Suite installation frigate, avec configuration du serveur MQTT Mosquitto, il n’y a pas de synchronisation entre l’itégration MQTT de HASS et le serveur MOSQUTITTO sur mon NAS
J’ai controlé, le frigate envoie bien les infos sur Mosquitto (vu avec MQTT explorer) mais le ne recupère pas ces infos sur l’intégration MQTT.
Une petite aide ne serait pas de refus
version |
core-2025.6.3 |
installation_type |
Home Assistant OS |
dev |
false |
hassio |
true |
docker |
true |
user |
root |
virtualenv |
false |
python_version |
3.13.3 |
os_name |
Linux |
os_version |
6.6.74-haos-raspi |
arch |
aarch64 |
timezone |
Europe/Paris |
config_dir |
/config |
GitHub API |
ok |
GitHub Content |
ok |
GitHub Web |
ok |
HACS Data |
ok |
GitHub API Calls Remaining |
4994 |
Installed Version |
2.0.5 |
Stage |
running |
Available Repositories |
2045 |
Downloaded Repositories |
15 |
logged_in |
true |
subscription_expiration |
1 janvier 2018 à 01:00 |
relayer_connected |
false |
relayer_region |
null |
remote_enabled |
false |
remote_connected |
false |
alexa_enabled |
true |
google_enabled |
true |
cloud_ice_servers_enabled |
true |
remote_server |
null |
certificate_status |
null |
instance_id |
922112ff862e406c9e9d77e9a3abefa8 |
can_reach_cert_server |
ok |
can_reach_cloud_auth |
ok |
can_reach_cloud |
ok |
host_os |
Home Assistant OS 15.2 |
update_channel |
stable |
supervisor_version |
supervisor-2025.06.2 |
agent_version |
1.7.2 |
docker_version |
28.0.4 |
disk_total |
28.3 GB |
disk_used |
21.5 GB |
healthy |
true |
supported |
true |
host_connectivity |
true |
supervisor_connectivity |
true |
ntp_synchronized |
true |
virtualization |
board |
rpi4-64 |
supervisor_api |
ok |
version_api |
ok |
installed_addons |
Z-Wave JS (0.17.0), Studio Code Server (5.19.3), Zigbee2MQTT (2.4.0-1), Samba share (12.5.2), openWakeWord (1.10.0), Whisper (2.6.0), Piper (1.6.0), Node-RED (19.0.2), NGINX Home Assistant SSL proxy (3.12.0), Advanced SSH & Web Terminal (20.0.2), Frigate (0.15.1) |
dashboards |
5 |
resources |
8 |
views |
23 |
mode |
storage |
Network Configuration
adapters |
lo (disabled), end0 (enabled, default, auto), hassio (disabled), docker0 (disabled), vethf29ea1f (disabled), veth31c2db9 (disabled), vetha9f2a8b (disabled), veth5309d70 (disabled), veth5ddedb8 (disabled), veth239256d (disabled), veth15efd07 (disabled) |
ipv4_addresses |
lo (127.0.0.1/8), end0 (192.168.1.113/24), hassio (172.30.32.1/23), docker0 (172.30.232.1/23), vethf29ea1f (), veth31c2db9 (), vetha9f2a8b (), veth5309d70 (), veth5ddedb8 (), veth239256d (), veth15efd07 () |
ipv6_addresses |
lo (::1/128), end0 (2a01:e0a:2da:49c0:9112:f744:5b6c:39cb/64, fe80::6a0b:8cfb:ed5b:3781/64), hassio (fe80::40de:fcff:fe02:2c23/64), docker0 (fe80::9cf2:79ff:fe2c:d035/64), vethf29ea1f (fe80::ccad:77ff:fe58:582a/64), veth31c2db9 (fe80::2c52:c9ff:fe72:88df/64), vetha9f2a8b (fe80::c083:a4ff:fea8:5cc9/64), veth5309d70 (fe80::6c53:baff:fe4e:d19a/64), veth5ddedb8 (fe80::f8ba:72ff:fe9a:4200/64), veth239256d (fe80::c09f:b5ff:fe81:1306/64), veth15efd07 (fe80::a88a:14ff:fe51:77f7/64) |
announce_addresses |
192.168.1.113, 2a01:e0a:2da:49c0:9112:f744:5b6c:39cb, fe80::6a0b:8cfb:ed5b:3781 |
oldest_recorder_run |
15 juin 2025 à 21:08 |
current_recorder_run |
27 juin 2025 à 09:11 |
estimated_db_size |
1798.37 MiB |
database_engine |
sqlite |
database_version |
3.48.0 |
en general les capteurs ne remontent pas tout seul dans MQTT il faut créer des sensors MQTT, ceux qui remontent seuls (genre zigbee2mqtt) utilisent une procédé d’auto découverte.
je pense que tu dois créer tes sensors manuellement
Ce que je souhaite remonter par MQTT, ce sont les états de frigate ( nvr pour mes cameras) .
Les états sont bien remontés sur mon serveur MQTT mosquitto qui est installé sur mon NAS. (je le vois dans MQTT explorer).
mais lors que je regarde dans l’intégration MQTT, qui doit normalement , récupérer tous les infos de mosquitto, je le vois pas mes données de frigate. Je vois très bien ce qui est remonté par zigbee2MQTT ou par mon spa.
Tu n’as pas lu mon message ?
Il fait créer tes désirs toi même en suivant la doc des mqtt sensors le mqtt ne remonte pas automatiquement quand si il y’a de l’autodiscovery et ça ne semble pas être le cas sur ton frigate
si j ai lu mais je n ai pas du comprendre ta reponse , je vais fouiller
Merci de ton aide
les sensors mqtt ne remontent pas tjs automatiquement dans ce cas il faut les créer (cf la doc au dessus)
Tu as 2 broker ? un sur ton nas et un sur HA ?
il n’en a pas sur son HA en tout cas
Je me plante peut-être mais dans mon install, l’intégration frigate fonctionne correctement et remonte donc l’état des caméras , et je n’ai pourtant aucune entrée dans l’intégration mqtt de HA correspondant à Frigate.
Il n’est pas nécessaire que les sensors soient visiblent dans l’intégration mqtt pourque ça fonctionne
Non je n’ai qu un broker sur mon nas. J’utilise HA pour recupérer mes infos sur le broker mosquito qui est sur mon NAS
frigate fonctionne tres bien, mais il me semblait qu il fallait etre en MQTT pour automatiser les caméras configurées dans frigate
Qu’entends-tu par "automatiser les caméras " ?
sur Frigate, grace aux remontées vers le broker MQTT, (motion, detectikon, … ) tu peux declencher des automatisations sur HASS.
Les entités et sensor remontées par l’intégration frigate tout simplement
Installe l’intégration Frigate et tout remontera dans HA tout seul et sera dispo pour des automatisations et autres.
Me revoici.
Ta réponse peuit effectivement répondre à une partie de mes besoins, mais cela ne me dit pas pourquoi les messages MQTT de frigate ne remonte pas de mosquitto vers l’intégration MQTT de HASS.
Me revoici aussi
Les messages mqtt transitent entre l’intégration frigate de ton HA et ton broker.
Si tu veux les voir dans l’intégration mqtt de HA , il faut, comme expliqué pat @ddfdom dès le debut, créer manuellement ces sensors …mais pour quel usage / intérêt ??? Ca ne t’apportera rien de plus que ce remonte nativement l’intégration
