01"],"manufacturer":"NodOn","model":"Pilot wire heating module (SIN-4-FP-21)","name":"Radiateur chambre invité","sw_version":"3.0.0-1.4.4","via_device":"zigbee2mqtt_bridge_0xe0798dfffec6decb"},"device_class":"firmware","entity_category":"config","entity_picture":"https://github.com/Koenkk/zigbee2mqtt/raw/master/images/logo.png","json_attributes_template":"{\"in_progress\": {{ iif(value_json['update']['state'] == 'updating', 'true', 'false') }} }","json_attributes_topic":"zigbee2mqtt/Radiateur chambre invité","latest_version_template":"{{ value_json['update']['latest_version'] }}","latest_version_topic":"zigbee2mqtt/Radiateur chambre invité","name":null,"object_id":"radiateur_chambre_invité","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"payload_install":"{\"id\": \"0x90395efffe4b1c01\"}","state_topic":"zigbee2mqtt/Radiateur chambre invité","unique_id":"0x90395efffe4b1c01_update_zigbee2mqtt","value_template":"{{ value_json['update']['installed_version'] }}"}'
Zigbee2MQTT:info 2024-02-22 11:05:48: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"online"}'
Zigbee2MQTT:info 2024-02-22 11:05:49: MQTT publish: topic 'zigbee2mqtt/Température salon', payload '{"air_quality":"good","battery":100,"device_temperature":17,"display_unit":"ppb_celsius","humidity":67.15,"linkquality":208,"power_outage_count":21,"temperature":17.76,"update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voc":141,"voltage":3056}'
Zigbee2MQTT:info 2024-02-22 11:05:49: MQTT publish: topic 'zigbee2mqtt/Détecteur ouverture porte baie vitrée', payload '{"battery":100,"battery_low":false,"contact":true,"linkquality":124,"tamper":false,"voltage":3000}'
Zigbee2MQTT:info 2024-02-22 11:05:49: MQTT publish: topic 'zigbee2mqtt/Radiateur Masterbedroom', payload '{"energy":0.01,"linkquality":236,"pilot_wire_mode":"off","power":0,"state":"ON","update":{"installed_version":66564,"latest_version":66561,"state":"idle"},"update_available":null}'
Zigbee2MQTT:info 2024-02-22 11:05:49: MQTT publish: topic 'zigbee2mqtt/Radiateur chambre invité', payload '{"energy":0.02,"linkquality":212,"pilot_wire_mode":"frost_protection","power":0,"state":"OFF","update":{"installed_version":768,"latest_version":768,"state":"idle"},"update_available":null}'
Zigbee2MQTT:info 2024-02-22 11:05:49: Zigbee2MQTT started!
Supervisor
24-02-22 10:27:58 WARNING (MainThread) [supervisor.addons.options] Unknown option 'mqtt' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-22 10:29:35 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Zigbee2MQTT is failed, restarting...
24-02-22 10:29:35 INFO (SyncWorker_4) [supervisor.docker.manager] Cleaning addon_45df7312_zigbee2mqtt application
24-02-22 10:29:36 WARNING (MainThread) [supervisor.addons.options] Unknown option 'mqtt' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-22 10:29:56 WARNING (MainThread) [supervisor.addons.options] Unknown option 'mqtt' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-22 10:29:56 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on zigbee2mqtt/zigbee2mqtt-aarch64 with version 1.35.3-1
24-02-22 10:31:14 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Zigbee2MQTT is failed, restarting...
24-02-22 10:31:14 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning addon_45df7312_zigbee2mqtt application
24-02-22 10:31:14 WARNING (MainThread) [supervisor.addons.options] Unknown option 'mqtt' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-22 10:31:23 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on zigbee2mqtt/zigbee2mqtt-aarch64 with version 1.35.3-1
24-02-22 10:31:24 WARNING (MainThread) [supervisor.addons.options] Unknown option 'mqtt' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-22 10:34:08 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
24-02-22 10:34:12 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Zigbee2MQTT is failed, restarting...
