Depuis quelques jours, j’essaie de configurer un ESP32 et un ESP32-S3 en tant qu’assistant vocal. Pour cela, j’utilise un microphone INMP441.
Voici la conf de mes deux esp:
esphome:
friendly_name: Assistant Chambre
platformio_options:
board_build.flash_mode: dio
on_boot:
- light.turn_on:
blue: 100%
brightness: 60%
effect: fast pulse
esp32:
board: esp32-s3-devkitc-1
variant: esp32s3
framework:
type: esp-idf
sdkconfig_options:
CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "y"
CONFIG_ESP32S3_DATA_CACHE_64KB: "y"
CONFIG_ESP32S3_DATA_CACHE_LINE_64B: "y"
CONFIG_AUDIO_BOARD_CUSTOM: "y"
psram:
mode: octal
speed: 80MHz
# Enable logging
logger:
level: DEBUG
ota:
wifi:
ssid: !secret wifi_ssid
manual_ip:
# Set this to the IP of the ESP
static_ip: 192.168.1.23
# Set this to the IP address of the router. Often ends with .1
gateway: 192.168.1.1
# The subnet of the network. 255.255.255.0 works for most home networks.
subnet: 255.255.255.0
ap:
# Enable Home Assistant API
api:
on_client_connected:
then:
- delay: 50ms
- light.turn_off: led_ww
- micro_wake_word.start:
on_client_disconnected:
then:
- voice_assistant.stop:
button:
- platform: restart
switch:
optimistic: true
on_turn_on:
- micro_wake_word.stop:
- light.turn_on:
red: 100%
green: 0%
blue: 0%
brightness: 60%
effect: fast pulse
- delay: 2s
- light.turn_off:
- light.turn_on:
red: 100%
green: 0%
blue: 0%
brightness: 30%
on_turn_off:
- light.turn_on:
red: 0%
green: 100%
blue: 0%
brightness: 60%
effect: fast pulse
- delay: 2s
- light.turn_off:
light:
- platform: esp32_rmt_led_strip
rgb_order: GRB
pin: GPIO48
num_leds: 1
rmt_channel: 0
chipset: ws2812
name: "on board light"
effects:
- pulse:
- pulse:
transition_length: 0.5s
update_interval: 0.5s
min_brightness: 0%
max_brightness: 100%
# Audio and Voice Assistant Config
i2s_audio:
- id: i2s_mic
i2s_lrclk_pin: GPIO3
i2s_bclk_pin: GPIO2
- id: i2s_spk
i2s_lrclk_pin: GPIO6
i2s_bclk_pin: GPIO7
microphone:
platform: i2s_audio
adc_type: external
i2s_audio_id: i2s_mic
i2s_din_pin: GPIO4
channel: left
pdm: false
speaker:
platform: i2s_audio
dac_type: external
i2s_audio_id: i2s_spk
i2s_dout_pin: GPIO8
micro_wake_word:
on_wake_word_detected:
- voice_assistant.start:
- light.turn_on:
red: 30%
green: 30%
blue: 70%
brightness: 60%
effect: fast pulse
model: hey_jarvis
voice_assistant:
microphone: va_mic
speaker: va_spk
noise_suppression_level: 2.0
volume_multiplier: 4.0
on_stt_end:
then:
on_error:
on_end:
then:
- wait_until:
not:
voice_assistant.is_running:
esphome:
friendly_name: test
esp32:
board: esp32dev
framework:
type: arduino
version: recommended
# Enable logging
logger:
level: DEBUG
api:
ota:
wifi:
manual_ip:
static_ip: 192.168.1.19
ap:
captive_portal:
i2s_audio:
- id: i2s_in
i2s_lrclk_pin: GPIO26 #WS
i2s_bclk_pin: GPIO25 #SCK
microphone:
- platform: i2s_audio
adc_type: external
pdm: false
channel: left
bits_per_sample: 32bit
i2s_audio_id: i2s_in
i2s_din_pin: GPIO33 #SD Pin from the INMP441 Microphone
voice_assistant:
microphone: mic_i2s
auto_gain: 31dBFS
use_wake_word: false
- light.turn_on:
on_listening:
- light.turn_on:
effect: "Scan Effect With Custom Values"
red: 63%
green: 13%
blue: 93%
on_stt_end:
- light.turn_on:
effect: "None"
red: 0%
green: 100%
blue: 0%
on_error:
- light.turn_on:
effect: "None"
- if:
condition:
switch.is_on: use_wake_word
then:
- switch.turn_off: use_wake_word
- delay: 1sec
- switch.turn_on: use_wake_word
on_tts_start: # this is required to play the output on a media player
- homeassistant.service:
service: tts.speak
media_player_entity_id: media_player.marantz_sr6015 #replace this with your media player entity id
message: !lambda 'return x;'
entity_id: tts.piper #replace this with your piper tts id.
