Visual studio code ou studio code serveur ne démarre pas
bonjour,
je souhaite installer Visual studio Code qui, visiblement, se nomme maintenant Studio code Serveur.
je télécharge l’add on, je l’installe et je le démarre.
Lorque je le sélectionne dans la barre latérale, HA me dit que l’add ne tourne pas… je retourne sur sa page et effectivement, je peux le démarrer donc i lne tournait pas, voici le journal de l’add on :
s6-rc: info: service base-addon-banner: starting
 Add-on: Studio Code Server
 Fully featured Visual Studio Code (VSCode) experience integrated in the Home Assistant frontend.
 Add-on version: 5.8.0
 You are running the latest version of this add-on.
 System: Home Assistant OS 10.3  (amd64 / qemux86-64)
 Home Assistant Core: 2023.6.3
 Home Assistant Supervisor: 2023.06.4
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service base-addon-timezone: starting
s6-rc: info: service base-addon-log-level: starting
[10:20:07] INFO: Configuring timezone (Europe/Paris)...
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service base-addon-timezone successfully started
s6-rc: info: service init-user: starting
s6-rc: info: service init-mysql: starting
s6-rc: info: service init-mosquitto: starting
s6-rc: info: service init-code-server: starting
s6-rc: info: service init-code-server successfully started
s6-rc: info: service init-mysql successfully started
s6-rc: info: service init-user successfully started
s6-rc: info: service code-server: starting
s6-rc: info: service code-server successfully started
[10:20:08] INFO: Starting code-server...
s6-rc: info: service init-mosquitto successfully started
[2023-07-03T08:20:09.827Z] info  Wrote default config file to ~/.config/code-server/config.yaml
[2023-07-03T08:20:10.841Z] info  code-server 4.14.1 5c199629305a0b935b4388b7db549f77eae82b5a
[2023-07-03T08:20:10.844Z] info  Using user-data-dir /data/vscode
[2023-07-03T08:20:10.871Z] info  Using config file ~/.config/code-server/config.yaml
[2023-07-03T08:20:10.871Z] info  HTTP server listening on http://0.0.0.0:1337/
[2023-07-03T08:20:10.871Z] info    - Authentication is disabled
[2023-07-03T08:20:10.871Z] info    - Not serving HTTPS
[2023-07-03T08:20:10.872Z] info  Session server listening on /data/vscode/code-server-ipc.sock
ma config :
## System Information
version | core-2023.6.3
dev | false
hassio | true
docker | true
user | root
virtualenv | false
python_version | 3.11.4
os_name | Linux
os_version | 6.1.34
arch | x86_64
timezone | Europe/Paris
config_dir | /config
GitHub API | ok
GitHub Content | ok
GitHub Web | ok
GitHub API Calls Remaining | 4941
Installed Version | 1.32.1
Stage | running
Available Repositories | 1267
Downloaded Repositories | 8
</details>
logged_in | true
subscription_expiration | 4 juillet 2023 à 02:00
relayer_connected | true
relayer_region | eu-central-1
remote_enabled | true
remote_connected | true
alexa_enabled | false
google_enabled | true
remote_server | eu-central-1-5.ui.nabu.casa
certificate_status | ready
can_reach_cert_server | ok
can_reach_cloud_auth | ok
can_reach_cloud | ok
</details>
host_os | Home Assistant OS 10.3
update_channel | stable
supervisor_version | supervisor-2023.06.4
agent_version | 1.5.1
docker_version | 23.0.6
disk_total | 30.8 GB
disk_used | 7.2 GB
healthy | true
supported | true
board | ova
supervisor_api | ok
version_api | ok
installed_addons | Terminal & SSH (9.7.1), File editor (5.6.0), Duck DNS (1.15.0), Z-Wave JS (0.1.84), Mosquitto broker (6.2.1), Samba share (10.0.2), Samba Backup (5.2.0), Zigbee2MQTT (1.32.0-2), Node-RED (14.2.2), Studio Code Server (5.8.0)
</details>
dashboards | 3
resources | 3
views | 6
mode | storage
</details>
oldest_recorder_run | 24 juin 2023 à 04:23
current_recorder_run | 3 juillet 2023 à 10:09
estimated_db_size | 294.02 MiB
database_engine | sqlite
database_version | 3.41.2
</details>
une idée ? merci d’avance
Il y a tout un tas de sujets dans le genre. Issues · hassio-addons/addon-vscode · GitHub
Effectivement ça semble se lancer( mais pas tout le temps) et s’arrêter (mais pas tout le temps non plus)
effectivement, il s’est lancé une fois, puis plus et là, ca marche…
Avant le premier démarrage, il a fallu une bonne heure … on verra ce que dit l’avenir
merci pour le lien que je vais consulter la prochaine fois que ca ne démarre pas
Depuis la dernière mise à jour 5.8.0
Je fais face à des déconnection de l’addon puis il se relance tout seul etc…
je n’ai pas trouvé d’astuce à date pour palier à ça
une prochaine mise à jour corrigera ceci
Bonjour vous avez trouvé la solution à votre problème ?
Comment avez-vous fait ?
La mise à jour de l’époque a résolu le sujet chez moi
il s’est produit la meme chose chez moi
