Permettre le choix et la MAJ des thèmes HACS et utiliser une personnalisation communes pour le dashboard énergie
Bonjour la communauté :wave:t2:
J’ai une personnalisation des couleurs du dashboard énergie pour refléter mon abonnement TEMPO, donc pour les différentes couleurs de jour et HC/HP.
Sauf que j’ai mis ces personnalisations dans le configuration.yaml
default_config:
frontend:
# themes: !include_dir_merge_named themes
themes:
theme_Couleurs_TEMPO:
ha-card-border-width: 0
# Bleu nuit: HC Bleu
energy-grid-consumption-color-0: "#9BE1FD"
# Bleu -magenta : HP Bleu
energy-grid-consumption-color-1: "#039DE0"
# Gris: HC Blanc
energy-grid-consumption-color-2: "#C8D9E5"
# Blanc : HP Blanc
energy-grid-consumption-color-3: "#8BAAC0"
# Rouge sang: HC Rouge
energy-grid-consumption-color-4: "#F49D9A"
# Red : HP Rouge
energy-grid-consumption-color-5: "#D9534F"
# Standard : Tarif Base
energy-grid-consumption-color-6: "#9eb75c"
modes:
light: {}
dark: {}
automation: !include /config/separate_yaml/automations.yaml
script: !include /config/separate_yaml/scripts.yaml
scene: !include /config/separate_yaml/scenes.yaml
input_number: !include /config/separate_yaml/input_numbers.yaml
# template: !include /config/templates.yaml
template: !include_dir_merge_list /config/separate_yaml/templates
sensor: !include /config/separate_yaml/sensors.yaml
# Personnalisations
http:
# For extra security set this to only accept connections on localhost if NGINX is on the same machine
# Uncommenting this will mean that you can only reach Home Assistant using the proxy, not directly via IP from other clients.
# server_host: 127.0.0.1
use_x_forwarded_for: true
# You must set the trusted proxy IP address so that Home Assistant will properly accept connections
# Set this to your NGINX machine IP, or localhost if hosted on the same machine.
trusted_proxies:
- 192.168.2.209 # Nginx via SWAG container
ip_ban_enabled: true
login_attempts_threshold: 5
Mais voilà, ceci me bloque l’utilisation des thèmes de HACS, car je ne peux les sélectionner car il faut avoir !include_dir_merge_named themes
qui va aller chercher les différents dossiers de thèmes dans /config/themes/
Mais si je passe par cette ligne d’include, je perds mes couleurs personnalisées dans le dashboard énergie.
Je pourrais éditer chacun des thèmes et ajouter les lignes de changement de couleur dans chacun, mais c’est fastidieux… Et surtout ça me bloquera les futures mises à jour de ces thèmes… où pire, si elles se dont, ça écrasera mes personnalisations.
Donc ma question est : comment faire pour avoir mes couleurs personnalisées dans le dashboard énergie, tout en pouvant utiliser les thèmes HACS et leurs mises à jour ?
Merci d’avance
version | core-2024.1.5 |
dev | false |
hassio | true |
docker | true |
user | root |
virtualenv | false |
python_version | 3.11.6 |
os_name | Linux |
os_version | 6.1.71-haos |
arch | x86_64 |
timezone | Europe/Paris |
config_dir | /config |
GitHub API | ok |
GitHub Content | ok |
GitHub Web | ok |
GitHub API Calls Remaining | 4984 |
Installed Version | 1.34.0 |
Stage | running |
Available Repositories | 1385 |
Downloaded Repositories | 29 |
HACS Data | ok |
logged_in | false |
can_reach_cert_server | ok |
can_reach_cloud_auth | ok |
can_reach_cloud | ok |
host_os | Home Assistant OS 11.4 |
update_channel | stable |
supervisor_version | supervisor-2023.12.1 |
agent_version | 1.6.0 |
docker_version | 24.0.7 |
disk_total | 30.8 GB |
disk_used | 7.6 GB |
healthy | true |
supported | true |
board | ova |
supervisor_api | ok |
version_api | ok |
installed_addons | Studio Code Server (5.15.0), Advanced SSH & Web Terminal (17.0.4), Silicon Labs Flasher (0.2.0), Zigbee2MQTT (1.35.1-1), Mosquitto broker (6.4.0), Samba Backup (5.2.0), tiko / Mon Pilotage Elec (1.3.1), File editor (5.7.0) |
dashboards | 2 |
resources | 18 |
views | 7 |
mode | storage |
oldest_recorder_run | January 16, 2024 at 1:52 PM |
current_recorder_run | January 23, 2024 at 12:48 PM |
estimated_db_size | 78.01 MiB |
database_engine | sqlite |
database_version | 3.41.2 |