- if:
condition:
then:
- voice_assistant.start_continuous:
- if:
condition:
then:
on_end:
- light.turn_off:
binary_sensor:
- platform: status
name: API Connection
filters:
- delayed_on: 1s
on_press:
- if:
condition:
then:
on_release:
- if:
condition:
then:
switch:
name: Use wake word
optimistic: true
restore_mode: RESTORE_DEFAULT_ON
entity_category: config
on_turn_on:
- lambda: id(va).set_use_wake_word(true);
- if:
condition:
not:
- voice_assistant.is_running
then:
on_turn_off:
- lambda: id(va).set_use_wake_word(false);
light:
- platform: neopixelbus
type: grb
pin: GPIO32 # DIN pin of the LED Strip
num_leds: 9 # change the Number of LEDS according to your LED Strip.
variant: SK6812
default_transition_length: 0.5s
effects:
- addressable_scan:
name: Scan Effect With Custom Values
move_interval: 50ms
scan_width: 2
Home Assistant, OpenWakeWord, Whisper et Piper sont installés sur Docker. Lorsque je teste l’ensemble du processus avec mon téléphone en mode debug, le mot de réveil et les commandes prononcés sont détectés. Sur mes ESP, le mot de réveil n’est pas détecté.
J’ai ensuite testé microWakeWord sur mon ESP32-S3 et cette fois-ci cela a marché.
Par contre, c’est la partie Whisper qui ne semble pas fonctionner plus. On dirait presque un soucis de connexion entre mes esp et ha/openwakeword/whisper/piper.
Je ne comprends pas ce qui se passe et je suis à court d’idées. Quelqu’un pourrait-il m’indiquer d’où vient le problème, s’il vous plaît ?
Bonjour @Nicolas117
J’utilise les mêmes solutions que @WarC0zes, le S3 très réactif mais je n’en ai sorti aucun retour son, si ça fonctionne pour toi je suis preneur de ta conf stp
Bob
Merci @WarC0zes, mais avant de complexifier les choses j’aimerais faire fonctionner mes esp.
Ma pipeline fonctionne plutôt bien lorsque j’utilise mon téléphone (whisper répond en 2 à 3s).
Le problème semble vraiment être du coté d’esphome.
J’ai eu beau faire tous les tutos du web, rien ne fonctionne. Je désespère .
Je suis avec un i3 sans gpu pour le conteneur whisper avec le model small-int8.
Ok je vais tester vosk mais je n’ai pas vu de doc sur le hub docker pour l’installation de l’image. De ce que je comprends sur le github il faut que je télécharge le modèle français sur le conteneur et que je passe le model utilisé en argument ?
