Trouver l'IP du serveur MQTT
Je souhaite savoir comment faire pour connaitre l’adresse IP de mon serveur MQTT.
Pour connecter un gestionnaire d’énergie.
Pouvez-vous m’aider?
Merci d’avance
version core-2025.3.4
python_version 3.13.2
os_version 6.12.18-haos
timezone Europe/Zurich
Installed Version 2.0.5
Available Repositories 1599
Downloaded Repositories 3
host_os Home Assistant OS 15.0
supervisor_version supervisor-2025.03.3
agent_version 1.7.2
docker_version 28.0.1
disk_total 28.0 GB
disk_used 5.2 GB
virtualization
board green
installed_addons Get HACS (1.3.1), Mosquitto broker (6.5.0), File editor (5.8.0)
dashboards 2
resources 0
views 8
Network Configuration
adapters lo (disabled), end0 (enabled, default, auto), hassio (disabled), docker0 (disabled), veth6ebc102 (disabled), veth6a83a91 (disabled), veth74d494a (disabled), veth31beaad (disabled), veth4a32b3d (disabled), veth5db5fb1 (disabled), vethb0cc94d (disabled), vethe38382d (disabled)
ipv4_addresses lo (127.0.0.1/8), end0 (192.168.178.67/24), hassio (172.30.32.1/23), docker0 (172.30.232.1/23), veth6ebc102 (), veth6a83a91 (), veth74d494a (), veth31beaad (), veth4a32b3d (), veth5db5fb1 (), vethb0cc94d (), vethe38382d ()
ipv6_addresses lo (::1/128), end0 (fdab:706c:6219:0:af4a:e3e:25ef:24f4/64, 2001:8e0:30cd:f01:bb37:2b2e:b0ea:b9ca/64, fe80::2629:66ab:2622:da8d/64), hassio (fe80::d0f2:31ff:fe8c:1be9/64), docker0 (fe80::ccd9:50ff:fe56:f640/64), veth6ebc102 (fe80::fc77:25ff:feba:1c0a/64), veth6a83a91 (fe80::78c4:38ff:fef0:ddb/64), veth74d494a (fe80::f02c:b4ff:fed5:6298/64), veth31beaad (fe80::e881:99ff:fea0:8966/64), veth4a32b3d (fe80::98ca:d8ff:fe79:f57c/64), veth5db5fb1 (fe80::6c95:60ff:fef1:93ba/64), vethb0cc94d (fe80::94f5:15ff:febd:4991/64), vethe38382d (fe80::10ca:22ff:feb5:217d/64)
announce_addresses 192.168.178.67, fdab:706c:6219:0:af4a:e3e:25ef:24f4, 2001:8e0:30cd:f01:bb37:2b2e:b0ea:b9ca, fe80::2629:66ab:2622:da8d
oldest_recorder_run 9 mars 2025 à 19:29
current_recorder_run 21 mars 2025 à 23:55
estimated_db_size 346.04 MiB
database_version 3.48.0
C’est simplement l’IP de home assistant
Merci pour la réponse rapide
