Surveillance température congélateur
J’ai une automatisation qui m’alerte si les températures remontent trop.
Ça a marché, mais ça ne marche plus "Error rendering data template: Value Error: Template error: roud got invalid input 'None' when rendering template 'Temperature: {{...}} but no default was specified.
Je suis sûr que ce sera clair pour vous ;-).
Merci de m’avoir lu.
alias: Surveillance congélateurs
description: ''
  - platform: numeric_state
    entity_id:
      - sensor.thermometre_1_temperature
    above: -18
    for:
      hours: 2
      minutes: 0
      seconds: 0
    entity_id:
      - sensor.thermometre_2_temperature
    above: -18
    for:
      hours: 2
      minutes: 0
      seconds: 0
    entity_id:
      - sensor.thermometre_3_temperature
    above: 12
    for:
      hours: 2
      minutes: 0
      seconds: 0
    entity_id:
      - sensor.thermometre_4_temperature
    above: 15
    for:
      hours: 2
      minutes: 0
      seconds: 0
condition: []
  - metadata: {}
      title: '{{ state_attr(trigger.entity_id, ''friendly_name'') }}'
      message: >-
        Température: {{ state_attr(trigger.entity_id, 'temperature')|round(1)
        }}°C à {{now().strftime('%H:%M') }}
    action: notify.critical
[center]## System Information
version core-2025.6.2
hassio false
python_version 3.13.3
os_version 6.8.0-62-generic
arch x86_64
Installed Version 2.0.5
Available Repositories 2103
Downloaded Repositories 12
logged_in true
subscription_expiration 9 mars 2026 à 01:00
relayer_connected true
relayer_region eu-central-1
remote_enabled true
remote_connected true
alexa_enabled false
google_enabled true
remote_server eu-central-1-12.ui.nabu.casa
certificate_status ready
instance_id f11bce2f5e6b4d68a443370a2189285a
can_reach_cloud failed to load: unreachable
dashboards 4
resources 5
views 7
Network Configuration
adapters lo (disabled), eth0 (enabled, default, auto)
ipv4_addresses lo (127.0.0.1/8), eth0 (172.18.0.3/16)
ipv6_addresses lo (::1/128), eth0 ()
announce_addresses 172.18.0.3
oldest_recorder_run 14 juin 2025 à 13:23
current_recorder_run 24 juin 2025 à 13:42
estimated_db_size 291.17 MiB
database_version 3.48.0
[/center]
ajoute |float(0) au template de température.
        Température: {{ state_attr(trigger.entity_id, 'temperature')|float(0) |round(1)
Bonjour et merci pour ta réactivité,
Il n’y a plus d’erreur et les alertes remontent, mais le message est:
Réfrigérateur cuisine
Température: 0.0°C à 19:12
Alors que la température était de 24° environ.
Avez-vous des liens vers le typage des données ?
si c’est a 0, c’est la valeur par défaut du |float(0). C’est que ton thermomètre est indisponible.
le code state_attr(trigger.entity_id, 'temperature') suppose que l’attribut temperature existe sur l’entité.
essaie avec ça
Température: {{ states(trigger.entity_id) | float(0) | round(1) }}°C à {{ now().strftime('%H:%M') }}
Merci, ça marche!
Je ne comprends ni pourquoi ça marche, ni pourquoi une automation qui a fonctionné 1 an a fait sa crise.
Avez-vous des liens vers des pages qui présentent les types de valeurs ?
tu va simplement sur le page web de HA , exemple :arrow_heading_down:
Templating - Home Assistant (home-assistant.io)