Pour les logs de mes esp:
[20:23:14][I][app:102]: ESPHome version 2024.2.2 compiled on Mar 19 2024, 20:22:36
[20:23:14][C][wifi:577]: WiFi:
[20:23:14][C][wifi:409]: Local MAC: A0:B7:65:63:24:7C
[20:23:14][C][wifi:414]: SSID: [redacted]
[20:23:14][C][wifi:415]: IP Address: 192.168.1.19
[20:23:14][C][wifi:417]: BSSID: [redacted]
[20:23:14][C][wifi:418]: Hostname: 'test'
[20:23:14][C][wifi:420]: Signal strength: -50 dB ▂▄▆█
[20:23:14][C][wifi:424]: Channel: 11
[20:23:14][C][wifi:425]: Subnet: 255.255.255.0
[20:23:14][C][wifi:426]: Gateway: 192.168.1.1
[20:23:14][C][wifi:427]: DNS1: 0.0.0.0
[20:23:14][C][wifi:428]: DNS2: 0.0.0.0
[20:23:14][C][logger:447]: Logger:
[20:23:14][C][logger:448]: Level: DEBUG
[20:23:14][C][logger:449]: Log Baud Rate: 115200
[20:23:14][C][logger:451]: Hardware UART: UART0
[20:23:14][C][template.switch:068]: Template Switch 'Use wake word'
[20:23:14][C][template.switch:091]: Restore Mode: restore defaults to ON
[20:23:14][C][template.switch:057]: Optimistic: YES
[20:23:14][C][captive_portal:088]: Captive Portal:
[20:23:14][C][mdns:115]: mDNS:
[20:23:14][C][mdns:116]: Hostname: test
[20:23:14][C][ota:096]: Over-The-Air Updates:
[20:23:14][C][ota:097]: Address: 192.168.1.19:3232
[20:23:14][C][ota:100]: Using Password.
[20:23:14][C][ota:103]: OTA version: 2.
[20:23:14][C][api:139]: API Server:
[20:23:14][C][api:140]: Address: 192.168.1.19:6053
[20:23:14][C][api:142]: Using noise encryption: YES
[20:25:13][D][switch:012]: 'Use wake word' Turning ON.
[20:25:13][D][switch:055]: 'Use wake word': Sending state ON
[20:25:13][D][voice_assistant:416]: State changed from IDLE to START_PIPELINE
[20:25:13][D][voice_assistant:422]: Desired state set to START_MICROPHONE
[20:25:13][D][voice_assistant:118]: microphone not running
[20:25:13][D][voice_assistant:202]: Requesting start...
[20:25:13][D][voice_assistant:416]: State changed from START_PIPELINE to STARTING_PIPELINE
[20:25:13][D][voice_assistant:437]: Client started, streaming microphone
[20:25:13][D][voice_assistant:416]: State changed from STARTING_PIPELINE to START_MICROPHONE
[20:25:13][D][voice_assistant:422]: Desired state set to STREAMING_MICROPHONE
[20:25:13][D][voice_assistant:155]: Starting Microphone
[20:25:13][D][voice_assistant:416]: State changed from START_MICROPHONE to STARTING_MICROPHONE
[20:25:13][D][voice_assistant:523]: Event Type: 1
[20:25:13][D][voice_assistant:526]: Assist Pipeline running
[20:25:13][D][voice_assistant:416]: State changed from STARTING_MICROPHONE to STREAMING_MICROPHONE
[20:25:13][D][voice_assistant:523]: Event Type: 9
[20:25:15][D][switch:016]: 'Use wake word' Turning OFF.
[20:25:15][D][switch:055]: 'Use wake word': Sending state OFF
[20:25:15][D][voice_assistant:516]: Signaling stop...
[20:25:15][D][voice_assistant:416]: State changed from STREAMING_MICROPHONE to STOP_MICROPHONE
[20:25:15][D][voice_assistant:422]: Desired state set to IDLE
[20:25:15][D][voice_assistant:416]: State changed from STOP_MICROPHONE to STOPPING_MICROPHONE
[20:25:15][D][voice_assistant:523]: Event Type: 0
[20:25:15][E][voice_assistant:653]: Error: no_wake_word - No wake word detected
[20:25:15][D][voice_assistant:416]: State changed from STOPPING_MICROPHONE to STOP_MICROPHONE
[20:25:15][D][voice_assistant:416]: State changed from STOP_MICROPHONE to IDLE
[20:25:15][D][voice_assistant:523]: Event Type: 2
[20:25:15][D][voice_assistant:613]: Assist Pipeline ended
[20:25:21][D][switch:012]: 'Use wake word' Turning ON.
[20:25:21][D][switch:055]: 'Use wake word': Sending state ON
[20:25:21][D][voice_assistant:416]: State changed from IDLE to START_PIPELINE
[20:25:21][D][voice_assistant:422]: Desired state set to START_MICROPHONE
[20:25:21][D][voice_assistant:118]: microphone not running
[20:25:21][D][voice_assistant:202]: Requesting start...
