voilà le problème et je n’arrive pas à trouver d’où cela proviens
ce matin j’ai eu une notification photo ci jointe
et la je regarde mes LOGS et voilà ce qui est notifié
2023-12-13 09:53:36.821 WARNING (MainThread) [homeassistant.helpers.entity_component] Forced update failed. Entity update.platinum_weather_card_update not found.
2023-12-13 09:53:36.822 WARNING (MainThread) [homeassistant.helpers.entity_component] Forced update failed. Entity update.prixcarburant_update not found.
2023-12-13 09:53:36.822 WARNING (MainThread) [homeassistant.helpers.entity_component] Forced update failed. Entity update.rpi_monitor_card_update not found.
2023-12-13 09:53:36.823 WARNING (MainThread) [homeassistant.helpers.entity_component] Forced update failed. Entity update.sonoff_lan_update not found.
2023-12-13 09:53:36.823 WARNING (MainThread) [homeassistant.helpers.entity_component] Forced update failed. Entity update.swipe_card_update not found.
avez vous une idée sur ce problème.
Renseigner votre problème
## System Information
version | core-2023.12.1
dev | false
hassio | true
docker | true
user | root
virtualenv | false
python_version | 3.11.6
os_name | Linux
os_version | 6.1.58-haos-raspi
arch | aarch64
timezone | Europe/Paris
config_dir | /config
GitHub API | ok
GitHub Content | ok
GitHub Web | ok
Installed Version | 1.33.0
Stage | running
Available Repositories | 1417
Downloaded Repositories | 27
</details>
logged_in | false
can_reach_cert_server | ok
can_reach_cloud_auth | ok
can_reach_cloud | ok
</details>
host_os | Home Assistant OS 11.2
update_channel | stable
supervisor_version | supervisor-2023.11.6
agent_version | 1.6.0
docker_version | 24.0.7
disk_total | 109.3 GB
disk_used | 15.3 GB
healthy | true
supported | true
board | rpi4-64
supervisor_api | ok
version_api | ok
installed_addons | File editor (5.7.0), Samba share (12.2.0), AirCast (4.0.1), motionEye (0.19.1), eWeLink Smart Home (1.4.3), Terminal & SSH (9.8.1), Example (8.0.1), Log Viewer (0.16.0), Duck DNS (1.15.0), Let's Encrypt (5.0.6), Advanced SSH & Web Terminal (17.0.0), Mosquitto broker (6.4.0), InfluxDB (4.8.0), MyElectricalData (0.9.2-6), Linky (1.2.0), Grafana (9.1.1), NGINX Home Assistant SSL proxy (3.5.0), Studio Code Server (5.14.2)
</details>
dashboards | 4
resources | 22
views | 4
mode | storage
</details>
oldest_recorder_run | 7 décembre 2023 à 10:10
current_recorder_run | 12 décembre 2023 à 16:02
estimated_db_size | 113.58 MiB
database_engine | sqlite
database_version | 3.41.2
</details>
<details><summary>Sonoff</summary>
version | 3.5.3 (a8c6d45)
cloud_online | 18 / 18
local_online | 18 / 18
debug | failed to load:
</details>
en vous remerciant
