Utility Meter mesurer votre consommation d'énergie
bonjour je vais vous partager mon Utility Meter
Cette intégration permet de connaître ses consommations électriques
1/ matériel :
comptage: PZEM-004t 100a
esp: esp32
J’ai choisi le modèle avec anneau monté directement sur la phase de mon arrivée EDF
2/ flash de l’esp avec esp home
prog
esphome:
  platform: ESP32
  board: esp32doit-devkit-v1
wifi:
  networks:
    - ssid: "xxxxx"
      password: "xxxxxxx"
    - ssid: "xxxxxxx"
      password: "xxxxxxxxx"
  ap:
    ssid: "Esp tableau"
    password: "xxxxxxxx"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
uart:
  - id: ubus1
    tx_pin: GPIO1
    rx_pin: GPIO3
    baud_rate: 9600
    stop_bits: 2     #pour un ESP8266, essayer plutôt la valeur 1
time:
  platform: sntp
  on_time:
      - seconds: 57
        minutes: 59
        hours: 23
        then:
          - sensor.template.publish:
              state: !lambda return id(puissance_tableau_du_jour).state;
  - platform: pzemac
    address: 1
    current:
      accuracy_decimals: 2
    voltage:
    power:
      unit_of_measurement: W
    frequency:
      unit_of_measurement: Hz
    power_factor:
    energy:
      unit_of_measurement: Wh
      accuracy_decimals: 1
    update_interval: 5s
    unit_of_measurement: "kWh"
    update_interval: 5s
    icon: mdi:power
    lambda: return (( (id(Wh_tableau).state)/1000.0));
  - platform: total_daily_energy
    power_id: puissance_tableau
    filters:
        # Multiplication factor from W to kW is 0.001
        - multiply: 0.001
    icon: mdi:counter
    unit_of_measurement: "kwh"
    icon: mdi:power
    update_interval: 10s
    unit_of_measurement: "VA"
    icon: mdi:power
    lambda: return ( (id(puissance_tableau).state/id(fi_tableau).state));
    unit_of_measurement: "VAr"
    icon: mdi:power
    #lambda: return ( ((id(puissance_tableau_reactive).state)*sin(acos((id(fi_tableau).state))) ) );
    lambda: return ( ( sqrt( (id(puissance_tableau_reactive).state)*(id(puissance_tableau_reactive).state)   -  (id(fi_tableau).state)*(id(fi_tableau).state) ) )  );
  - platform: wifi_signal
    name: "WiFi puissance_enedis"
  - platform: uptime
switch:
  - platform: restart
binary_sensor:
  - platform: status
text_sensor:
    lambda: |-
      int seconds = (id(uptime_sec).state);
      int days = seconds / (24 * 3600);
      seconds = seconds % (24 * 3600);
      int hours = seconds / 3600;
      seconds = seconds % 3600;
      int minutes = seconds /  60;
      seconds = seconds % 60;
      return { (String(days) +"d " + String(hours) +"h " + String(minutes) +"m "+ String(seconds) +"s").c_str() };
    icon: mdi:clock-start
    update_interval: 113s
web_server:
  port: 80
3/ fichier configuration.yaml pour utility meter et hp/hc
configuration.yaml
########  consomation  ########
utility_meter:
  energy_total_usage_daily:
    source: sensor.wh_tableau_jour
    cycle: daily
    tariffs:
      - hp
      - hc
  energy_total_usage_weekly:
    cycle: weekly
    tariffs:
      - hp
      - hc
  energy_total_usage_monthly:
    cycle: monthly
    tariffs:
      - hp
      - hc
  energy_total_usage_yearly:
    cycle: yearly
    tariffs:
      - hp
      - hc
4/ l’automation pour changé les hc et hp
automation
- id: '1622132545289'
  alias: mise à jour hc/hp (Dupliquer)
  description: ''
  - platform: time
    at:
    - '21:00:00'
    - '23:00:00'
    - '01:30:00'
    - '07:30:00'
  - platform: homeassistant
    event: start
  condition: []
  - choose:
    - conditions:
      - condition: template
        value_template: '{{ ((states.sensor.time.state >= "07:30")  and (states.sensor.time.state
          < "21:00")) or ((states.sensor.time.state >= "23:00")  or (states.sensor.time.state
          < "01:30")) }} '
      sequence:
      - service: utility_meter.select_tariff
          entity_id:
          - utility_meter.energy_total_usage_yearly
          - utility_meter.energy_total_usage_daily
          - utility_meter.energy_total_usage_weekly
          - utility_meter.energy_total_usage_monthly
          tariff: hp
    - conditions:
        value_template: '{{ ((states.sensor.time.state >= "21:00")  and (states.sensor.time.state
          < "23:00")) or ((states.sensor.time.state >= "01:30")  and (states.sensor.time.state
          < "07:30")) }} '
      sequence:
          entity_id:
          tariff: hc
    default: []
5/ les petits plus sensor conso , pourcentage etc.