[20:25:21][D][voice_assistant:416]: State changed from START_PIPELINE to STARTING_PIPELINE
[20:25:21][D][voice_assistant:437]: Client started, streaming microphone
[20:25:21][D][voice_assistant:416]: State changed from STARTING_PIPELINE to START_MICROPHONE
[20:25:21][D][voice_assistant:422]: Desired state set to STREAMING_MICROPHONE
[20:25:21][D][voice_assistant:155]: Starting Microphone
[20:25:21][D][voice_assistant:416]: State changed from START_MICROPHONE to STARTING_MICROPHONE
[20:25:21][D][voice_assistant:523]: Event Type: 1
[20:25:21][D][voice_assistant:526]: Assist Pipeline running
[20:25:21][D][voice_assistant:416]: State changed from STARTING_MICROPHONE to STREAMING_MICROPHONE
[20:25:21][D][voice_assistant:523]: Event Type: 9
[20:25:57][D][esp32.preferences:114]: Saving 1 preferences to flash...
[20:25:57][D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[20:27:58][I][ota:117]: Boot seems successful, resetting boot loop counter.
[20:27:58][D][esp32.preferences:114]: Saving 1 preferences to flash...
[20:27:58][D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
Et pour le s3 avec microwakeword :
[22:22:32][C][wifi:577]: WiFi:
[22:22:32][C][wifi:409]: Local MAC: 48:27:E2:D3:0D:A0
[22:22:32][C][wifi:414]: SSID: [redacted]
[22:22:32][C][wifi:415]: IP Address: 192.168.1.23
[22:22:32][C][wifi:417]: BSSID: [redacted]
[22:22:32][C][wifi:418]: Hostname: 'assistant-chambre'
[22:22:32][C][wifi:420]: Signal strength: -39 dB ▂▄▆█
[22:22:32][C][wifi:424]: Channel: 11
[22:22:32][C][wifi:425]: Subnet: 255.255.255.0
[22:22:32][C][wifi:426]: Gateway: 192.168.1.1
[22:22:32][C][wifi:427]: DNS1: 0.0.0.0
[22:22:32][C][wifi:428]: DNS2: 0.0.0.0
[22:22:32][D][light:036]: 'on board light' Setting:
[22:22:32][D][light:085]: Transition length: 1.0s
[22:22:32][W][micro_wake_word:150]: Wake word is already running
[22:22:32][C][logger:447]: Logger:
[22:22:32][C][logger:448]: Level: DEBUG
[22:22:32][C][logger:449]: Log Baud Rate: 115200
[22:22:32][C][logger:451]: Hardware UART: USB_SERIAL_JTAG
[22:22:32][C][esp32_rmt_led_strip:175]: ESP32 RMT LED Strip:
[22:22:32][C][esp32_rmt_led_strip:176]: Pin: 11
[22:22:32][C][esp32_rmt_led_strip:177]: Channel: 0
[22:22:32][C][esp32_rmt_led_strip:202]: RGB Order: GRB
[22:22:32][C][esp32_rmt_led_strip:203]: Max refresh rate: 0
[22:22:32][C][esp32_rmt_led_strip:204]: Number of LEDs: 1
J’ai ajouté porcupine et vosk. Vosk est plus rapide ± 0.3s avec le modèle small mais est un peu moins précis que whisper.
En ce qui concerne mes esp, les résultats sont malheureusement les mêmes. Le wake word n’est pas détecté et coté stt il ne se passe rien.
INFO ESPHome 2024.2.2
INFO Reading configuration /config/test.yaml...
