En aillant ignorer ZHA et installer MQTT explorer + crée une connexion avec HA j’ai toujours le mem probleme Z2M ne se lance pas.
[18:18:03] INFO: Preparing to start...
[18:18:04] INFO: Socat not enabled
[18:18:04] INFO: Zigbee Herdsman debug logging enabled
[18:18:06] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:debug 2024-01-03 18:18:12: Can't load state from file /config/zigbee2mqtt/state.json (doesn't exist)
Zigbee2MQTT:info 2024-01-03 18:18:12: Logging to console and directory: '/config/zigbee2mqtt/log/2024-01-03.18-18-11' filename: log.txt
Zigbee2MQTT:debug 2024-01-03 18:18:12: Removing old log directory '/config/zigbee2mqtt/log/2024-01-03.17-54-45'
Zigbee2MQTT:info 2024-01-03 18:18:12: Starting Zigbee2MQTT version 1.35.0 (commit #unknown)
Zigbee2MQTT:info 2024-01-03 18:18:12: Starting zigbee-herdsman (0.30.0)
Zigbee2MQTT:debug 2024-01-03 18:18:12: Using zigbee-herdsman with settings: '{"adapter":{"concurrent":null,"delay":null,"disableLED":false},"backupPath":"/config/zigbee2mqtt/coordinator_backup.json","databaseBackupPath":"/config/zigbee2mqtt/database.db.backup","databasePath":"/config/zigbee2mqtt/database.db","network":{"channelList":[11],"extendedPanID":[88,149,67,199,92,129,28,44],"networkKey":"HIDDEN","panID":49278},"serialPort":{"adapter":"zigate","path":"/dev/ttyUSB0"}}'
2024-01-03T17:18:12.463Z zigbee-herdsman:adapter Failed to validate path: 'Error: spawn udevadm ENOENT'
2024-01-03T17:18:12.468Z zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[209,107,211,7,8,222,77,72,12,49,42,9,134,58,163,250],"panID":49278,"extendedPanID":[88,149,67,199,92,129,28,44],"channelList":[11]},"serialPort":{"path":"/dev/ttyUSB0","adapter":"zigate"},"databasePath":"/config/zigbee2mqtt/database.db","databaseBackupPath":"/config/zigbee2mqtt/database.db.backup","backupPath":"/config/zigbee2mqtt/coordinator_backup.json","adapter":{"disableLED":false,"concurrent":null,"delay":null}}'
2024-01-03T17:18:12.489Z zigbee-herdsman:adapter:zigate:driver:log Successfully connected ZiGate port '/dev/ttyUSB0'
2024-01-03T17:18:12.491Z zigbee-herdsman:adapter:zigate:adapter:log Connected to ZiGate adapter successfully.
2024-01-03T17:18:12.497Z zigbee-herdsman:adapter:zigate:driver:log Send command >>>> Reset 0x0011 <<<<
Payload: {}
2024-01-03T17:18:12.504Z zigbee-herdsman:adapter:zigate:driver:log ZiGateFrame { msgCodeBytes: <Buffer 00 11>, msgLengthBytes: <Buffer 00 00>, checksumBytes: <Buffer 11>, msgPayloadBytes: <Buffer >, rssiBytes: <Buffer >, msgLengthOffset: 0 }
2024-01-03T17:18:12.506Z zigbee-herdsman:adapter:zigate:driver:log <-- send command <Buffer 01 02 10 11 02 10 02 10 11 03>
2024-01-03T17:18:12.507Z zigbee-herdsman:adapter:zigate:driver:log DisableResponse: false
Zigbee2MQTT:error 2024-01-03 18:18:17: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2024-01-03 18:18:17: Failed to start zigbee
Zigbee2MQTT:error 2024-01-03 18:18:17: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2024-01-03 18:18:17: Exiting...
Zigbee2MQTT:error 2024-01-03 18:18:17: Error: failed to connect to zigate adapter [object Object] after 5000ms
at ZiGateAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/zigate/adapter/zigateAdapter.ts:101:19)
at runNextTicks (node:internal/process/task_queues:60:5)
at listOnTimeout (node:internal/timers:538:9)
at processTimers (node:internal/timers:512:7)
at Zigbee.start (/app/lib/zigbee.ts:60:27)
at Controller.start (/app/lib/controller.ts:101:27)
at start (/app/index.js:107:5)
