Utilisation de service HA avec node red
Je requière votre aide afin de comprendre pourquoi une fonction de mon flow ne fonctionne pas.
Voici le flow
[{"id":"fbcf2a1d21d4780f","type":"inject","z":"5056bad6e29e9cb7","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"40","payloadType":"num","x":1230,"y":180,"wires":[["a70759bef0fd1362"]]},{"id":"a70759bef0fd1362","type":"function","z":"5056bad6e29e9cb7","name":"Changement  Niveau","func":"/*if (context.flow.get(\"vr_ouvr\") == 0 && context.flow.get(\"action\") == \"ouverture\") {\n    context.flow.set(\"vr_ouvr\", 1, \"default\");\n}\nif (context.flow.get(\"vr_ferm\") == 0 && context.flow.get(\"action\") == \"fermeture\") {\n    context.flow.set(\"vr_ferm\", 1, \"default\");\n}\nmsg.payload = {\n    domain: \"homeassistant\",\n    service: \"set_value\",\n    target: {\n        \"entity_id\": [\"input_number.volets_niveau_bureau\"]\n    },\n    data: {\n        \"value\": context.flow.get(\"pourcentage\")\n        \"value\": msg.payload\n    }\n}*/\nmsg.payload = {\n    domain: \"homeassistant\",\n    service: \"set_value\",\n    target: {\n        \"entity_id\": [\"input_number.volets_niveau_bureau\"]\n    },\n    data: {\n        \"value\": msg.payload\n    }\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1600,"y":140,"wires":[["edd92d4715a18e0a","8c0e0cd3a1287b75"]],"info":"Met à jour le niveau d'ouverture affiché\r\nBloque à 1 la variable permettant de ne pas boucher"},{"id":"8c0e0cd3a1287b75","type":"api-call-service","z":"5056bad6e29e9cb7","name":"","server":"8ba7aec4.1022e","version":5,"debugenabled":false,"domain":"","service":"","areaId":[],"deviceId":[],"entityId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1930,"y":140,"wires":[["a29827db5a89b7de"]]},{"id":"edd92d4715a18e0a","type":"debug","z":"5056bad6e29e9cb7","name":"debug 127","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1870,"y":200,"wires":[]},{"id":"a29827db5a89b7de","type":"debug","z":"5056bad6e29e9cb7","name":"debug 130","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":2110,"y":240,"wires":[]},{"id":"c857505616340b2d","type":"debug","z":"5056bad6e29e9cb7","name":"debug 131","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":2130,"y":400,"wires":[]},{"id":"5464514303628974","type":"api-call-service","z":"5056bad6e29e9cb7","name":"","server":"8ba7aec4.1022e","version":5,"debugenabled":false,"domain":"input_number","service":"set_value","areaId":[],"deviceId":["c39d8e65a25cc96e65bd524011ba935a"],"entityId":["input_number.volets_niveau_bureau"],"data":"{\"value\": msg.payload}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1870,"y":340,"wires":[["c857505616340b2d"]]},{"id":"178f187a51e1d2b7","type":"inject","z":"5056bad6e29e9cb7","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"30","payloadType":"num","x":1590,"y":340,"wires":[["5464514303628974"]]},{"id":"8ba7aec4.1022e","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30,"areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
Quand j’utilise le payload pour lancer le service, il ne me met aucune erreur mais l’input ne se met pas à jour. Si je mets toutes la conf dans le node ça fonctionne.
Je pense donc avoir une erreur dans ma syntaxe mais impossible de trouver ce qui ne lui plait pas.
Auriez-vous une idée?
Au cas ou, la fonction qui n’enclenche pas le service:
msg.payload = {
    domain: "homeassistant",
    service: "set_value",
    target: {
        "entity_id": ["input_number.volets_niveau_bureau"]
    data: {
        "value": msg.payload
return msg;
et mon msg sortant:
{"_msgid":"926fd978ccc62b72","payload":{"domain":"homeassistant","service":"set_value","target":{"entity_id":["input_number.volets_niveau_bureau"]},"data":{"value":40}}}
Voila si quelqu’un utilise déjà les services de cette façon, peut-il m’aider?
C’est le domain qui n’est pas bon.
Ca, ça marche:
msg.payload = {
    domain: "input_number",
    target: {
        "entity_id": ["input_number.test_number"]
    data: {
return msg;
Merci @golfvert je venais de trouver.
Il a fallu que je vous écrive pour que l’erreur me saute aux yeux. Parfois, un peu de recule c’est bon :slight_smile:
merci à toi je vais pouvoir simplifier mes flows grâce à ça.
Bon WE à la communauté
Parfait…
Même si ce n’est pas la question, je ne suis pas sûr qu’utiliser un nœud function pour pouvoir mettre en variable tous les paramètres du call_service soit une « bonne » méthode.
Il est possible d’utiliser des variables aux endroits clé (la valeur, l’entité) avec jsonata ou mustache.
J’ai l’impression que sur la durée la maintenance risque d’être compliquée.
Quel est le but recherché ?
Re,
En fait, j’ai un flow qui utilise à plusieurs reprises des services HA qui changent en fonction de leur place dans le code.
Je cherche donc à réduire le nombre de nœuds en les factorisant. Au delà de ça, je dois avouer que je préfère la lecture de ligne de code mais c’est effectivement très personnel :slight_smile: . J’ai un peu de mal avec les langage « imagé »
Là où je bloque, à dire vrai c’est dans la parallèlisation des flows, que je n’ai pas bien compris. Du coup, je les duplique et là la maintenance en prends un coup, je suis d’accord. Je pense regarder ce point plus tard. j’avance petit à petit.
Je note ta remarque, mais pour le moment, je sais pas trop comment je vais m’y prendre dans ce dev. Je suis donc embêté pour t’expliquer mon objectif.
Quand ce sera plus clair dans ma tête je pourrais te répondre.
En attendant, je te remercie de pour ton temps et pour ton aide
Réduire le nombre de noeuds, n’est, je pense, pas un objectif. Tu risques de réduire la lisibilité de l’ensemble pour pas un grand intérêt.
Alors, les automatisations en yaml sont faites pour toi :wink:
Alors, il faut mieux prendre un papier et décrire ce que tu veux faire avec des mots. La programmation en yaml ou nodered n’est que la traduction d’un algorithme…
Oui j’ai une V1 de mon flow qui fonctionne mais il y a quelque truc qui ne me plaise pas donc je réfléchit par écrit et teste certaine brique pour comprendre le fonctionnement.
j’aime bien la découverte
