Re,
Non, non.
maintenant plus de souci.
J’a fait un flow node-red avec déclencheur allumage lampe salon et test du positionnement des volets.
[{"id":"0e6ee65234f9a561","type":"trigger-state","z":"8b9df13d8fdffd0a","name":"Lampe repas ON ?","server":"11a90641.be375a","version":2,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityid":"switch.relay_switch_1x2_5kw_3","entityidfiltertype":"exact","debugenabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"is","comparatorValueDatatype":"bool","comparatorValue":"true"}],"inputs":0,"outputs":3,"customoutputs":[{"messageType":"default","messageValue":"","messageValueType":"json","comparatorPropertyType":"always","comparatorPropertyValue":"","comparatorType":"is","comparatorValue":"","comparatorValueDataType":"str"}],"outputinitially":false,"state_type":"habool","enableInput":false,"x":110,"y":100,"wires":[["df68cc0791cbde57"],[],[]]},{"id":"df68cc0791cbde57","type":"time-range-switch","z":"8b9df13d8fdffd0a","name":"Heure > sunset - 45' && < sunset ??","lat":"45.772623","lon":"3.280114","startTime":"sunset","endTime":"sunset","startOffset":"-45","endOffset":"-2","x":390,"y":100,"wires":[["caa4466f241fea08","16e6aa02df3a32d7","441d1be55546ea21"],[]]},{"id":"af7042307d8d0b37","type":"comment","z":"8b9df13d8fdffd0a","name":"Pré-fermeture volets - Lampe Repas ON","info":"","x":180,"y":40,"wires":[]},{"id":"caa4466f241fea08","type":"api-current-state","z":"8b9df13d8fdffd0a","name":"Position volet Sud > 50 (Ouvert)","server":"11a90641.be375a","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"cover.roller_shutter_2","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"data_volet","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":730,"y":80,"wires":[["bfe2c3578b1c5fd0"]]},{"id":"bfe2c3578b1c5fd0","type":"switch","z":"8b9df13d8fdffd0a","name":"","property":"data_volet.attributes.current_position","propertyType":"msg","rules":[{"t":"gte","v":"50","vt":"str"},{"t":"lt","v":"50","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":950,"y":80,"wires":[["e493373051fdd7f6"],[]]},{"id":"e493373051fdd7f6","type":"api-call-service","z":"8b9df13d8fdffd0a","name":"Fermeture volet Sud","server":"11a90641.be375a","version":5,"debugenabled":true,"domain":"cover","service":"set_cover_position","areaId":[],"deviceId":[],"entityId":["cover.roller_shutter_2"],"data":"{ \"position\" : 50}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1140,"y":80,"wires":[[]]},{"id":"16e6aa02df3a32d7","type":"api-current-state","z":"8b9df13d8fdffd0a","name":"Position volet S/O > 50 (Ouvert)","server":"11a90641.be375a","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"cover.roller_shutter","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"data_volet","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":730,"y":120,"wires":[["6461cb7711e60651"]]},{"id":"6461cb7711e60651","type":"switch","z":"8b9df13d8fdffd0a","name":"","property":"data_volet.attributes.current_position","propertyType":"msg","rules":[{"t":"gte","v":"50","vt":"str"},{"t":"lt","v":"50","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":950,"y":120,"wires":[["cdb45cfbc962ba7b"],[]]},{"id":"cdb45cfbc962ba7b","type":"api-call-service","z":"8b9df13d8fdffd0a","name":"Fermeture volet S/O","server":"11a90641.be375a","version":5,"debugenabled":true,"domain":"cover","service":"set_cover_position","areaId":[],"deviceId":[],"entityId":["cover.roller_shutter"],"data":"{ \"position\" : 50}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1140,"y":120,"wires":[[]]},{"id":"441d1be55546ea21","type":"api-current-state","z":"8b9df13d8fdffd0a","name":"Position volet SaM> 50 (Ouvert)","server":"11a90641.be375a","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"cover.roller_shutter_4","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"data_volet","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":730,"y":160,"wires":[["21589fa048af0405"]]},{"id":"21589fa048af0405","type":"switch","z":"8b9df13d8fdffd0a","name":"","property":"data_volet.attributes.current_position","propertyType":"msg","rules":[{"t":"gte","v":"50","vt":"str"},{"t":"lt","v":"50","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":950,"y":160,"wires":[["a607b589e23614b4"],[]]},{"id":"a607b589e23614b4","type":"api-call-service","z":"8b9df13d8fdffd0a","name":"Fermeture volet SaM","server":"11a90641.be375a","version":5,"debugenabled":true,"domain":"cover","service":"set_cover_position","areaId":[],"deviceId":[],"entityId":["cover.roller_shutter_4"],"data":"{ \"position\" : 50}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1140,"y":160,"wires":[[]]},{"id":"11a90641.be375a","type":"server","name":"Home Assistant","version":2,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":false,"cacheJson":false,"heartbeat":false,"heartbeatInterval":30}]