sensor.yaml
########  conso elec ########
  sensors:
energy_total_daily:
  friendly_name: 'Energie journalière consommée'
  value_template: "{{ (states('sensor.energy_total_usage_daily_hp')|float + states('sensor.energy_total_usage_daily_hc')|float)|round(2) }}"
[details="sensor.yaml"]
  sensors:
energy_total_weekly:
  friendly_name: 'Energie hebdo consommée'
  value_template: "{{ (states('sensor.energy_total_usage_weekly_hp')|float + states('sensor.energy_total_usage_weekly_hc')|float)|round(2) }}"
  sensors:
energy_total_montly:
  friendly_name: 'Energie mensuel consommée'
  value_template: "{{ (states('sensor.energy_total_usage_monthly_hp')|float + states('sensor.energy_total_usage_monthly_hc')|float)|round(2) }}"
  sensors:
energy_total_yearly:
  friendly_name: 'Energie annuel consommée'
  value_template: "{{ (states('sensor.energy_total_usage_yearly_hp')|float + states('sensor.energy_total_usage_yearly_hc')|float)|round(2) }}"
  sensors:
hp_hc:
  friendly_name: 'Energie mensuel € hp+hc'
  value_template: "{{ ((((states('sensor.energy_total_usage_monthly_hp')|float)*states('input_number.prix_hp')|float) + ((states('sensor.energy_total_usage_monthly_hc')|float)*states('input_number.prix_hc')|float)) + states('input_number.abo_hchp')|float )|round (3)}}"
  unit_of_measurement: "€"
  sensors:
base:
  friendly_name: 'Energie mensuel € base'
  value_template: "{{ ((((states('sensor.energy_total_usage_monthly_hp')|float)*states('input_number.prix_base')|float) + ((states('sensor.energy_total_usage_monthly_hc')|float)*states('input_number.prix_base')|float)) + states('input_number.abo_base')|float)|round(3)}}"
  sensors:
mensuel:
  friendly_name: 'Energie mensuel '
  value_template: "{{states('sensor.energy_total_usage_monthly_hc')}} HC et {{states('sensor.energy_total_usage_monthly_hp')}} HP"
  sensors:
hc_hp:
  friendly_name: 'pourcentage '
  value_template: >-
  {% set hchp = (states('sensor.energy_total_usage_monthly_hc')| float) /((states('sensor.energy_total_usage_monthly_hp')| float)+(states('sensor.energy_total_usage_monthly_hc')| float)) %}
  {% if hchp <= 1  %}
  {{ hchp| round(2)}} % d'heures creuses
[/details]
les input_number
input_nunber.yaml
###### tarif edf   ##########
prix_hp:
    initial: 0.1707
    min: 0
    max: 2
    unit_of_measurement: €
    mode: box
prix_hc:
    initial: 0.1257
    min: 0
    max: 2
    mode: box
prix_base:
    initial: 0.1507
    min: 0
    max: 2
    mode: box
abo_base:
    initial: 12.67
    min: 10
    max: 20
    mode: box
abo_hchp:
    initial: 15.14
    min: 10
    max: 20
    mode: box
6/ le résultat
Même si ce tuto date un peu, je tiens à te remercier.
Cependant, j’ai un petit problème… Mes heures creuses sont de 22h36 à 6h36 et je ne sais pas comment les saisir dans automatisation.
Pourrais-tu m’aider s’il te plaît ?
