Je cherche à paramétrer une planification avec le scheduler card (comme pour le chauffage) pour la climatisation de la maison. Malheureusement je ne trouve que les preset du mode chauffage (boost / eco / comfort) et non pas ceux du mode clim (eco clim/ comfort clim/ boost clim). Une astuce ou une méthode à utiliser ?
version
core-2025.6.0
installation_type
Home Assistant OS
dev
false
hassio
true
docker
true
user
root
virtualenv
false
python_version
3.13.3
os_name
Linux
os_version
6.12.23-haos
arch
x86_64
timezone
Europe/Paris
config_dir
/config
GitHub API
ok
GitHub Content
ok
GitHub Web
ok
HACS Data
ok
GitHub API Calls Remaining
4977
Installed Version
2.0.5
Stage
running
Available Repositories
2087
Downloaded Repositories
28
Solcast Solar
can_reach_server
ok
logged_in
false
can_reach_cert_server
ok
can_reach_cloud_auth
ok
can_reach_cloud
ok
host_os
Home Assistant OS 15.2
update_channel
stable
supervisor_version
supervisor-2025.05.5
agent_version
1.7.2
docker_version
28.0.4
disk_total
30.8 GB
disk_used
11.9 GB
healthy
true
supported
true
host_connectivity
true
supervisor_connectivity
false
ntp_synchronized
true
virtualization
kvm
board
ova
supervisor_api
ok
version_api
ok
installed_addons
Zigbee2MQTT (2.4.0-1), Mosquitto broker (6.5.1), Duck DNS (1.19.0), NGINX Home Assistant SSL proxy (3.11.1), Studio Code Server (5.19.3), Home Assistant Google Drive Backup (0.112.1), Advanced SSH & Web Terminal (20.0.2), Samba share (12.5.1), Matter Server (8.0.0)