24-02-22 10:34:12 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning addon_45df7312_zigbee2mqtt application
24-02-22 10:34:12 WARNING (MainThread) [supervisor.addons.options] Unknown option 'mqtt' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-22 10:34:17 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on zigbee2mqtt/zigbee2mqtt-aarch64 with version 1.35.3-1
24-02-22 10:34:19 WARNING (MainThread) [supervisor.addons.options] Unknown option 'mqtt' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-22 10:35:52 WARNING (MainThread) [supervisor.misc.tasks] Watchdog found a problem with core_mosquitto application!
24-02-22 10:36:12 INFO (SyncWorker_1) [supervisor.docker.manager] Stopping addon_core_mosquitto application
24-02-22 10:37:47 INFO (MainThread) [supervisor.host.info] Updating local host information
24-02-22 10:37:53 INFO (MainThread) [supervisor.host.services] Updating service information
24-02-22 10:37:54 INFO (MainThread) [supervisor.host.network] Updating local network information
24-02-22 10:37:58 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
24-02-22 10:37:59 INFO (MainThread) [supervisor.host.manager] Host information reload completed
24-02-22 10:38:12 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning addon_core_mosquitto application
24-02-22 10:38:17 WARNING (MainThread) [supervisor.addons.options] Unknown option 'logins' for Mosquitto broker (core_mosquitto)
24-02-22 10:38:17 WARNING (MainThread) [supervisor.addons.options] Unknown option 'require_certificate' for Mosquitto broker (core_mosquitto)
24-02-22 10:38:18 WARNING (MainThread) [supervisor.addons.options] Unknown option 'logins' for Mosquitto broker (core_mosquitto)
24-02-22 10:38:18 WARNING (MainThread) [supervisor.addons.options] Unknown option 'require_certificate' for Mosquitto broker (core_mosquitto)
24-02-22 10:40:32 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-mosquitto with version 6.4.0
24-02-22 10:40:44 WARNING (MainThread) [supervisor.addons.options] Unknown option 'logins' for Mosquitto broker (core_mosquitto)
24-02-22 10:40:44 WARNING (MainThread) [supervisor.addons.options] Unknown option 'require_certificate' for Mosquitto broker (core_mosquitto)
24-02-22 10:42:14 ERROR (MainThread) [supervisor.services.modules.mqtt] There is already a MQTT service in use from core_mosquitto
24-02-22 10:42:25 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'mqtt'
24-02-22 10:42:28 INFO (MainThread) [supervisor.auth] Successful login for 'mqtt'
24-02-22 10:43:31 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.
24-02-22 10:44:39 WARNING (MainThread) [supervisor.addons.options] Unknown option 'logins' for Mosquitto broker (core_mosquitto)
24-02-22 10:44:39 WARNING (MainThread) [supervisor.addons.options] Unknown option 'require_certificate' for Mosquitto broker (core_mosquitto)
24-02-22 10:44:39 WARNING (MainThread) [supervisor.addons.options] Unknown option 'mqtt' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-22 10:49:55 WARNING (MainThread) [supervisor.addons.options] Unknown option 'logins' for Mosquitto broker (core_mosquitto)
24-02-22 10:49:55 WARNING (MainThread) [supervisor.addons.options] Unknown option 'require_certificate' for Mosquitto broker (core_mosquitto)
24-02-22 10:49:56 WARNING (MainThread) [supervisor.addons.options] Unknown option 'mqtt' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-22 10:53:02 WARNING (MainThread) [supervisor.addons.options] Unknown option 'mqtt' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-22 10:54:56 WARNING (MainThread) [supervisor.addons.options] Unknown option 'logins' for Mosquitto broker (core_mosquitto)
24-02-22 10:54:56 WARNING (MainThread) [supervisor.addons.options] Unknown option 'require_certificate' for Mosquitto broker (core_mosquitto)
24-02-22 10:54:56 WARNING (MainThread) [supervisor.addons.options] Unknown option 'mqtt' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-22 10:55:21 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
24-02-22 10:55:21 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
24-02-22 10:55:31 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
24-02-22 10:55:31 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
24-02-22 10:55:31 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
24-02-22 10:55:31 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
24-02-22 10:55:35 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
24-02-22 10:55:35 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
24-02-22 10:55:35 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
24-02-22 10:55:35 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
24-02-22 10:55:35 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
24-02-22 10:55:35 INFO (MainThread) [supervisor.resolution.check] System checks complete
24-02-22 10:55:35 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
24-02-22 10:55:36 WARNING (MainThread) [supervisor.addons.options] Unknown option 'logins' for Mosquitto broker (core_mosquitto)
24-02-22 10:55:36 WARNING (MainThread) [supervisor.addons.options] Unknown option 'require_certificate' for Mosquitto broker (core_mosquitto)
24-02-22 10:56:13 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-02-22 10:56:13 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
24-02-22 10:56:13 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
24-02-22 10:57:00 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Zigbee2MQTT is failed, restarting...