Merci d’avance.
bonjour je pense qu’il faut changer les heures de déclenchement dans l’automation du même noms:
les modifs
  description: ''
  - platform: time
    at:
    - '21:00:00'   # ici
    - '23:00:00'  # ici
    - '01:30:00'  #supprimé
    - '07:30:00'  #supprimé
aussi ici
              < "01:30")) }} '
et enfin ici
      < "07:30")) }} '
tu n’as qu’une plage donc:
normalement ca
  description: ''
  - platform: time
    at:
    - '20:36:00'
    - '06:36:00'
    event: start
  condition: []
  - choose:
    - conditions:
        value_template: '{{ ((states.sensor.time.state >= "06:36")  and (states.sensor.time.state
          < "20:36")) }} '
      sequence:
          entity_id:
          tariff: hp
    - conditions:
        value_template: '{{ ((states.sensor.time.state >= "20:36")  and (states.sensor.time.state
          < "23:59")) or ((states.sensor.time.state >= "00:00")  and (states.sensor.time.state
          < "06:36")) }} '
      sequence:
          entity_id:
          tariff: hc
    default: []
a vérifier la condition 2 20h36—>6h36 :
          < "06:36")) }} '
car je suis pas trop sur du template
pour info le Linky peut aussi te donner un sensor HC et un sensor HP qui seront alors tes déclencheurs et tes conditions.
et comme l’intégration de compteur à été facilité
tu fais paramètre ----> appareille et service-------> entrées ------>ajouter une entrée---->compteur de service publique . et voila tu rentre ton sensor WH tes sensorHP et sensorHC du linky
stefan
Merci, c’est sympa je vais tester.
En fait, là c’est pour calculer le coût de la filtration de ma pompe piscine que je cherche à faire ton automatisation.
Pour mon compteur linky, j’ai réussi à avoir un module teleinfokit qui fonctionne parfaitement via Mqtt.
bonjour,
tien ca peux aider :
compte le temps de fonctionnement sur une journée d’une entitée:
Résumé
dans sensor.yaml
- platform: history_stats
  name: Lamp ON today
  entity_id: light.ventilateur
  state: "on"
  type: time
  start: "{{ now().replace(hour=0, minute=0, second=0) }}"
  end: "{{ now() }}"
et le service notify.file
peux te permettre d’extraire des donnée sur un .txt ou autres.
en gros un txt a transformer en exel avec date et conso.
Résumé
service: notify.filenotify
  message: '{{states(''sensor.date_time'')}} {{states(''sensor.eau_consommation_jour'')}}'
pour revenir à nos moutons:
tu choisi deux tariff HP… et HC… (mon choix a voire si idem chez toi) qui te crée un select.eau (eau c’est mon choix le tiens sera différent)
et une petite automation. le declencheur est le linky , tu peux mettre les heures .
automation chgt tariff
alias: 'changement de tariff '
description: ''
  - platform: state
    entity_id:
      - sensor.tariff
condition: []
  - choose:
      - conditions:
          - condition: state
            entity_id: sensor.tariff
            state: HP..# faudra changer
        sequence:
          - service: select.select_option
              option: HP..# faudra changé
              entity_id: select.eau2 # faudra changer
      - conditions:
          - condition: state
            state: HC..# faudra changer
        sequence:
              option: HC..# faudra changer
    default: []
mode: queued
max: 2
pour le cout ca reste identique à l’article
stefan
Encore merci, je vais essayer car à force de faire ou de modifier les sensors, les automations et des inputs, je t’avoue que je me suis perdu tout seul là.
Je vais faire un peu le ménage/trie afin que je puisse avoir les infos sur cette fameuse prise.
Je te tiens au courant. :crossed_fingers:
@steffleur
Salut, bon finalement je n’y arrive pas… Je suis dépité. Je vais devoir essayer de supprimer tout ce que j’ai fait car les heures creuses ne s’affichent pas sur ma prise.
Sinon, j’avais pensé la mettre dans l’onglet Energy mais il ne me trouve pas la prise :confused:.
Si tu as une idée, stp.
Encore merci
En mp attention au attribut des sensors lors des copier coller je suis français j’utilise hp et hc les anglophone utilisent Peak et offpeak…:face_with_monocle: Stefan
