Suite à la dernière mise à jour,
Home Assistant 2023.6.0
Supervisor 2023.06.1
Operating System 10.2
j’ai des erreurs dans ce style.
Unable to install package pybluez==0.22
Logger: homeassistant.util.package
Source: util/package.py:107
First occurred: 15:43:01 (3 occurrences)
Last logged: 15:43:38
Unable to install package pybluez==0.22: error: subprocess-exited-with-error × python setup.py bdist_wheel did not run successfully. │ exit code: 1 ╰─> [19 lines of output] running bdist_wheel running build running build_py creating build creating build/lib.linux-aarch64-cpython-311 creating build/lib.linux-aarch64-cpython-311/bluetooth copying bluetooth/__init__.py -> build/lib.linux-aarch64-cpython-311/bluetooth copying bluetooth/widcomm.py -> build/lib.linux-aarch64-cpython-311/bluetooth copying bluetooth/osx.py -> build/lib.linux-aarch64-cpython-311/bluetooth copying bluetooth/msbt.py -> build/lib.linux-aarch64-cpython-311/bluetooth copying bluetooth/btcommon.py -> build/lib.linux-aarch64-cpython-311/bluetooth copying bluetooth/bluez.py -> build/lib.linux-aarch64-cpython-311/bluetooth copying bluetooth/ble.py -> build/lib.linux-aarch64-cpython-311/bluetooth running build_ext building 'bluetooth._bluetooth' extension creating build/temp.linux-aarch64-cpython-311 creating build/temp.linux-aarch64-cpython-311/bluez gcc -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -fno-semantic-interposition -fno-builtin-malloc -fno-builtin-calloc -fno-builtin-realloc -fno-builtin-free -DTHREAD_STACK_SIZE=0x100000 -fPIC -I./port3 -I/usr/local/include/python3.11 -c bluez/btmodule.c -o build/temp.linux-aarch64-cpython-311/bluez/btmodule.o error: command 'gcc' failed: No such file or directory [end of output] note: This error originates from a subprocess, and is likely not a problem with pip. ERROR: Failed building wheel for pybluez ERROR: Could not build wheels for pybluez, which is required to install pyproject.toml-based projects
Je suis sur un Raspi 4
Apparemment nous sommes plusieurs à avoir le problème.
Quelqu’un a t’il réussi à passer une quelconque mise à jour?
il y a bien une solution mais pas adaptée à une installation sur Raspberry ici
En attendant je ré-injecte une sauvegarde
Bonjour à tous
depuis la mise à jour 2023.06 l’état de mon smartphone n’est plus suivi via le Bluetooth
quand je vérifie la conf dans « Outils de développement » j’ai le message d’erreur
Configuration non valide !
Platform error device_tracker.bluetooth_tracker - Requirements for bluetooth_tracker not found: [‹ pybluez==0.22 ›].
dans "configuration.yaml ses lignes suffisaient jusqu’ici
# Tracker Bluetooth
device_tracker:
- platform: bluetooth_tracker
si un de vous a une idée merci
version
core-2023.6.0
installation_type
Home Assistant OS
dev
false
hassio
true
docker
true
user
root
virtualenv
false
python_version
3.11.3
os_name
Linux
os_version
6.1.21-v8
arch
aarch64
timezone
Europe/Paris
config_dir
/config
logged_in
false
can_reach_cert_server
ok
can_reach_cloud_auth
ok
can_reach_cloud
ok
host_os
Home Assistant OS 10.2
update_channel
stable
supervisor_version
supervisor-2023.06.1
agent_version
1.5.1
docker_version
23.0.6
disk_total
56.6 GB
disk_used
5.4 GB
healthy
true
supported
true
board
rpi4-64
supervisor_api
ok
version_api
ok
installed_addons
File editor (5.6.0), Terminal & SSH (9.7.1), Mosquitto broker (6.2.1)
dashboards
1
resources
0
views
1
mode
storage
oldest_recorder_run
30 mai 2023 à 12:47
current_recorder_run
8 juin 2023 à 22:29
estimated_db_size
22.07 MiB
database_engine
sqlite
database_version
3.41.2
Bonjour @Pulpy-Luke , oui mais pas pour ceux qui ont un raspberry. Command pip n’est pas installée…
De toute façon patcher à la main, peu importe la plate-forme c’est pas propre.
Vous avez tous les deux haos, donc ça sera probablement corrigé dans la prochaine release.
Un peu de patience (ou restauration de la version précédente) et ça devrait aller
Uowis
Juin 9, 2023, 6:55
6
J’avoue j’ai fait la manip à la main mentionné plus haut mais je suis pas confiant,…
Ca sera corriger vite je pense vu que ca met carafe une integration officiel (bluetooth_tracker)
Je vois 3 solutions :
Remettre l’ancienne version et attendre la correction
Commenter bluetooth_tracker en attendant la correction
Garder l’erreur en attendant la correction
J’ai rien vu dans la version 20223.6.1 qui vient d’arriver mais je pense aussi que ça devrait arriver vite.
Uowis
Juin 9, 2023, 8:50
8
je l’ai fait sur un raspberry il faut faire la commande dans le conteneur homeassistant
Juste pour info, c’est à dire? Moi j’avais essayé dans la fenêtre terminal.
Uowis
Juin 9, 2023, 11:43
10
Tu as essayé cette commande ?
non pas de commande sudo.
pas grave je vais attendre un update, j’ai réinstallé une sauvegarde
J’ai le même souci du coup quelle est la solution ?
Bjr, comme le disait @Pulpy-Luke , il vaut mieux attendre une mise à jour.
En attendant restaure une sauvegarde, c’est ce que j’ai fait…
D’accord j’ai supprimé ma ligne de code dans le fichier config en provisoire…
Salut dans le configuration.yaml
remplace bluetooth_tracker par bluetooth_le_tracker style:
### BLUETOOTH ###
- platform: bluetooth_le_tracker
consider_home: 180
interval_seconds: 60
new_device_defaults:
track_new_devices: true
Essaie, pour moi plus aucun message d’erreur
Nickel maxhome , ça marche ,merci.
Uowis
Juin 20, 2023, 10:44
17
on est d’accord que ca ne track pas les appareils Bluetooth normaux genre un smartphone ?
Bonjour, qu’on me corrige mais bluetooth_le_tracker fait que le tracker utilise le protocole Bluetooth Low Energy (BLE).
Moi mon Huawei P30, le Samsung A… de ma femme et mes sensors Xiami température humidité sont détectés sans problème
Uowis
Juin 21, 2023, 12:17
19
tu as declarer comment dans know_devices.yaml ?
Je n’ai pas mes telephones via BLE_tracker personnellement.
Uowis:
know_devices.yaml ?
je n’ai rien déclaré dans know_devices.yaml.
Par contre, c’est dans ce fichier que viennent se mettre les devices détectés et c’est là que je vois mes téléphones etc