INFO Starting log output from 192.168.1.19 using esphome API
INFO Successfully connected to test @ 192.168.1.19 in 0.211s
INFO Successful handshake with test @ 192.168.1.19 in 0.099s
[08:02:47][I][app:102]: ESPHome version 2024.2.2 compiled on Mar 20 2024, 07:57:22
[08:02:47][C][wifi:577]: WiFi:
[08:02:47][C][wifi:409]: Local MAC: A0:B7:65:63:24:7C
[08:02:47][C][wifi:414]: SSID: [redacted]
[08:02:47][C][wifi:415]: IP Address: 192.168.1.19
[08:02:47][C][wifi:417]: BSSID: [redacted]
[08:02:47][C][wifi:418]: Hostname: 'test'
[08:02:47][C][wifi:420]: Signal strength: -57 dB ▂▄▆█
[08:02:47][C][wifi:424]: Channel: 11
[08:02:47][C][wifi:425]: Subnet: 255.255.255.0
[08:02:47][C][wifi:426]: Gateway: 192.168.1.1
[08:02:47][C][wifi:427]: DNS1: 0.0.0.0
[08:02:47][C][wifi:428]: DNS2: 0.0.0.0
[08:02:47][C][logger:447]: Logger:
[08:02:47][C][logger:448]: Level: DEBUG
[08:02:47][C][logger:449]: Log Baud Rate: 115200
[08:02:47][C][logger:451]: Hardware UART: UART0
[08:02:47][C][light:103]: Light 'Light'
[08:02:47][C][light:105]: Default Transition Length: 0.5s
[08:02:47][C][light:106]: Gamma Correct: 2.80
[08:02:47][C][template.switch:068]: Template Switch 'Use wake word'
[08:02:47][C][template.switch:091]: Restore Mode: restore defaults to ON
[08:02:47][C][template.switch:057]: Optimistic: YES
[08:02:47][C][status:034]: Status Binary Sensor 'API Connection'
[08:02:47][C][status:034]: Device Class: 'connectivity'
[08:02:47][C][captive_portal:088]: Captive Portal:
[08:02:47][C][mdns:115]: mDNS:
[08:02:47][C][mdns:116]: Hostname: test
[08:02:47][C][ota:096]: Over-The-Air Updates:
[08:02:47][C][ota:097]: Address: 192.168.1.19:3232
[08:02:47][C][ota:100]: Using Password.
[08:02:47][C][ota:103]: OTA version: 2.
[08:02:47][C][api:139]: API Server:
[08:02:47][C][api:140]: Address: 192.168.1.19:6053
[08:02:47][C][api:142]: Using noise encryption: YES
[08:02:58][D][switch:012]: 'Use wake word' Turning ON.
[08:02:58][D][switch:055]: 'Use wake word': Sending state ON
[08:02:58][D][voice_assistant:416]: State changed from IDLE to START_PIPELINE
[08:02:58][D][voice_assistant:422]: Desired state set to START_MICROPHONE
[08:02:58][D][voice_assistant:118]: microphone not running
[08:02:58][D][voice_assistant:202]: Requesting start...
[08:02:58][D][voice_assistant:416]: State changed from START_PIPELINE to STARTING_PIPELINE
[08:02:58][D][voice_assistant:437]: Client started, streaming microphone
[08:02:58][D][voice_assistant:416]: State changed from STARTING_PIPELINE to START_MICROPHONE
[08:02:58][D][voice_assistant:422]: Desired state set to STREAMING_MICROPHONE
[08:02:58][D][voice_assistant:155]: Starting Microphone
[08:02:58][D][voice_assistant:416]: State changed from START_MICROPHONE to STARTING_MICROPHONE
[08:02:58][D][voice_assistant:523]: Event Type: 1
[08:02:58][D][voice_assistant:526]: Assist Pipeline running
[08:02:58][D][voice_assistant:416]: State changed from STARTING_MICROPHONE to STREAMING_MICROPHONE
[08:02:58][D][voice_assistant:523]: Event Type: 9
[08:03:18][D][esp32.preferences:114]: Saving 1 preferences to flash...
[08:03:18][D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
Quand j’active le debug sur ha au niveau de la pipeline assist, avec mon esp-32s3 qui a microwakeword d’activé le .wav destiné à whisper ou vosk fait 44 octets.
De même avec l’esp32 pour le wakword et porcupine/openwakeword lorsque que je coupe l’utilisation du wakeword via le switch.
Je ne comprends vraiment pas ce qui est incorrect dans ma configuration.