24-02-22 10:57:00 INFO (SyncWorker_5) [supervisor.docker.manager] Cleaning addon_45df7312_zigbee2mqtt application
24-02-22 10:57:00 WARNING (MainThread) [supervisor.addons.options] Unknown option 'mqtt' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-22 10:57:05 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on zigbee2mqtt/zigbee2mqtt-aarch64 with version 1.35.3-1
24-02-22 10:57:05 WARNING (MainThread) [supervisor.addons.options] Unknown option 'mqtt' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-22 10:57:35 WARNING (MainThread) [supervisor.addons.options] Unknown option 'mqtt' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-22 10:58:40 WARNING (MainThread) [supervisor.misc.tasks] Watchdog missing application response from core_mosquitto
24-02-22 10:58:51 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Zigbee2MQTT is failed, restarting...
24-02-22 10:58:51 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning addon_45df7312_zigbee2mqtt application
24-02-22 10:58:52 WARNING (MainThread) [supervisor.addons.options] Unknown option 'mqtt' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-22 10:59:02 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on zigbee2mqtt/zigbee2mqtt-aarch64 with version 1.35.3-1
24-02-22 10:59:03 WARNING (MainThread) [supervisor.addons.options] Unknown option 'mqtt' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-22 10:59:33 WARNING (MainThread) [supervisor.addons.options] Unknown option 'logins' for Mosquitto broker (core_mosquitto)
24-02-22 10:59:33 WARNING (MainThread) [supervisor.addons.options] Unknown option 'require_certificate' for Mosquitto broker (core_mosquitto)
24-02-22 11:01:21 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Zigbee2MQTT is failed, restarting...
24-02-22 11:01:21 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning addon_45df7312_zigbee2mqtt application
24-02-22 11:01:22 WARNING (MainThread) [supervisor.addons.options] Unknown option 'mqtt' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-22 11:01:33 WARNING (MainThread) [supervisor.addons.options] Unknown option 'mqtt' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-22 11:01:34 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on zigbee2mqtt/zigbee2mqtt-aarch64 with version 1.35.3-1
24-02-22 11:03:28 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Zigbee2MQTT is failed, restarting...
24-02-22 11:03:28 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning addon_45df7312_zigbee2mqtt application
24-02-22 11:03:28 WARNING (MainThread) [supervisor.addons.options] Unknown option 'mqtt' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-22 11:03:37 WARNING (MainThread) [supervisor.addons.options] Unknown option 'mqtt' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-22 11:03:43 WARNING (MainThread) [supervisor.addons.options] Unknown option 'mqtt' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-22 11:03:44 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on zigbee2mqtt/zigbee2mqtt-aarch64 with version 1.35.3-1
24-02-22 11:05:13 WARNING (MainThread) [supervisor.addons.options] Unknown option 'mqtt' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-22 11:05:22 WARNING (MainThread) [supervisor.addons.options] Unknown option 'mqtt' for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-22 11:05:26 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
Merci. alut,
Infos :
Core 2024.2.2
OS : 11.5
Raspberry Pi 3
rpi3-64
Config :
Zigbee2mqtt
Mosquitto Broker
Logs :
Mosquitto
Zigbee2mqtt
Supervisor
Merci.
